Hi I have been trying to train yolov4 using 4 gpus but it has got stuck from past 7 hours and has not thrown any error.
Command passed -
print(“To run with multigpu, please change --gpus based on the number of available GPUs in your machine.”)
!yolo_v4 train -e $SPECS_DIR/yolo_v4_train_darknet53_kitti.txt
-r $USER_EXPERIMENT_DIR/experiment_dir_unpruned
-k $KEY
–gpus 4
config file -
random_seed: 42
yolov4_config {
big_anchor_shape: “[(106.00, 124.00), (81.00, 197.00), (178.00, 216.00)]”
mid_anchor_shape: “[(39.00, 108.00), (60.00, 71.00), (57.00, 127.00)]”
small_anchor_shape: “[(24.00, 39.00), (39.00, 49.00), (29.00, 71.00)]”
box_matching_iou: 0.25
arch: “darknet”
nlayers: 53
arch_conv_blocks: 2
loss_loc_weight: 0.8
loss_neg_obj_weights: 100.0
loss_class_weights: 0.5
label_smoothing: 0.0
big_grid_xy_extend: 0.05
mid_grid_xy_extend: 0.1
small_grid_xy_extend: 0.2
freeze_bn: false
#freeze_blocks: 0
force_relu: false
training_config {
batch_size_per_gpu: 8
num_epochs: 100
enable_qat: false
checkpoint_interval: 10
learning_rate {
soft_start_cosine_annealing_schedule {
min_learning_rate: 1e-7
max_learning_rate: 1e-4
soft_start: 0.3
regularizer {
type: L1
weight: 3e-5
optimizer {
adam {
epsilon: 1e-7
beta1: 0.9
beta2: 0.999
amsgrad: false
pretrain_model_path: “/workspace/examples/yolo_v4/pretrained_darknet53/tlt_pretrained_object_detection_vdarknet53/darknet_53.hdf5”
eval_config {
average_precision_mode: SAMPLE
batch_size: 8
matching_iou_threshold: 0.5
nms_config {
confidence_threshold: 0.001
clustering_iou_threshold: 0.5
top_k: 200
augmentation_config {
hue: 0.1
saturation: 1.5
exposure:1.5
vertical_flip:0
horizontal_flip: 0.5
jitter: 0.3
output_width: 960
output_height: 544
randomize_input_shape_period: 0
mosaic_prob: 0.5
mosaic_min_ratio:0.2
dataset_config {
data_sources: {
label_directory_path: “/workspace/examples/yolo_v4/DATA_DOWNLOAD_DIR/training_labels”
image_directory_path: “/workspace/examples/yolo_v4/DATA_DOWNLOAD_DIR/training”
include_difficult_in_training: true
target_class_mapping {
key: “person”
value: “person”
validation_data_sources: {
label_directory_path: “/workspace/examples/yolo_v4/DATA_DOWNLOAD_DIR/val_labels”
image_directory_path: “/workspace/examples/yolo_v4/DATA_DOWNLOAD_DIR/val”
After running the output -
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
2021-06-17 19:15:12,713 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2021-06-17 19:15:12,714 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2021-06-17 19:15:13,335 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
2021-06-17 19:15:13,336 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2021-06-17 19:15:13,533 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
2021-06-17 19:15:13,533 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2021-06-17 19:15:13,536 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
2021-06-17 19:15:13,536 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
WARNING:tensorflow:From /home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:49: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
2021-06-17 19:15:13,620 [WARNING] tensorflow: From /home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:49: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
WARNING:tensorflow:From /home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:52: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
2021-06-17 19:15:13,620 [WARNING] tensorflow: From /home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:52: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
2021-06-17 19:15:13,621 [WARNING] tensorflow: From /home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:52: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
2021-06-17 19:15:14,618 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
2021-06-17 19:15:14,620 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
2021-06-17 19:15:14,631 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
2021-06-17 19:15:14,633 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
2021-06-17 19:15:14,637 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
2021-06-17 19:15:14,639 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
2021-06-17 19:15:14,649 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
2021-06-17 19:15:14,653 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
2021-06-17 19:15:14,656 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
2021-06-17 19:15:14,662 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
2021-06-17 19:15:14,668 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
2021-06-17 19:15:14,684 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
WARNING:tensorflow:From /opt/nvidia/third_party/keras/tensorflow_backend.py:183: The name tf.nn.max_pool is deprecated. Please use tf.nn.max_pool2d instead.
2021-06-17 19:15:16,364 [WARNING] tensorflow: From /opt/nvidia/third_party/keras/tensorflow_backend.py:183: The name tf.nn.max_pool is deprecated. Please use tf.nn.max_pool2d instead.
2021-06-17 19:15:16,510 [WARNING] tensorflow: From /opt/nvidia/third_party/keras/tensorflow_backend.py:183: The name tf.nn.max_pool is deprecated. Please use tf.nn.max_pool2d instead.
2021-06-17 19:15:16,529 [WARNING] tensorflow: From /opt/nvidia/third_party/keras/tensorflow_backend.py:183: The name tf.nn.max_pool is deprecated. Please use tf.nn.max_pool2d instead.
2021-06-17 19:15:16,544 [WARNING] tensorflow: From /opt/nvidia/third_party/keras/tensorflow_backend.py:183: The name tf.nn.max_pool is deprecated. Please use tf.nn.max_pool2d instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:2018: The name tf.image.resize_nearest_neighbor is deprecated. Please use tf.compat.v1.image.resize_nearest_neighbor instead.
2021-06-17 19:15:16,654 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:2018: The name tf.image.resize_nearest_neighbor is deprecated. Please use tf.compat.v1.image.resize_nearest_neighbor instead.
2021-06-17 19:15:16,856 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:2018: The name tf.image.resize_nearest_neighbor is deprecated. Please use tf.compat.v1.image.resize_nearest_neighbor instead.
2021-06-17 19:15:16,858 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:2018: The name tf.image.resize_nearest_neighbor is deprecated. Please use tf.compat.v1.image.resize_nearest_neighbor instead.
2021-06-17 19:15:16,869 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:2018: The name tf.image.resize_nearest_neighbor is deprecated. Please use tf.compat.v1.image.resize_nearest_neighbor instead.
WARNING:tensorflow:From /opt/nvidia/third_party/keras/tensorflow_backend.py:187: The name tf.nn.avg_pool is deprecated. Please use tf.nn.avg_pool2d instead.
2021-06-17 19:15:19,389 [WARNING] tensorflow: From /opt/nvidia/third_party/keras/tensorflow_backend.py:187: The name tf.nn.avg_pool is deprecated. Please use tf.nn.avg_pool2d instead.
