Error: RGB/BGR input format specified but network input channels is not 3
Hello. I am new to deepstream and am having some difficulties getting started.
Environment and setup:
Jetson TX2
• DeepStream Version
6.0
4.6
• TensorRT Version
8.0
I am having difficulty resolving the following error:
0:04:01.863759071 13398     0x3e23a660 ERROR                nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::preparePreprocess() <nvdsinfer_context_impl.cpp:964> [UID = 1]: RGB/BGR input format specified but network input channels is not 3
ERROR: Infer Context prepare preprocessing resource failed., nvinfer error:NVDSINFER_CONFIG_FAILED
Attempting to run an onnx model with mp4 file as data source. Attached are snippets of the config files used:
Main config file
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=2
uri=file://video.mp4
num-sources=1
gpu-id=0
cudadec-memtype=0
[pre-process]
enable=1
config-file=config_preprocess.txt
[primary-gie]
enable=1
gpu-id=0
infer-dims=512;512;3
batch-size=1
interval=2
gie-unique-id=1
nvbuf-memory-type=0
config-file=INFER_CONFIG.txt
Inference config:
[property]
gpu-id=0
onnx-file=/filepath/the_model.onnx
network-mode=0
#num-detected-classes=80
gie-unique-id=1
network-type=0
is-classifier=0
## 1=DBSCAN, 2=NMS, 3= DBSCAN+NMS Hybrid, 4 = None(No clustering)
cluster-mode=2
maintain-aspect-ratio=1
Pre process config:
[property]
enable=1
network-input-shape=1;512;512;3
processing-width=512
processing-height=512
tensor-data-type=0
Thanks in advance!
Based on the error, it seems that the input format of your model is not expected.
May I know the input dimension of your model first?
You can visualize it with the below link to find this information:
https://lutzroeder.github.io/netron/
