When I try and compile a project to a shared library, I get this error:
/usr/bin/ld: obj/release/cuRTIV.cu_o: relocation R_X86_64_32 against `a local symbol' can not be used when making a shared object; recompile with -fPIC
obj/release/cuRTIV.cu_o: could not read symbols: Bad value
collect2: ld returned 1 exit status
I am using the makefile that comes with the SDK with a few changes
# Add source files here
EXECUTABLE := libcuRTIV.so
# CUDA source files (compiled with cudacc)
CUFILES := cuRTIV.cu
# CUDA dependency files
CU_DEPS := cuRTIV_kernel.cu
# C/C++ source files (compiled with gcc / c++)
CCFILES := cuRTIV_cpp.cpp
# Rules and targets
include ../../common/common.mk
CXXFLAGS += -fPIC
CFLAGS += -fPIC
LINK += -shared
cuRTIV.cu is getting compiled with nvcc, so I can’t pass -fPIC to it. Any ideas?
Ive been trying to create a shared object file, ran into the same problem you did, but
didn’t solve the problem, what should the final makefile used to create a shared object look like? Whenever i add the LINK += -shared, i get the error:
obj/release/mySo.cu_o: relocation R_X86_64_32 against `a local symbol' can not be used when making a shared object; recompile with -fPIC obj/release/mySo.cu_o: could not read symbols: Bad value