2021-06-17 19:15:19,486 [WARNING] tensorflow: From /opt/nvidia/third_party/keras/tensorflow_backend.py:187: The name tf.nn.avg_pool is deprecated. Please use tf.nn.avg_pool2d instead.
2021-06-17 19:15:19,599 [WARNING] tensorflow: From /opt/nvidia/third_party/keras/tensorflow_backend.py:187: The name tf.nn.avg_pool is deprecated. Please use tf.nn.avg_pool2d instead.
2021-06-17 19:15:19,616 [WARNING] tensorflow: From /opt/nvidia/third_party/keras/tensorflow_backend.py:187: The name tf.nn.avg_pool is deprecated. Please use tf.nn.avg_pool2d instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
2021-06-17 19:15:19,739 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
2021-06-17 19:15:19,739 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
2021-06-17 19:15:19,840 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
2021-06-17 19:15:19,841 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
2021-06-17 19:15:19,935 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
2021-06-17 19:15:19,937 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
2021-06-17 19:15:19,949 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
2021-06-17 19:15:19,950 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
2021-06-17 19:15:20,921 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
2021-06-17 19:15:21,013 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
2021-06-17 19:15:21,131 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
2021-06-17 19:15:21,132 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/optimizers.py:790: The name tf.train.Optimizer is deprecated. Please use tf.compat.v1.train.Optimizer instead.
2021-06-17 19:15:22,668 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/optimizers.py:790: The name tf.train.Optimizer is deprecated. Please use tf.compat.v1.train.Optimizer instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:3295: The name tf.log is deprecated. Please use tf.math.log instead.
2021-06-17 19:15:22,672 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:3295: The name tf.log is deprecated. Please use tf.math.log instead.
2021-06-17 19:15:22,715 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/optimizers.py:790: The name tf.train.Optimizer is deprecated. Please use tf.compat.v1.train.Optimizer instead.
2021-06-17 19:15:22,719 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:3295: The name tf.log is deprecated. Please use tf.math.log instead.
2021-06-17 19:15:22,825 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/optimizers.py:790: The name tf.train.Optimizer is deprecated. Please use tf.compat.v1.train.Optimizer instead.
2021-06-17 19:15:22,828 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:3295: The name tf.log is deprecated. Please use tf.math.log instead.
2021-06-17 19:15:22,834 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/optimizers.py:790: The name tf.train.Optimizer is deprecated. Please use tf.compat.v1.train.Optimizer instead.
2021-06-17 19:15:22,840 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:3295: The name tf.log is deprecated. Please use tf.math.log instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:986: The name tf.assign_add is deprecated. Please use tf.compat.v1.assign_add instead.
2021-06-17 19:15:23,891 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:986: The name tf.assign_add is deprecated. Please use tf.compat.v1.assign_add instead.
2021-06-17 19:15:23,935 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:986: The name tf.assign_add is deprecated. Please use tf.compat.v1.assign_add instead.
2021-06-17 19:15:24,013 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:986: The name tf.assign_add is deprecated. Please use tf.compat.v1.assign_add instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:973: The name tf.assign is deprecated. Please use tf.compat.v1.assign instead.
2021-06-17 19:15:24,147 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:973: The name tf.assign is deprecated. Please use tf.compat.v1.assign instead.
2021-06-17 19:15:24,188 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:973: The name tf.assign is deprecated. Please use tf.compat.v1.assign instead.
