• Hardware Platform (Jetson / GPU) Jetson Nano 2Gb
• DeepStream Version 6.0
• JetPack Version (valid for Jetson only) 4.6
• TensorRT Version 8.0.1
• Issue Type( questions, new requirements, bugs) Question/Bug
Using the new nvinfer configuration flag “network-input-order” introduced in Deepstream 6.0 isnt giving the expected result. I have an onnx file that has input dimensions of 128x128x1 (Grey Scale). This is a NHWC input format, so, as one would expect I set the “network-input-order” to 1, which is NHWC. However, deepstream throws an error:
0:02:58.926432640 15050 0x559293b8d0 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1947> [UID = 1]: serialize cuda engine to file: /home/james/main/models/Segment/model.onnx_b1_gpu0_fp32.engine successfully
INFO: [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT img 128x128x1
1 OUTPUT kFLOAT conv2d_23 128x128x1
0:02:59.573292270 15050 0x559293b8d0 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<inference> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::preparePreprocess() <nvdsinfer_context_impl.cpp:973> [UID = 1]: GRAY input format specified but network input channels is not 1.
ERROR: Infer Context prepare preprocessing resource failed., nvinfer error:NVDSINFER_CONFIG_FAILED
This same error is thrown when if I set “network-input-order” to 0. This error is giving me the impression that deepstream is still trying to use NCHW even if the order is set to NHWC, hence why it says the input channels is not 1 (Reading 128 first). I have also tried setting “input-tensor-meta” to 0 (As the docs say that network-input-order is ignored if this flag is 1). However, this gives the warning: Unknown or legacy key specified “input-tensor-meta’ for group [property]”
Further, I have tried creating the engine file directly with trtexec. The engine is created successfully but loading the engine file in the nvinfer config yields the same result. I’ve tried creating the engine with these two commands:
/usr/src/tensorrt/bin/trtexec --onnx=/home/james/main/models/Segment/model.onnx --explicitBatch --saveEngine=/home/james/test.trt
and…
/usr/src/tensorrt/bin/trtexec --onnx=/home/james/main/models/Segment/model.onnx --shapes=img:1x128x128x1 --explicitBatch --saveEngine=/home/james/test.trt
An example of my nvinfer configuration:
[property]
gpu-id=0
net-scale-factor=1.0
model-color-format=2 # Grey scale
#onnx-file=model.onnx # The onnx file for conversion
model-engine-file=test.trt # The successfully converted engine file
input-tensor-meta=0 # Diable the input tensor meta (The same error is thrown even if I comment this flag out)
network-input-order=1 # Input as NHWC
segmentation-output-order=1 # Output as NHWC (It gives the same error even if I comment this flag out)
gie-unique-id=1
network-type=2 # Segmentation
output-blob-names=conv2d_23
segmentation-threshold=0.0
Am I missing something in getting my onnx file to run correctly using the NHWC input order? Please advise.
Thank you,
James
