Error: sce-fabric Occurred, Unable to Output DisplayPort Video
Dear NVIDIA Technical Support Team,
Hello, I am developing a product using the Orin NX 8GB SOM and a custom carrier board we have designed.
Currently, I am encountering the following error in the kernel log. I am unsure of the cause or how to resolve it, so I would appreciate your assistance.
Our product has a mechanism that enables or disables video output via DisplayPort when a button is pressed.
To disable DisplayPort video output, we use the xrandr --off command to stop video output and also reset the DP HUB IC connected to the DisplayPort.
To enable video output, we perform the opposite operation.
When repeatedly enabling and disabling video output in this manner, the following error message appeared:
I suspect that this issue is related to DisplayPort, but I am unsure how to prevent it from occurring.
Could you provide any advice?
Our Carrier Board Configuration:
[ Orin NX 8GB ] - [ DP HUB to HDMI ] -± HDMI-0
|- HDMI-1
Software : Jetson linux 36.3 based
We have not yet tested this on the Orin Nano Devkit.
Jan  4 10:20:06 kernel:[ 2442.336145] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731343 result 0x1:
Jan  4 10:20:06 kernel:[ 2442.342331] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731343 result 0x1:
Jan  4 10:20:06 kernel:[ 2442.348464] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731343 result 0x1:
Jan  4 10:20:06 kernel:[ 2442.354582] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731343 result 0x1:
Jan  4 10:20:06 kernel:[ 2442.360621] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731343 result 0x1:
Jan  4 10:20:06 kernel:[ 2442.366614] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731343 result 0x1:
Jan  4 10:20:06 kernel:[ 2442.372628] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731343 result 0x1:
Jan  4 10:20:06 kernel:[ 2442.379334] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731343 result 0x1:
Jan  4 10:20:06 kernel:[ 2442.386832] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731343 result 0x1:
Jan  4 10:20:06 kernel:[ 2442.393155] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731343 result 0x1:
Jan  4 10:20:06 kernel:[ 2442.400796] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731343 result 0x1:
Jan  4 10:20:06 kernel:[ 2442.409301] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731343 result 0x1:
Jan  4 10:20:07 kernel:[ 2442.446089] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
Jan  4 10:20:07 kernel:[ 2442.458324] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
Jan  4 10:20:07 kernel:[ 2442.470511] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
Jan  4 10:20:07 kernel:[ 2442.482295] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
Jan  4 10:20:07 kernel:[ 2442.494310] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
Jan  4 10:20:07 kernel:[ 2442.506958] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
Jan  4 10:20:07 kernel:[ 2442.518394] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
Jan  4 10:20:07 kernel:[ 2442.530344] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
Jan  4 10:20:07 kernel:[ 2442.542327] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
Jan  4 10:20:07 kernel:[ 2442.554339] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
Jan  4 10:20:07 kernel:[ 2442.570482] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
Jan  4 10:20:07 kernel:[ 2442.582372] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
Jan  4 10:20:07 kernel:[ 2442.594341] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
Jan  4 10:20:07 kernel:[ 2442.606322] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
Jan  4 10:20:07 kernel:[ 2442.618856] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
Jan  4 10:20:07 kernel:[ 2442.630381] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
Jan  4 10:20:07 kernel:[ 2442.642327] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