2021-06-17 19:15:24,268 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:973: The name tf.assign is deprecated. Please use tf.compat.v1.assign instead.
2021-06-17 19:15:24,735 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:986: The name tf.assign_add is deprecated. Please use tf.compat.v1.assign_add instead.
2021-06-17 19:15:25,070 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:973: The name tf.assign is deprecated. Please use tf.compat.v1.assign instead.
Layer (type) Output Shape Param # Connected to
Input (InputLayer) (None, 3, 544, 960) 0
conv1 (Conv2D) (None, 32, 544, 960) 864 Input[0][0]
conv1_bn (BatchNormalization) (None, 32, 544, 960) 128 conv1[0][0]
conv1_lrelu (LeakyReLU) (None, 32, 544, 960) 0 conv1_bn[0][0]
conv2 (Conv2D) (None, 64, 272, 480) 18432 conv1_lrelu[0][0]
conv2_bn (BatchNormalization) (None, 64, 272, 480) 256 conv2[0][0]
conv2_lrelu (LeakyReLU) (None, 64, 272, 480) 0 conv2_bn[0][0]
b1_conv1_1 (Conv2D) (None, 32, 272, 480) 2048 conv2_lrelu[0][0]
b1_conv1_1_bn (BatchNormalizati (None, 32, 272, 480) 128 b1_conv1_1[0][0]
b1_conv1_1_lrelu (LeakyReLU) (None, 32, 272, 480) 0 b1_conv1_1_bn[0][0]
b1_conv1_2 (Conv2D) (None, 64, 272, 480) 18432 b1_conv1_1_lrelu[0][0]
b1_conv1_2_bn (BatchNormalizati (None, 64, 272, 480) 256 b1_conv1_2[0][0]
b1_conv1_2_lrelu (LeakyReLU) (None, 64, 272, 480) 0 b1_conv1_2_bn[0][0]
b1_add1 (Add) (None, 64, 272, 480) 0 conv2_lrelu[0][0]
b1_conv1_2_lrelu[0][0]
conv3 (Conv2D) (None, 128, 136, 240 73728 b1_add1[0][0]
conv3_bn (BatchNormalization) (None, 128, 136, 240 512 conv3[0][0]
conv3_lrelu (LeakyReLU) (None, 128, 136, 240 0 conv3_bn[0][0]
b2_conv1_1 (Conv2D) (None, 64, 136, 240) 8192 conv3_lrelu[0][0]
b2_conv1_1_bn (BatchNormalizati (None, 64, 136, 240) 256 b2_conv1_1[0][0]
b2_conv1_1_lrelu (LeakyReLU) (None, 64, 136, 240) 0 b2_conv1_1_bn[0][0]
b2_conv1_2 (Conv2D) (None, 128, 136, 240 73728 b2_conv1_1_lrelu[0][0]
b2_conv1_2_bn (BatchNormalizati (None, 128, 136, 240 512 b2_conv1_2[0][0]
b2_conv1_2_lrelu (LeakyReLU) (None, 128, 136, 240 0 b2_conv1_2_bn[0][0]
b2_add1 (Add) (None, 128, 136, 240 0 conv3_lrelu[0][0]
b2_conv1_2_lrelu[0][0]
b2_conv2_1 (Conv2D) (None, 64, 136, 240) 8192 b2_add1[0][0]
b2_conv2_1_bn (BatchNormalizati (None, 64, 136, 240) 256 b2_conv2_1[0][0]
b2_conv2_1_lrelu (LeakyReLU) (None, 64, 136, 240) 0 b2_conv2_1_bn[0][0]
b2_conv2_2 (Conv2D) (None, 128, 136, 240 73728 b2_conv2_1_lrelu[0][0]
b2_conv2_2_bn (BatchNormalizati (None, 128, 136, 240 512 b2_conv2_2[0][0]
b2_conv2_2_lrelu (LeakyReLU) (None, 128, 136, 240 0 b2_conv2_2_bn[0][0]
b2_add2 (Add) (None, 128, 136, 240 0 b2_add1[0][0]
b2_conv2_2_lrelu[0][0]
conv4 (Conv2D) (None, 256, 68, 120) 294912 b2_add2[0][0]
conv4_bn (BatchNormalization) (None, 256, 68, 120) 1024 conv4[0][0]
conv4_lrelu (LeakyReLU) (None, 256, 68, 120) 0 conv4_bn[0][0]
b3_conv1_1 (Conv2D) (None, 128, 68, 120) 32768 conv4_lrelu[0][0]
b3_conv1_1_bn (BatchNormalizati (None, 128, 68, 120) 512 b3_conv1_1[0][0]
b3_conv1_1_lrelu (LeakyReLU) (None, 128, 68, 120) 0 b3_conv1_1_bn[0][0]
b3_conv1_2 (Conv2D) (None, 256, 68, 120) 294912 b3_conv1_1_lrelu[0][0]
b3_conv1_2_bn (BatchNormalizati (None, 256, 68, 120) 1024 b3_conv1_2[0][0]
b3_conv1_2_lrelu (LeakyReLU) (None, 256, 68, 120) 0 b3_conv1_2_bn[0][0]
b3_add1 (Add) (None, 256, 68, 120) 0 conv4_lrelu[0][0]
b3_conv1_2_lrelu[0][0]
b3_conv2_1 (Conv2D) (None, 128, 68, 120) 32768 b3_add1[0][0]
b3_conv2_1_bn (BatchNormalizati (None, 128, 68, 120) 512 b3_conv2_1[0][0]
b3_conv2_1_lrelu (LeakyReLU) (None, 128, 68, 120) 0 b3_conv2_1_bn[0][0]
b3_conv2_2 (Conv2D) (None, 256, 68, 120) 294912 b3_conv2_1_lrelu[0][0]
b3_conv2_2_bn (BatchNormalizati (None, 256, 68, 120) 1024 b3_conv2_2[0][0]
b3_conv2_2_lrelu (LeakyReLU) (None, 256, 68, 120) 0 b3_conv2_2_bn[0][0]
b3_add2 (Add) (None, 256, 68, 120) 0 b3_add1[0][0]
b3_conv2_2_lrelu[0][0]
b3_conv3_1 (Conv2D) (None, 128, 68, 120) 32768 b3_add2[0][0]
b3_conv3_1_bn (BatchNormalizati (None, 128, 68, 120) 512 b3_conv3_1[0][0]
b3_conv3_1_lrelu (LeakyReLU) (None, 128, 68, 120) 0 b3_conv3_1_bn[0][0]
b3_conv3_2 (Conv2D) (None, 256, 68, 120) 294912 b3_conv3_1_lrelu[0][0]
b3_conv3_2_bn (BatchNormalizati (None, 256, 68, 120) 1024 b3_conv3_2[0][0]
b3_conv3_2_lrelu (LeakyReLU) (None, 256, 68, 120) 0 b3_conv3_2_bn[0][0]
