• Hardware NVIDIA A5000x8
• Network Type (LPRnet)
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here) format_version: 2.0 / toolkit_version: 3.22.05 / v3.21.11-py3
• Training spec file(If have, please share here)
yolo_v4_tiny_train_kitti.txt (2.0 KB)
yolo_v4_tiny_tfrecords_kitti_val.txt (296 Bytes)
I want to train a yolov4 tiny. My dataset image size is 1920x1088 (all the same size).
I need some advice to fix the below issue.
When I start the training process, the process crashes, below is the output:
39/109 [=========>…] - ETA: 6:01 - loss: 21861.4963INFO: 2 root error(s) found.
(0) Invalid argument: Input to reshape is a tensor with 2976 values, but the requested shape has 2928
[[{{node bg_anchor_1/Reshape}}]]
[[cond_62/cond/SliceReplace/ListDiff/Switch/_4049]]
(1) Invalid argument: Input to reshape is a tensor with 2976 values, but the requested shape has 2928
0 successful operations.
0 derived errors ignored.
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py”, line 145, in
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/utils.py”, line 707, in return_func
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/utils.py”, line 695, in return_func
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py”, line 141, in main
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py”, line 126, in main
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py”, line 77, in run_experiment
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/models/yolov4_model.py”, line 692, in train
File “/usr/local/lib/python3.6/dist-packages/keras/engine/training.py”, line 1039, in fit
validation_steps=validation_steps)
File “/usr/local/lib/python3.6/dist-packages/keras/engine/training_arrays.py”, line 154, in fit_loop
outs = f(ins)
File “/usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py”, line 2715, in call
return self._call(inputs)
File “/usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py”, line 2675, in _call
fetched = self._callable_fn(*array_vals)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py”, line 1472, in call
run_metadata_ptr)
tensorflow.python.framework.errors_impl.InvalidArgumentError: 2 root error(s) found.
INFO: Horovod has been shut down. This was caused by an exception on one of the ranks or an attempt to allreduce, allgather or broadcast a tensor after one of the ranks finished execution. If the shutdown was caused by an exception, you should see the exception in the log before the first shutdown message.
[[{{node training_1/Adam/DistributedAdam_Allreduce/cond_9/HorovodAllreduce_training_1_Adam_gradients_AddN_50_0}}]]
outs = f(ins)
run_metadata_ptr)
tensorflow.python.framework.errors_impl.UnknownError: Horovod has been shut down. This was caused by an exception on one of the ranks or an attempt to allreduce, allgather or broadcast a tensor after one of the ranks finished execution. If the shutdown was caused by an exception, you should see the exception in the log before the first shutdown message.
[[{{node training_1/Adam/DistributedAdam_Allreduce/cond_33/HorovodAllreduce_training_1_Adam_gradients_AddN_38_0}}]]
outs = f(ins)
run_metadata_ptr)
[[{{node training_1/Adam/DistributedAdam_Allreduce/cond_59/HorovodAllreduce_training_1_Adam_gradients_AddN_27_0}}]]
outs = f(ins)
run_metadata_ptr)
Primary job terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
outs = f(ins)
run_metadata_ptr)
outs = f(ins)
run_metadata_ptr)
mpirun detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
Process name: [[54762,1],7]
Exit code: 1
2024-03-19 22:54:52,466 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
