I am trying to implement a custom YOLOv3 .onnx file. The input dimensions of the network are in the order HWC. When I try to compile the model I receive an error stating that the network RGB input channels are not 3. I noticed that I can change the infer-dims property to be the required input format, but it appears in the documentation that this still would need the channel input to be listed first. Is there a way to change the input format within the pgie such that it can accept my model format of HWC?
• DeepStream Version
• TensorRT Version
This is on a dGPU
This is Deepstream 6.0
Testing will be performed on a 3090
Issue type: question
15.2.2 Input Order
1). network-input-order= // 0:NCHW 1:NHWC
2). infer-dims= // if network-input-order=1, i.e. NHWC, infer-dims must be specified, otherwise, nvinfer can’t detect input dims automatically
3). model-color-format= // 0: RGB 1: BGR 2: GRAY
I have solved this issue by using ONNX’s NHWC → CHWN converter tool