b3_add3 (Add) (None, 256, 68, 120) 0 b3_add2[0][0]
b3_conv3_2_lrelu[0][0]
b3_conv4_1 (Conv2D) (None, 128, 68, 120) 32768 b3_add3[0][0]
b3_conv4_1_bn (BatchNormalizati (None, 128, 68, 120) 512 b3_conv4_1[0][0]
b3_conv4_1_lrelu (LeakyReLU) (None, 128, 68, 120) 0 b3_conv4_1_bn[0][0]
b3_conv4_2 (Conv2D) (None, 256, 68, 120) 294912 b3_conv4_1_lrelu[0][0]
b3_conv4_2_bn (BatchNormalizati (None, 256, 68, 120) 1024 b3_conv4_2[0][0]
b3_conv4_2_lrelu (LeakyReLU) (None, 256, 68, 120) 0 b3_conv4_2_bn[0][0]
b3_add4 (Add) (None, 256, 68, 120) 0 b3_add3[0][0]
b3_conv4_2_lrelu[0][0]
b3_conv5_1 (Conv2D) (None, 128, 68, 120) 32768 b3_add4[0][0]
b3_conv5_1_bn (BatchNormalizati (None, 128, 68, 120) 512 b3_conv5_1[0][0]
b3_conv5_1_lrelu (LeakyReLU) (None, 128, 68, 120) 0 b3_conv5_1_bn[0][0]
b3_conv5_2 (Conv2D) (None, 256, 68, 120) 294912 b3_conv5_1_lrelu[0][0]
b3_conv5_2_bn (BatchNormalizati (None, 256, 68, 120) 1024 b3_conv5_2[0][0]
b3_conv5_2_lrelu (LeakyReLU) (None, 256, 68, 120) 0 b3_conv5_2_bn[0][0]
b3_add5 (Add) (None, 256, 68, 120) 0 b3_add4[0][0]
b3_conv5_2_lrelu[0][0]
b3_conv6_1 (Conv2D) (None, 128, 68, 120) 32768 b3_add5[0][0]
b3_conv6_1_bn (BatchNormalizati (None, 128, 68, 120) 512 b3_conv6_1[0][0]
b3_conv6_1_lrelu (LeakyReLU) (None, 128, 68, 120) 0 b3_conv6_1_bn[0][0]
b3_conv6_2 (Conv2D) (None, 256, 68, 120) 294912 b3_conv6_1_lrelu[0][0]
b3_conv6_2_bn (BatchNormalizati (None, 256, 68, 120) 1024 b3_conv6_2[0][0]
b3_conv6_2_lrelu (LeakyReLU) (None, 256, 68, 120) 0 b3_conv6_2_bn[0][0]
b3_add6 (Add) (None, 256, 68, 120) 0 b3_add5[0][0]
b3_conv6_2_lrelu[0][0]
b3_conv7_1 (Conv2D) (None, 128, 68, 120) 32768 b3_add6[0][0]
b3_conv7_1_bn (BatchNormalizati (None, 128, 68, 120) 512 b3_conv7_1[0][0]
b3_conv7_1_lrelu (LeakyReLU) (None, 128, 68, 120) 0 b3_conv7_1_bn[0][0]
b3_conv7_2 (Conv2D) (None, 256, 68, 120) 294912 b3_conv7_1_lrelu[0][0]
b3_conv7_2_bn (BatchNormalizati (None, 256, 68, 120) 1024 b3_conv7_2[0][0]
b3_conv7_2_lrelu (LeakyReLU) (None, 256, 68, 120) 0 b3_conv7_2_bn[0][0]
b3_add7 (Add) (None, 256, 68, 120) 0 b3_add6[0][0]
b3_conv7_2_lrelu[0][0]
b3_conv8_1 (Conv2D) (None, 128, 68, 120) 32768 b3_add7[0][0]
b3_conv8_1_bn (BatchNormalizati (None, 128, 68, 120) 512 b3_conv8_1[0][0]
b3_conv8_1_lrelu (LeakyReLU) (None, 128, 68, 120) 0 b3_conv8_1_bn[0][0]
b3_conv8_2 (Conv2D) (None, 256, 68, 120) 294912 b3_conv8_1_lrelu[0][0]
b3_conv8_2_bn (BatchNormalizati (None, 256, 68, 120) 1024 b3_conv8_2[0][0]
b3_conv8_2_lrelu (LeakyReLU) (None, 256, 68, 120) 0 b3_conv8_2_bn[0][0]
b3_add8 (Add) (None, 256, 68, 120) 0 b3_add7[0][0]
b3_conv8_2_lrelu[0][0]
conv5 (Conv2D) (None, 512, 34, 60) 1179648 b3_add8[0][0]
conv5_bn (BatchNormalization) (None, 512, 34, 60) 2048 conv5[0][0]
conv5_lrelu (LeakyReLU) (None, 512, 34, 60) 0 conv5_bn[0][0]
b4_conv1_1 (Conv2D) (None, 256, 34, 60) 131072 conv5_lrelu[0][0]
b4_conv1_1_bn (BatchNormalizati (None, 256, 34, 60) 1024 b4_conv1_1[0][0]
b4_conv1_1_lrelu (LeakyReLU) (None, 256, 34, 60) 0 b4_conv1_1_bn[0][0]
b4_conv1_2 (Conv2D) (None, 512, 34, 60) 1179648 b4_conv1_1_lrelu[0][0]
b4_conv1_2_bn (BatchNormalizati (None, 512, 34, 60) 2048 b4_conv1_2[0][0]
b4_conv1_2_lrelu (LeakyReLU) (None, 512, 34, 60) 0 b4_conv1_2_bn[0][0]
b4_add1 (Add) (None, 512, 34, 60) 0 conv5_lrelu[0][0]
b4_conv1_2_lrelu[0][0]
b4_conv2_1 (Conv2D) (None, 256, 34, 60) 131072 b4_add1[0][0]
b4_conv2_1_bn (BatchNormalizati (None, 256, 34, 60) 1024 b4_conv2_1[0][0]
b4_conv2_1_lrelu (LeakyReLU) (None, 256, 34, 60) 0 b4_conv2_1_bn[0][0]
b4_conv2_2 (Conv2D) (None, 512, 34, 60) 1179648 b4_conv2_1_lrelu[0][0]
b4_conv2_2_bn (BatchNormalizati (None, 512, 34, 60) 2048 b4_conv2_2[0][0]
b4_conv2_2_lrelu (LeakyReLU) (None, 512, 34, 60) 0 b4_conv2_2_bn[0][0]
b4_add2 (Add) (None, 512, 34, 60) 0 b4_add1[0][0]
b4_conv2_2_lrelu[0][0]
b4_conv3_1 (Conv2D) (None, 256, 34, 60) 131072 b4_add2[0][0]
b4_conv3_1_bn (BatchNormalizati (None, 256, 34, 60) 1024 b4_conv3_1[0][0]
b4_conv3_1_lrelu (LeakyReLU) (None, 256, 34, 60) 0 b4_conv3_1_bn[0][0]
b4_conv3_2 (Conv2D) (None, 512, 34, 60) 1179648 b4_conv3_1_lrelu[0][0]
b4_conv3_2_bn (BatchNormalizati (None, 512, 34, 60) 2048 b4_conv3_2[0][0]
b4_conv3_2_lrelu (LeakyReLU) (None, 512, 34, 60) 0 b4_conv3_2_bn[0][0]
b4_add3 (Add) (None, 512, 34, 60) 0 b4_add2[0][0]
b4_conv3_2_lrelu[0][0]
