• Hardware (RTX2080Ti)
• Network Type (Classification)
• TLT Version (tao-toolkit-tf:v3.21.08-py3)
• Training spec file(classifi_8_0_1_efficientnet_b1_relu_train.cfg (1.2 KB)
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/makenet/scripts/train.py”, line 500, in
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/utils.py”, line 494, in return_func
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/utils.py”, line 482, in return_func
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/makenet/scripts/train.py”, line 495, in main
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/makenet/scripts/train.py”, line 468, in run_experiment
File “/usr/local/lib/python3.6/dist-packages/keras/legacy/interfaces.py”, line 91, in wrapper
return func(*args, **kwargs)
File “/usr/local/lib/python3.6/dist-packages/keras/engine/training.py”, line 1418, in fit_generator
initial_epoch=initial_epoch)
File “/usr/local/lib/python3.6/dist-packages/keras/engine/training_generator.py”, line 217, in fit_generator
class_weight=class_weight)
File “/usr/local/lib/python3.6/dist-packages/keras/engine/training.py”, line 1217, in train_on_batch
outputs = self.train_function(ins)
File “/usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py”, line 2715, in call
return self._call(inputs)
File “/usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py”, line 2675, in _call
fetched = self._callable_fn(*array_vals)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py”, line 1472, in call
run_metadata_ptr)
tensorflow.python.framework.errors_impl.NotFoundError: 2 root error(s) found.
(0) Not found: No algorithm worked!
[[{{node stem_conv_1/convolution}}]]
[[loss/add_92/_11357]]
(1) Not found: No algorithm worked!
0 successful operations.
0 derived errors ignored.
Primary job terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun.real detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
Process name: [[59563,1],0]
Exit code: 1
Using TensorFlow backend.
