Training yolo_v4 with custom data with cspdarknet_53 arch.
random_seed: 42
yolov4_config {
big_anchor_shape: "[(233.47, 63.30),(339.88, 127.71),(754.14, 237.96)]"
mid_anchor_shape: "[(68.84, 52.25),(127.54, 36.81),(128.06, 91.08)]"
small_anchor_shape: "[(14.96, 9.41),(28.33, 17.79),(52.51, 27.30)]"
box_matching_iou: 0.25
matching_neutral_box_iou: 0.5
arch: "cspdarknet"
nlayers: 53
arch_conv_blocks: 2
loss_loc_weight: 0.8
loss_neg_obj_weights: 100.0
loss_class_weights: 0.5
label_smoothing: 0.0
big_grid_xy_extend: 0.05
mid_grid_xy_extend: 0.1
small_grid_xy_extend: 0.2
freeze_bn: false
#freeze_blocks: 0
force_relu: false
training_config {
batch_size_per_gpu: 2
num_epochs: 500
enable_qat: true
checkpoint_interval: 10
learning_rate {
soft_start_cosine_annealing_schedule {
min_learning_rate: 1e-7
max_learning_rate: 1e-4
soft_start: 0.3
regularizer {
type: L1
weight: 3e-5
optimizer {
adam {
epsilon: 1e-7
beta1: 0.9
beta2: 0.999
amsgrad: false
pretrain_model_path: "/root/nvidia/cv_samples_v1.2.0/yolo_v4/model/cspdarknet_53.hdf5"
eval_config {
average_precision_mode: SAMPLE
batch_size: 8
matching_iou_threshold: 0.5
nms_config {
confidence_threshold: 0.001
clustering_iou_threshold: 0.5
force_on_cpu: true
top_k: 200
augmentation_config {
hue: 0.1
saturation: 1.5
exposure:1.5
vertical_flip:0
horizontal_flip: 0.5
jitter: 0.3
output_width: 1248
output_height: 384
output_channel: 3
randomize_input_shape_period: 0
mosaic_prob: 0.5
mosaic_min_ratio:0.2
dataset_config {
data_sources: {
tfrecords_path: "/root/nvidia/cv_samples_v1.2.0/yolo_v4/data/training/tfrecords/train*"
image_directory_path: "/root/nvidia/cv_samples_v1.2.0/detectnet_v2/baggage/baggage/train/data"
include_difficult_in_training: true
image_extension: "png"
target_class_mapping {
key: "handbag"
value: "handbag"
key: "suitcase"
value: "suitcase"
key: "backpack"
value: "backpack"
key: "laptop"
value: "laptop"
validation_data_sources: {
tfrecords_path: "/root/nvidia/cv_samples_v1.2.0/yolo_v4/data/validation/tfrecords/val*"
image_directory_path: "/root/nvidia/cv_samples_v1.2.0/detectnet_v2/baggage/baggage/validation/data"
it stuck here
To run with multigpu, please change --gpus based on the number of available GPUs in your machine.
2021-10-12 07:42:53,618 [INFO] root: Registry: [‘nvcr.io’]
2021-10-12 07:42:53,721 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the “user”:“UID:GID” in the
DockerOptions portion of the “/root/.tao_mounts.json” file. You can obtain your
users UID and GID by using the “id -u” and “id -g” commands on the
terminal.
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
2021-10-12 07:43:06,168 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2021-10-12 07:43:06,169 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2021-10-12 07:43:06,240 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
2021-10-12 07:43:06,240 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2021-10-12 07:43:06,241 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
2021-10-12 07:43:06,242 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:40: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
2021-10-12 07:43:06,270 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:40: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:43: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
2021-10-12 07:43:06,270 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:43: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
2021-10-12 07:43:06,271 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:43: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
2021-10-12 07:43:06,271 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:40: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
2021-10-12 07:43:06,979 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
2021-10-12 07:43:06,981 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
2021-10-12 07:43:07,002 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
2021-10-12 07:43:07,013 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
2021-10-12 07:43:07,015 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
2021-10-12 07:43:07,016 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
2021-10-12 07:43:07,018 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
2021-10-12 07:43:07,035 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
2021-10-12 07:43:07,040 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
WARNING:tensorflow:From /opt/nvidia/third_party/keras/tensorflow_backend.py:183: The name tf.nn.max_pool is deprecated. Please use tf.nn.max_pool2d instead.
2021-10-12 07:43:09,177 [WARNING] tensorflow: From /opt/nvidia/third_party/keras/tensorflow_backend.py:183: The name tf.nn.max_pool is deprecated. Please use tf.nn.max_pool2d instead.
2021-10-12 07:43:09,270 [WARNING] tensorflow: From /opt/nvidia/third_party/keras/tensorflow_backend.py:183: The name tf.nn.max_pool is deprecated. Please use tf.nn.max_pool2d instead.
2021-10-12 07:43:09,313 [WARNING] tensorflow: From /opt/nvidia/third_party/keras/tensorflow_backend.py:183: The name tf.nn.max_pool is deprecated. Please use tf.nn.max_pool2d instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:2018: The name tf.image.resize_nearest_neighbor is deprecated. Please use tf.compat.v1.image.resize_nearest_neighbor instead.
2021-10-12 07:43:09,418 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:2018: The name tf.image.resize_nearest_neighbor is deprecated. Please use tf.compat.v1.image.resize_nearest_neighbor instead.
2021-10-12 07:43:09,509 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:2018: The name tf.image.resize_nearest_neighbor is deprecated. Please use tf.compat.v1.image.resize_nearest_neighbor instead.
2021-10-12 07:43:09,573 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:2018: The name tf.image.resize_nearest_neighbor is deprecated. Please use tf.compat.v1.image.resize_nearest_neighbor instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
2021-10-12 07:43:09,861 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
2021-10-12 07:43:09,862 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
2021-10-12 07:43:09,971 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
2021-10-12 07:43:09,972 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
2021-10-12 07:43:10,049 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
2021-10-12 07:43:10,050 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
2021-10-12 07:43:10,513 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
2021-10-12 07:43:10,622 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
2021-10-12 07:43:10,729 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
command tried:
!tao yolo_v4 train -e /root/nvidia/cv_samples_v1.2.0/yolo_v4/specs/yolo_v4_train_baggage_resnet18_kitti.txt
-r /root/nvidia/cv_samples_v1.2.0/yolo_v4/experiment_dir_unpruned
-k nvidia_tlt
–gpus 3
–gpu_index 0 1 2