b4_conv4_1 (Conv2D) (None, 256, 34, 60) 131072 b4_add3[0][0]
b4_conv4_1_bn (BatchNormalizati (None, 256, 34, 60) 1024 b4_conv4_1[0][0]
b4_conv4_1_lrelu (LeakyReLU) (None, 256, 34, 60) 0 b4_conv4_1_bn[0][0]
b4_conv4_2 (Conv2D) (None, 512, 34, 60) 1179648 b4_conv4_1_lrelu[0][0]
b4_conv4_2_bn (BatchNormalizati (None, 512, 34, 60) 2048 b4_conv4_2[0][0]
b4_conv4_2_lrelu (LeakyReLU) (None, 512, 34, 60) 0 b4_conv4_2_bn[0][0]
b4_add4 (Add) (None, 512, 34, 60) 0 b4_add3[0][0]
b4_conv4_2_lrelu[0][0]
b4_conv5_1 (Conv2D) (None, 256, 34, 60) 131072 b4_add4[0][0]
b4_conv5_1_bn (BatchNormalizati (None, 256, 34, 60) 1024 b4_conv5_1[0][0]
b4_conv5_1_lrelu (LeakyReLU) (None, 256, 34, 60) 0 b4_conv5_1_bn[0][0]
b4_conv5_2 (Conv2D) (None, 512, 34, 60) 1179648 b4_conv5_1_lrelu[0][0]
b4_conv5_2_bn (BatchNormalizati (None, 512, 34, 60) 2048 b4_conv5_2[0][0]
b4_conv5_2_lrelu (LeakyReLU) (None, 512, 34, 60) 0 b4_conv5_2_bn[0][0]
b4_add5 (Add) (None, 512, 34, 60) 0 b4_add4[0][0]
b4_conv5_2_lrelu[0][0]
b4_conv6_1 (Conv2D) (None, 256, 34, 60) 131072 b4_add5[0][0]
b4_conv6_1_bn (BatchNormalizati (None, 256, 34, 60) 1024 b4_conv6_1[0][0]
b4_conv6_1_lrelu (LeakyReLU) (None, 256, 34, 60) 0 b4_conv6_1_bn[0][0]
b4_conv6_2 (Conv2D) (None, 512, 34, 60) 1179648 b4_conv6_1_lrelu[0][0]
b4_conv6_2_bn (BatchNormalizati (None, 512, 34, 60) 2048 b4_conv6_2[0][0]
b4_conv6_2_lrelu (LeakyReLU) (None, 512, 34, 60) 0 b4_conv6_2_bn[0][0]
b4_add6 (Add) (None, 512, 34, 60) 0 b4_add5[0][0]
b4_conv6_2_lrelu[0][0]
b4_conv7_1 (Conv2D) (None, 256, 34, 60) 131072 b4_add6[0][0]
b4_conv7_1_bn (BatchNormalizati (None, 256, 34, 60) 1024 b4_conv7_1[0][0]
b4_conv7_1_lrelu (LeakyReLU) (None, 256, 34, 60) 0 b4_conv7_1_bn[0][0]
b4_conv7_2 (Conv2D) (None, 512, 34, 60) 1179648 b4_conv7_1_lrelu[0][0]
b4_conv7_2_bn (BatchNormalizati (None, 512, 34, 60) 2048 b4_conv7_2[0][0]
b4_conv7_2_lrelu (LeakyReLU) (None, 512, 34, 60) 0 b4_conv7_2_bn[0][0]
b4_add7 (Add) (None, 512, 34, 60) 0 b4_add6[0][0]
b4_conv7_2_lrelu[0][0]
b4_conv8_1 (Conv2D) (None, 256, 34, 60) 131072 b4_add7[0][0]
b4_conv8_1_bn (BatchNormalizati (None, 256, 34, 60) 1024 b4_conv8_1[0][0]
b4_conv8_1_lrelu (LeakyReLU) (None, 256, 34, 60) 0 b4_conv8_1_bn[0][0]
b4_conv8_2 (Conv2D) (None, 512, 34, 60) 1179648 b4_conv8_1_lrelu[0][0]
b4_conv8_2_bn (BatchNormalizati (None, 512, 34, 60) 2048 b4_conv8_2[0][0]
b4_conv8_2_lrelu (LeakyReLU) (None, 512, 34, 60) 0 b4_conv8_2_bn[0][0]
b4_add8 (Add) (None, 512, 34, 60) 0 b4_add7[0][0]
b4_conv8_2_lrelu[0][0]
conv6 (Conv2D) (None, 1024, 17, 30) 4718592 b4_add8[0][0]
conv6_bn (BatchNormalization) (None, 1024, 17, 30) 4096 conv6[0][0]
conv6_lrelu (LeakyReLU) (None, 1024, 17, 30) 0 conv6_bn[0][0]
b5_conv1_1 (Conv2D) (None, 512, 17, 30) 524288 conv6_lrelu[0][0]
b5_conv1_1_bn (BatchNormalizati (None, 512, 17, 30) 2048 b5_conv1_1[0][0]
b5_conv1_1_lrelu (LeakyReLU) (None, 512, 17, 30) 0 b5_conv1_1_bn[0][0]
b5_conv1_2 (Conv2D) (None, 1024, 17, 30) 4718592 b5_conv1_1_lrelu[0][0]
b5_conv1_2_bn (BatchNormalizati (None, 1024, 17, 30) 4096 b5_conv1_2[0][0]
b5_conv1_2_lrelu (LeakyReLU) (None, 1024, 17, 30) 0 b5_conv1_2_bn[0][0]
b5_add1 (Add) (None, 1024, 17, 30) 0 conv6_lrelu[0][0]
b5_conv1_2_lrelu[0][0]
b5_conv2_1 (Conv2D) (None, 512, 17, 30) 524288 b5_add1[0][0]
b5_conv2_1_bn (BatchNormalizati (None, 512, 17, 30) 2048 b5_conv2_1[0][0]
b5_conv2_1_lrelu (LeakyReLU) (None, 512, 17, 30) 0 b5_conv2_1_bn[0][0]
b5_conv2_2 (Conv2D) (None, 1024, 17, 30) 4718592 b5_conv2_1_lrelu[0][0]
b5_conv2_2_bn (BatchNormalizati (None, 1024, 17, 30) 4096 b5_conv2_2[0][0]
b5_conv2_2_lrelu (LeakyReLU) (None, 1024, 17, 30) 0 b5_conv2_2_bn[0][0]
b5_add2 (Add) (None, 1024, 17, 30) 0 b5_add1[0][0]
b5_conv2_2_lrelu[0][0]
b5_conv3_1 (Conv2D) (None, 512, 17, 30) 524288 b5_add2[0][0]
b5_conv3_1_bn (BatchNormalizati (None, 512, 17, 30) 2048 b5_conv3_1[0][0]
b5_conv3_1_lrelu (LeakyReLU) (None, 512, 17, 30) 0 b5_conv3_1_bn[0][0]
b5_conv3_2 (Conv2D) (None, 1024, 17, 30) 4718592 b5_conv3_1_lrelu[0][0]
b5_conv3_2_bn (BatchNormalizati (None, 1024, 17, 30) 4096 b5_conv3_2[0][0]
b5_conv3_2_lrelu (LeakyReLU) (None, 1024, 17, 30) 0 b5_conv3_2_bn[0][0]
b5_add3 (Add) (None, 1024, 17, 30) 0 b5_add2[0][0]
b5_conv3_2_lrelu[0][0]
b5_conv4_1 (Conv2D) (None, 512, 17, 30) 524288 b5_add3[0][0]