Jan  4 10:20:07 kernel:[ 2442.654313] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
Jan  4 10:20:07 kernel:[ 2442.670330] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
Jan  4 10:20:07 kernel:[ 2442.686385] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
Jan  4 10:20:07 kernel:[ 2442.702676] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
Jan  4 10:20:07 kernel:[ 2442.823619] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
Jan  4 10:20:08 kernel:[ 2443.894274] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731367 result 0x65:
Jan  4 10:20:08 kernel:[ 2443.895280] CPU:0, Error: sce-fabric@0xde00000, irq=173
Jan  4 10:20:08 kernel:[ 2443.895292] **************************************
Jan  4 10:20:08 kernel:[ 2443.895294] CPU:0, Error:sce-fabric, Errmon:2
Jan  4 10:20:08 kernel:[ 2443.895301] CBB registers returning all 1's which is invalid
Jan  4 10:20:08 kernel:[ 2443.895307] CPU:0, Error: cbb-fabric@0x13a00000, irq=177
Jan  4 10:20:08 kernel:[ 2443.895310] **************************************
Jan  4 10:20:08 kernel:[ 2443.895311] CPU:0, Error:cbb-fabric, Errmon:2
Jan  4 10:20:08 kernel:[ 2443.895317] 	  Error Code		: FIREWALL_ERR
Jan  4 10:20:08 kernel:[ 2443.895320] 	  Overflow		: Multiple FIREWALL_ERR
Jan  4 10:20:08 kernel:[ 2443.895328]
Jan  4 10:20:08 kernel:[ 2443.895330] 	  Error Code		: FIREWALL_ERR
Jan  4 10:20:08 kernel:[ 2443.895332] 	  MASTER_ID		: CCPLEX
Jan  4 10:20:08 kernel:[ 2443.895334] 	  Address		: 0xde12208
Jan  4 10:20:08 kernel:[ 2443.895336] 	  Cache			: 0x1 -- Bufferable
Jan  4 10:20:08 kernel:[ 2443.895340] 	  Protection		: 0x2 -- Unprivileged, Non-Secure, Data Access
Jan  4 10:20:08 kernel:[ 2443.895343] 	  Access_Type		: Read
Jan  4 10:20:08 kernel:[ 2443.895345] 	  Access_ID		: 0x17
Jan  4 10:20:08 kernel:[ 2443.895347] 	  Fabric		: cbb-fabric
Jan  4 10:20:08 kernel:[ 2443.895349] 	  Slave_Id		: 0x0
Jan  4 10:20:08 kernel:[ 2443.895351] 	  Burst_length		: 0x0
Jan  4 10:20:08 kernel:[ 2443.895352] 	  Burst_type		: 0x1
Jan  4 10:20:08 kernel:[ 2443.895353] 	  Beat_size		: 0x2
Jan  4 10:20:08 kernel:[ 2443.895354] 	  VQC			: 0x0
Jan  4 10:20:08 kernel:[ 2443.895355] 	  GRPSEC		: 0x7e
Jan  4 10:20:08 kernel:[ 2443.895356] 	  FALCONSEC		: 0x0
Jan  4 10:20:08 kernel:[ 2443.895357] 	  Slave			: AON
Jan  4 10:20:08 kernel:[ 2443.895360] 	**************************************
Jan  4 10:20:08 kernel:[ 2443.895384] ------------[ cut here ]------------
Jan  4 10:20:08 kernel:[ 2443.895387] WARNING: CPU: 0 PID: 0 at drivers/soc/tegra/cbb/tegra234-cbb.c:608 tegra234_cbb_isr+0x144/0x190
Jan  4 10:20:08 kernel:[ 2443.895404] Modules linked in: iptable_filter(E) lzo_rle(E) lzo_compress(E) zram(E) zsmalloc(E) r8168(OE) rfkill(E) snd_soc_tegra186_asrc(OE) snd_soc_tegra210_mixer(OE) snd_soc_tegra186_arad(OE) snd_soc_tegra210_admaif(OE) snd_soc_tegra210_ope(OE) snd_soc_tegra210_afc(OE) snd_soc_tegra_pcm(E) snd_soc_tegra210_mvc(OE) snd_soc_tegra186_dspk(OE) snd_soc_tegra210_dmic(OE) snd_soc_tegra210_adx(OE) snd_soc_tegra210_amx(OE) snd_soc_tegra210_sfc(OE) snd_soc_tegra210_i2s(OE) snd_soc_tegra210_ahub(OE) nvvrs_pseq_rtc(OE) snd_soc_tegra_machine_driver(OE) snd_soc_tegra_utils(OE) crct10dif_ce(E) snd_soc_simple_card_utils(E) tegra234_oc_event(OE) mttcan(OE) nvpmodel_clk_cap(OE) tegra_aconnect(E) nvpps(OE) snd_hda_codec_hdmi(E) can_dev(E) tegra_cactmon_mc_all(OE) tegra234_aon(OE) snd_hda_tegra(E) thermal_trip_event(OE) snd_hda_codec(E) tegra_pcie_dma_test(OE) snd_hda_core(E) snd_soc_tlv320aic31xx(E) pwm_tegra_tachometer(OE) mc_hwpm(OE) tegra_pcie_edma(OE) host1x_fence(OE) nvidia_vrs_pseq(OE)
Jan  4 10:20:08 kernel:[ 2443.895464]  governor_userspace(E) tegra_drm(OE) nvhost_nvdla(OE) nvhost_pva(OE) nvidia_p2p(OE) tegra_wmark(OE) cec(E) ina3221(E) nvhwpm(OE) drm_kms_helper(E) nvgpu(OE) governor_pod_scaling(OE) nvmap(OE) nvsciipc(OE) nvidia_modeset(OE) nvidia(OE) tegra_dce(OE) tsecriscv(OE) host1x_nvhost(OE) host1x(OE) mc_utils(OE) drm(E) fuse(E) ip_tables(E) x_tables(E) ipv6(E) pwm_fan(E) pwm_tegra(E) tegra_bpmp_thermal(E) tegra_xudc(E) ucsi_ccg(E) typec_ucsi(E) typec(E) nvme(E) nvme_core(E) phy_tegra194_p2u(E) pcie_tegra194(E)