b5_conv4_1_bn (BatchNormalizati (None, 512, 17, 30) 2048 b5_conv4_1[0][0]
b5_conv4_1_lrelu (LeakyReLU) (None, 512, 17, 30) 0 b5_conv4_1_bn[0][0]
b5_conv4_2 (Conv2D) (None, 1024, 17, 30) 4718592 b5_conv4_1_lrelu[0][0]
b5_conv4_2_bn (BatchNormalizati (None, 1024, 17, 30) 4096 b5_conv4_2[0][0]
b5_conv4_2_lrelu (LeakyReLU) (None, 1024, 17, 30) 0 b5_conv4_2_bn[0][0]
b5_add4 (Add) (None, 1024, 17, 30) 0 b5_add3[0][0]
b5_conv4_2_lrelu[0][0]
yolo_spp_pool_1 (MaxPooling2D) (None, 1024, 17, 30) 0 b5_add4[0][0]
yolo_spp_pool_2 (MaxPooling2D) (None, 1024, 17, 30) 0 b5_add4[0][0]
yolo_spp_pool_3 (MaxPooling2D) (None, 1024, 17, 30) 0 b5_add4[0][0]
yolo_spp_concat (Concatenate) (None, 4096, 17, 30) 0 yolo_spp_pool_1[0][0]
yolo_spp_pool_2[0][0]
yolo_spp_pool_3[0][0]
b5_add4[0][0]
yolo_spp_conv (Conv2D) (None, 512, 17, 30) 2097152 yolo_spp_concat[0][0]
yolo_spp_conv_bn (BatchNormaliz (None, 512, 17, 30) 2048 yolo_spp_conv[0][0]
yolo_spp_conv_lrelu (LeakyReLU) (None, 512, 17, 30) 0 yolo_spp_conv_bn[0][0]
yolo_conv1_1 (Conv2D) (None, 512, 17, 30) 262144 yolo_spp_conv_lrelu[0][0]
yolo_conv1_1_bn (BatchNormaliza (None, 512, 17, 30) 2048 yolo_conv1_1[0][0]
yolo_conv1_1_lrelu (LeakyReLU) (None, 512, 17, 30) 0 yolo_conv1_1_bn[0][0]
yolo_conv1_2 (Conv2D) (None, 1024, 17, 30) 4718592 yolo_conv1_1_lrelu[0][0]
yolo_conv1_2_bn (BatchNormaliza (None, 1024, 17, 30) 4096 yolo_conv1_2[0][0]
yolo_conv1_2_lrelu (LeakyReLU) (None, 1024, 17, 30) 0 yolo_conv1_2_bn[0][0]
yolo_conv1_3 (Conv2D) (None, 512, 17, 30) 524288 yolo_conv1_2_lrelu[0][0]
yolo_conv1_3_bn (BatchNormaliza (None, 512, 17, 30) 2048 yolo_conv1_3[0][0]
yolo_conv1_3_lrelu (LeakyReLU) (None, 512, 17, 30) 0 yolo_conv1_3_bn[0][0]
yolo_conv1_4 (Conv2D) (None, 1024, 17, 30) 4718592 yolo_conv1_3_lrelu[0][0]
yolo_conv1_4_bn (BatchNormaliza (None, 1024, 17, 30) 4096 yolo_conv1_4[0][0]
yolo_conv1_4_lrelu (LeakyReLU) (None, 1024, 17, 30) 0 yolo_conv1_4_bn[0][0]
yolo_conv1_5 (Conv2D) (None, 512, 17, 30) 524288 yolo_conv1_4_lrelu[0][0]
yolo_conv1_5_bn (BatchNormaliza (None, 512, 17, 30) 2048 yolo_conv1_5[0][0]
yolo_conv1_5_lrelu (LeakyReLU) (None, 512, 17, 30) 0 yolo_conv1_5_bn[0][0]
yolo_conv2 (Conv2D) (None, 256, 17, 30) 131072 yolo_conv1_5_lrelu[0][0]
yolo_conv2_bn (BatchNormalizati (None, 256, 17, 30) 1024 yolo_conv2[0][0]
yolo_conv2_lrelu (LeakyReLU) (None, 256, 17, 30) 0 yolo_conv2_bn[0][0]
upsample0 (UpSampling2D) (None, 256, 34, 60) 0 yolo_conv2_lrelu[0][0]
concatenate_3 (Concatenate) (None, 768, 34, 60) 0 upsample0[0][0]
b4_add7[0][0]
yolo_conv3_1 (Conv2D) (None, 256, 34, 60) 196608 concatenate_3[0][0]
yolo_conv3_1_bn (BatchNormaliza (None, 256, 34, 60) 1024 yolo_conv3_1[0][0]
yolo_conv3_1_lrelu (LeakyReLU) (None, 256, 34, 60) 0 yolo_conv3_1_bn[0][0]
yolo_conv3_2 (Conv2D) (None, 512, 34, 60) 1179648 yolo_conv3_1_lrelu[0][0]
yolo_conv3_2_bn (BatchNormaliza (None, 512, 34, 60) 2048 yolo_conv3_2[0][0]
yolo_conv3_2_lrelu (LeakyReLU) (None, 512, 34, 60) 0 yolo_conv3_2_bn[0][0]
yolo_conv3_3 (Conv2D) (None, 256, 34, 60) 131072 yolo_conv3_2_lrelu[0][0]
yolo_conv3_3_bn (BatchNormaliza (None, 256, 34, 60) 1024 yolo_conv3_3[0][0]
yolo_conv3_3_lrelu (LeakyReLU) (None, 256, 34, 60) 0 yolo_conv3_3_bn[0][0]
yolo_conv3_4 (Conv2D) (None, 512, 34, 60) 1179648 yolo_conv3_3_lrelu[0][0]
yolo_conv3_4_bn (BatchNormaliza (None, 512, 34, 60) 2048 yolo_conv3_4[0][0]
yolo_conv3_4_lrelu (LeakyReLU) (None, 512, 34, 60) 0 yolo_conv3_4_bn[0][0]
yolo_conv3_5 (Conv2D) (None, 256, 34, 60) 131072 yolo_conv3_4_lrelu[0][0]
yolo_conv3_5_bn (BatchNormaliza (None, 256, 34, 60) 1024 yolo_conv3_5[0][0]
yolo_conv3_5_lrelu (LeakyReLU) (None, 256, 34, 60) 0 yolo_conv3_5_bn[0][0]
yolo_conv4 (Conv2D) (None, 128, 34, 60) 32768 yolo_conv3_5_lrelu[0][0]
yolo_conv4_bn (BatchNormalizati (None, 128, 34, 60) 512 yolo_conv4[0][0]
yolo_conv4_lrelu (LeakyReLU) (None, 128, 34, 60) 0 yolo_conv4_bn[0][0]
upsample1 (UpSampling2D) (None, 128, 68, 120) 0 yolo_conv4_lrelu[0][0]
concatenate_4 (Concatenate) (None, 384, 68, 120) 0 upsample1[0][0]
b3_add7[0][0]
yolo_conv5_1 (Conv2D) (None, 128, 68, 120) 49152 concatenate_4[0][0]
yolo_conv5_1_bn (BatchNormaliza (None, 128, 68, 120) 512 yolo_conv5_1[0][0]
yolo_conv5_1_lrelu (LeakyReLU) (None, 128, 68, 120) 0 yolo_conv5_1_bn[0][0]
yolo_conv5_2 (Conv2D) (None, 256, 68, 120) 294912 yolo_conv5_1_lrelu[0][0]
yolo_conv5_2_bn (BatchNormaliza (None, 256, 68, 120) 1024 yolo_conv5_2[0][0]
yolo_conv5_2_lrelu (LeakyReLU) (None, 256, 68, 120) 0 yolo_conv5_2_bn[0][0]
yolo_conv5_3 (Conv2D) (None, 128, 68, 120) 32768 yolo_conv5_2_lrelu[0][0]
yolo_conv5_3_bn (BatchNormaliza (None, 128, 68, 120) 512 yolo_conv5_3[0][0]
yolo_conv5_3_lrelu (LeakyReLU) (None, 128, 68, 120) 0 yolo_conv5_3_bn[0][0]
yolo_conv5_4 (Conv2D) (None, 256, 68, 120) 294912 yolo_conv5_3_lrelu[0][0]
yolo_conv5_4_bn (BatchNormaliza (None, 256, 68, 120) 1024 yolo_conv5_4[0][0]
yolo_conv5_4_lrelu (LeakyReLU) (None, 256, 68, 120) 0 yolo_conv5_4_bn[0][0]
yolo_conv5_5 (Conv2D) (None, 128, 68, 120) 32768 yolo_conv5_4_lrelu[0][0]
yolo_conv5_5_bn (BatchNormaliza (None, 128, 68, 120) 512 yolo_conv5_5[0][0]
yolo_conv5_5_lrelu (LeakyReLU) (None, 128, 68, 120) 0 yolo_conv5_5_bn[0][0]
yolo_conv1_6 (Conv2D) (None, 1024, 17, 30) 4718592 yolo_conv1_5_lrelu[0][0]
yolo_conv3_6 (Conv2D) (None, 512, 34, 60) 1179648 yolo_conv3_5_lrelu[0][0]
yolo_conv5_6 (Conv2D) (None, 256, 68, 120) 294912 yolo_conv5_5_lrelu[0][0]
yolo_conv1_6_bn (BatchNormaliza (None, 1024, 17, 30) 4096 yolo_conv1_6[0][0]
yolo_conv3_6_bn (BatchNormaliza (None, 512, 34, 60) 2048 yolo_conv3_6[0][0]
yolo_conv5_6_bn (BatchNormaliza (None, 256, 68, 120) 1024 yolo_conv5_6[0][0]
yolo_conv1_6_lrelu (LeakyReLU) (None, 1024, 17, 30) 0 yolo_conv1_6_bn[0][0]
yolo_conv3_6_lrelu (LeakyReLU) (None, 512, 34, 60) 0 yolo_conv3_6_bn[0][0]
yolo_conv5_6_lrelu (LeakyReLU) (None, 256, 68, 120) 0 yolo_conv5_6_bn[0][0]
conv_big_object (Conv2D) (None, 18, 17, 30) 18450 yolo_conv1_6_lrelu[0][0]
conv_mid_object (Conv2D) (None, 18, 34, 60) 9234 yolo_conv3_6_lrelu[0][0]
conv_sm_object (Conv2D) (None, 18, 68, 120) 4626 yolo_conv5_6_lrelu[0][0]
bg_permute (Permute) (None, 17, 30, 18) 0 conv_big_object[0][0]
md_permute (Permute) (None, 34, 60, 18) 0 conv_mid_object[0][0]
sm_permute (Permute) (None, 68, 120, 18) 0 conv_sm_object[0][0]
bg_reshape (Reshape) (None, 1530, 6) 0 bg_permute[0][0]
md_reshape (Reshape) (None, 6120, 6) 0 md_permute[0][0]
sm_reshape (Reshape) (None, 24480, 6) 0 sm_permute[0][0]
bg_anchor (YOLOAnchorBox) (None, 1530, 6) 0 conv_big_object[0][0]
bg_bbox_processor (BBoxPostProc (None, 1530, 6) 0 bg_reshape[0][0]
md_anchor (YOLOAnchorBox) (None, 6120, 6) 0 conv_mid_object[0][0]
md_bbox_processor (BBoxPostProc (None, 6120, 6) 0 md_reshape[0][0]
sm_anchor (YOLOAnchorBox) (None, 24480, 6) 0 conv_sm_object[0][0]
sm_bbox_processor (BBoxPostProc (None, 24480, 6) 0 sm_reshape[0][0]
encoded_bg (Concatenate) (None, 1530, 12) 0 bg_anchor[0][0]
bg_bbox_processor[0][0]
encoded_md (Concatenate) (None, 6120, 12) 0 md_anchor[0][0]
md_bbox_processor[0][0]
encoded_sm (Concatenate) (None, 24480, 12) 0 sm_anchor[0][0]
sm_bbox_processor[0][0]
encoded_detections (Concatenate (None, 32130, 12) 0 encoded_bg[0][0]
encoded_md[0][0]
encoded_sm[0][0]
Total params: 63,413,398
Trainable params: 63,359,766
Non-trainable params: 53,632
2021-06-17 19:17:37,591 [INFO] main: Number of images in the training dataset: 9356
Epoch 1/100
e7ed2085a8ec:450:984 [0] NCCL INFO Bootstrap : Using [0]lo:127.0.0.1<0> [1]eth0:172.17.0.10<0>
e7ed2085a8ec:450:984 [0] NCCL INFO NET/Plugin : No plugin found (libnccl-net.so), using internal implementation
e7ed2085a8ec:450:984 [0] NCCL INFO NET/IB : No device found.
e7ed2085a8ec:450:984 [0] NCCL INFO NET/Socket : Using [0]lo:127.0.0.1<0> [1]eth0:172.17.0.10<0>
e7ed2085a8ec:450:984 [0] NCCL INFO Using network Socket
NCCL version 2.7.8+cuda11.1
e7ed2085a8ec:451:978 [1] NCCL INFO Bootstrap : Using [0]lo:127.0.0.1<0> [1]eth0:172.17.0.10<0>
e7ed2085a8ec:451:978 [1] NCCL INFO NET/Plugin : No plugin found (libnccl-net.so), using internal implementation
e7ed2085a8ec:453:981 [3] NCCL INFO Bootstrap : Using [0]lo:127.0.0.1<0> [1]eth0:172.17.0.10<0>
e7ed2085a8ec:452:985 [2] NCCL INFO Bootstrap : Using [0]lo:127.0.0.1<0> [1]eth0:172.17.0.10<0>
e7ed2085a8ec:453:981 [3] NCCL INFO NET/Plugin : No plugin found (libnccl-net.so), using internal implementation
e7ed2085a8ec:452:985 [2] NCCL INFO NET/Plugin : No plugin found (libnccl-net.so), using internal implementation
e7ed2085a8ec:451:978 [1] NCCL INFO NET/IB : No device found.