Jan  4 10:20:08 kernel:[ 2443.895509] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G           OE     5.15.136-tegra #1
Jan  4 10:20:08 kernel:[ 2443.895513] Hardware name: NVIDIA NVIDIA Jetson Orin NX Engineering Reference Developer Kit/Jetson, BIOS 202402.1-81336553-dirty 11/08/2024
Jan  4 10:20:08 kernel:[ 2443.895515] pstate: 604000c9 (nZCv daIF +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
Jan  4 10:20:08 kernel:[ 2443.895520] pc : tegra234_cbb_isr+0x144/0x190
Jan  4 10:20:08 kernel:[ 2443.895522] lr : tegra234_cbb_isr+0x11c/0x190
Jan  4 10:20:08 kernel:[ 2443.895525] sp : ffff800008003e60
Jan  4 10:20:08 kernel:[ 2443.895526] x29: ffff800008003e60 x28: ffffb8f822722ec0 x27: 0000000000000001
Jan  4 10:20:08 kernel:[ 2443.895530] x26: 00000000000000c0 x25: ffffb8f821dc7268 x24: ffffb8f822b6b450
Jan  4 10:20:08 kernel:[ 2443.895533] x23: ffffb8f82210b008 x22: 00000000000000b1 x21: ffffb8f8229fe600
Jan  4 10:20:08 kernel:[ 2443.895537] x20: 0000000000000000 x19: ffffb8f8229fe6c0 x18: ffffffffffffffff
Jan  4 10:20:08 kernel:[ 2443.895540] x17: ffff4709cf140000 x16: ffff800008000000 x15: ffffb8f822b273a7
Jan  4 10:20:08 kernel:[ 2443.895543] x14: 0000000000000001 x13: 2a2a2a2a2a2a2a2a x12: 2a2a2a2a2a2a2a2a
Jan  4 10:20:08 kernel:[ 2443.895546] x11: 2a2a2a2a2a2a2a2a x10: 2a2a2a2a2a2a2a2a x9 : 2a2a2a2a2a2a2a2a
Jan  4 10:20:08 kernel:[ 2443.895548] x8 : 2a2a2a2a2a2a2a2a x7 : 2a2a2a2a2a2a2a2a x6 : 2a2a2a2a2a2a2a09
Jan  4 10:20:08 kernel:[ 2443.895551] x5 : ffff0001f124d9f0 x4 : 00000000fffff31f x3 : 0000000000000000
Jan  4 10:20:08 kernel:[ 2443.895554] x2 : ffffb8f820361e58 x1 : ffffb8f822722ec0 x0 : 0000000100010001
Jan  4 10:20:08 kernel:[ 2443.895558] Call trace:
Jan  4 10:20:08 kernel:[ 2443.895560]  tegra234_cbb_isr+0x144/0x190
Jan  4 10:20:08 kernel:[ 2443.895563]  __handle_irq_event_percpu+0x68/0x260
Jan  4 10:20:08 kernel:[ 2443.895571]  handle_irq_event+0x70/0x100
Jan  4 10:20:08 kernel:[ 2443.895575]  handle_fasteoi_irq+0xb0/0x1b0
Jan  4 10:20:08 kernel:[ 2443.895579]  handle_domain_irq+0x74/0xb0
Jan  4 10:20:08 kernel:[ 2443.895583]  gic_handle_irq+0x68/0x150
Jan  4 10:20:08 kernel:[ 2443.895589]  call_on_irq_stack+0x20/0x50
Jan  4 10:20:08 kernel:[ 2443.895595]  do_interrupt_handler+0x70/0x80
Jan  4 10:20:08 kernel:[ 2443.895598]  el1_interrupt+0x30/0x80
Jan  4 10:20:08 kernel:[ 2443.895603]  el1h_64_irq_handler+0x18/0x30
Jan  4 10:20:08 kernel:[ 2443.895606]  el1h_64_irq+0x7c/0x80
Jan  4 10:20:08 kernel:[ 2443.895608]  cpuidle_enter_state+0xbc/0x3f0
Jan  4 10:20:08 kernel:[ 2443.895615]  cpuidle_enter+0x44/0x60
Jan  4 10:20:08 kernel:[ 2443.895618]  do_idle+0x220/0x2b0
Jan  4 10:20:08 kernel:[ 2443.895622]  cpu_startup_entry+0x34/0x70
Jan  4 10:20:08 kernel:[ 2443.895625]  rest_init+0xf0/0x100
Jan  4 10:20:08 kernel:[ 2443.895627]  arch_call_rest_init+0x1c/0x28
Jan  4 10:20:08 kernel:[ 2443.895632]  start_kernel+0x6d0/0x710
Jan  4 10:20:08 kernel:[ 2443.895635]  __primary_switched+0xbc/0xc4
Jan  4 10:20:08 kernel:[ 2443.895641] ---[ end trace cc2a38ad3c3a4a28 ]---
err_system_no45.log (350.8 KB)
Thank you for your support.
I remember the error from above address should have been fixed on rel-36.4. Thus, please try rel-36.4.3 or at least rel-36.4.
Hello, WayneWWW
Thank you for your prompt response. I will check with version 36.4.3.
By the way, is there any fix or workaround for this issue in version 36.3?
We are developing production software based on version 36.3, so if possible, we would like to address the issue within this version.
I appreciate your guidance.
Is the fix mentioned in rel-36.4 related to the issues 4617111 and 4620917 listed in the Fixed Issues section of the release notes?
No, issue seems be fixed by another bug, and there is no workaround ready to back porting on old version now. Thanks