e7ed2085a8ec:453:981 [3] NCCL INFO NET/IB : No device found.
e7ed2085a8ec:452:985 [2] NCCL INFO NET/IB : No device found.
e7ed2085a8ec:451:978 [1] NCCL INFO NET/Socket : Using [0]lo:127.0.0.1<0> [1]eth0:172.17.0.10<0>
e7ed2085a8ec:451:978 [1] NCCL INFO Using network Socket
e7ed2085a8ec:452:985 [2] NCCL INFO NET/Socket : Using [0]lo:127.0.0.1<0> [1]eth0:172.17.0.10<0>
e7ed2085a8ec:452:985 [2] NCCL INFO Using network Socket
e7ed2085a8ec:453:981 [3] NCCL INFO NET/Socket : Using [0]lo:127.0.0.1<0> [1]eth0:172.17.0.10<0>
e7ed2085a8ec:453:981 [3] NCCL INFO Using network Socket
e7ed2085a8ec:450:984 [0] NCCL INFO Channel 00/02 : 0 1 2 3
e7ed2085a8ec:450:984 [0] NCCL INFO Channel 01/02 : 0 1 2 3
e7ed2085a8ec:450:984 [0] NCCL INFO threadThresholds 8/8/64 | 32/8/64 | 8/8/64
e7ed2085a8ec:450:984 [0] NCCL INFO Trees [0] 1/-1/-1->0->-1|-1->0->1/-1/-1 [1] 1/-1/-1->0->-1|-1->0->1/-1/-1
e7ed2085a8ec:451:978 [1] NCCL INFO threadThresholds 8/8/64 | 32/8/64 | 8/8/64
e7ed2085a8ec:451:978 [1] NCCL INFO Trees [0] 2/-1/-1->1->0|0->1->2/-1/-1 [1] 2/-1/-1->1->0|0->1->2/-1/-1
e7ed2085a8ec:451:978 [1] NCCL INFO Setting affinity for GPU 1 to 7fffffff,ffffffff,00000000,00000000,ffffffff,ffffffff,00000000,00000000
e7ed2085a8ec:452:985 [2] NCCL INFO threadThresholds 8/8/64 | 32/8/64 | 8/8/64
e7ed2085a8ec:452:985 [2] NCCL INFO Trees [0] 3/-1/-1->2->1|1->2->3/-1/-1 [1] 3/-1/-1->2->1|1->2->3/-1/-1
e7ed2085a8ec:452:985 [2] NCCL INFO Setting affinity for GPU 2 to 7fffffff,ffffffff,00000000,00000000,ffffffff,ffffffff,00000000,00000000
e7ed2085a8ec:453:981 [3] NCCL INFO threadThresholds 8/8/64 | 32/8/64 | 8/8/64
e7ed2085a8ec:453:981 [3] NCCL INFO Trees [0] -1/-1/-1->3->2|2->3->-1/-1/-1 [1] -1/-1/-1->3->2|2->3->-1/-1/-1
e7ed2085a8ec:453:981 [3] NCCL INFO Setting affinity for GPU 3 to 7fffffff,ffffffff,00000000,00000000,ffffffff,ffffffff,00000000,00000000
e7ed2085a8ec:450:984 [0] NCCL INFO Setting affinity for GPU 0 to ffffffff,ffffffff,00000000,00000000,ffffffff,ffffffff
e7ed2085a8ec:453:981 [3] NCCL INFO Channel 00 : 3[c3000] → 0[27000] via P2P/IPC
e7ed2085a8ec:451:978 [1] NCCL INFO Channel 00 : 1[83000] → 2[a3000] via P2P/IPC
e7ed2085a8ec:452:985 [2] NCCL INFO Channel 00 : 2[a3000] → 3[c3000] via P2P/IPC
e7ed2085a8ec:450:984 [0] NCCL INFO Channel 00 : 0[27000] → 1[83000] via P2P/IPC
e7ed2085a8ec:453:981 [3] NCCL INFO Channel 00 : 3[c3000] → 2[a3000] via P2P/IPC
e7ed2085a8ec:451:978 [1] NCCL INFO Channel 00 : 1[83000] → 0[27000] via P2P/IPC
e7ed2085a8ec:452:985 [2] NCCL INFO Channel 00 : 2[a3000] → 1[83000] via P2P/IPC
e7ed2085a8ec:453:981 [3] NCCL INFO Channel 01 : 3[c3000] → 0[27000] via P2P/IPC
e7ed2085a8ec:450:984 [0] NCCL INFO Channel 01 : 0[27000] → 1[83000] via P2P/IPC
e7ed2085a8ec:451:978 [1] NCCL INFO Channel 01 : 1[83000] → 2[a3000] via P2P/IPC
e7ed2085a8ec:452:985 [2] NCCL INFO Channel 01 : 2[a3000] → 3[c3000] via P2P/IPC
e7ed2085a8ec:453:981 [3] NCCL INFO Channel 01 : 3[c3000] → 2[a3000] via P2P/IPC
e7ed2085a8ec:451:978 [1] NCCL INFO Channel 01 : 1[83000] → 0[27000] via P2P/IPC
e7ed2085a8ec:453:981 [3] NCCL INFO 2 coll channels, 2 p2p channels, 2 p2p channels per peer
e7ed2085a8ec:453:981 [3] NCCL INFO comm 0x7f5c10430aa0 rank 3 nranks 4 cudaDev 3 busId c3000 - Init COMPLETE
e7ed2085a8ec:450:984 [0] NCCL INFO 2 coll channels, 2 p2p channels, 2 p2p channels per peer
e7ed2085a8ec:452:985 [2] NCCL INFO Channel 01 : 2[a3000] → 1[83000] via P2P/IPC
e7ed2085a8ec:450:984 [0] NCCL INFO comm 0x7f37b7099cf0 rank 0 nranks 4 cudaDev 0 busId 27000 - Init COMPLETE
e7ed2085a8ec:451:978 [1] NCCL INFO 2 coll channels, 2 p2p channels, 2 p2p channels per peer
e7ed2085a8ec:452:985 [2] NCCL INFO 2 coll channels, 2 p2p channels, 2 p2p channels per peer
e7ed2085a8ec:451:978 [1] NCCL INFO comm 0x7fb884430d10 rank 1 nranks 4 cudaDev 1 busId 83000 - Init COMPLETE
e7ed2085a8ec:452:985 [2] NCCL INFO comm 0x7f8127098aa0 rank 2 nranks 4 cudaDev 2 busId a3000 - Init COMPLETE
e7ed2085a8ec:450:984 [0] NCCL INFO Launch mode Parallel
It has got stuck here…
