Kernel Panic - not syncing error on Orin custom Board for IMX296 driver
We have a custom board for Orin. We have flashed it and were able to load OV5693 sensor module and get the video streaming.
However while I try to load VC - MIPI IMX296 module the board boots up but shuts down after 5 seconds.
The video node is present and the driver is loaded as well.
custom_board_imx296.txt (150.3 KB)
Log:
[2023-12-21 14:41:41] [   19.828747] nvidia: loading out-of-tree module taints kernel.
[2023-12-21 14:41:42] [   20.308026] using random self ethernet address
[2023-12-21 14:41:42] [   20.314487] using random host ethernet address
[2023-12-21 14:41:43] [   21.906129] using random self ethernet address
[2023-12-21 14:41:43] [   21.910732] using random host ethernet address
[2023-12-21 14:41:47] [   25.381916] CPU4: shutdown
[2023-12-21 14:41:47] [   25.481746] CPU5: shutdown
[2023-12-21 14:41:47] [   25.638039] CPU6: shutdown
[2023-12-21 14:41:47] [   25.759466] IRQ 116: no longer affine to CPU7
[2023-12-21 14:41:47] [   25.764743] CPU7: shutdown
[2023-12-21 14:41:48] [   26.020593] hot-surface-alert cooling state: 1 -> 0
[2023-12-21 14:41:48] [   26.033359] hot-surface-alert cooling state: 0 -> 1
[2023-12-21 14:42:03] [   40.970627] Unable to handle kernel NULL pointer dereference at virtual address 000000000000022c
[2023-12-21 14:42:03] [   40.979730] Mem abort info:
[2023-12-21 14:42:03] [   40.983038]   ESR = 0x96000045
[2023-12-21 14:42:03] [   40.986300]   EC = 0x25: DABT (current EL), IL = 32 bits
[2023-12-21 14:42:03] [   40.991893]   SET = 0, FnV = 0
[2023-12-21 14:42:03] [   40.995194]   EA = 0, S1PTW = 0
[2023-12-21 14:42:03] [   40.998560] Data abort info:
[2023-12-21 14:42:03] [   41.001656]   ISV = 0, ISS = 0x00000045
[2023-12-21 14:42:03] [   41.005716]   CM = 0, WnR = 1
[2023-12-21 14:42:03] [   41.008786] user pgtable: 4k pages, 48-bit VAs, pgdp=00000001332e0000
[2023-12-21 14:42:03] [   41.015722] [000000000000022c] pgd=0000000113624003, p4d=0000000113624003, pud=0000000000000000
[2023-12-21 14:42:03] [   41.024885] Internal error: Oops: 96000045 [#1] PREEMPT SMP
[2023-12-21 14:42:03] [   41.030627] Modules linked in: nvidia_modeset(OE) fuse(E) lzo_rle(E) lzo_compress(E) zram(E) ramoops(E) reed_solomon(E) loop(E) snd_soc_tegra186_asrc(E) snd_soc_tegra210_ope(E) s)
[2023-12-21 14:42:03] [   41.030762]  nvgpu(E) nvmap(E) ip_tables(E) x_tables(E) [last unloaded: mtd]
[2023-12-21 14:42:03] [   41.129852] CPU: 1 PID: 2250 Comm: pool-gnome-init Tainted: G           OE     5.10.120-tegra #2
[2023-12-21 14:42:03] [   41.138869] Hardware name: Unknown NVIDIA Orin NX Developer Kit/NVIDIA Orin NX Developer Kit, BIOS 4.1-33958178 08/01/2023
[2023-12-21 14:42:03] [   41.150207] pstate: 60400009 (nZCv daif +PAN -UAO -TCO BTYPE=--)
[2023-12-21 14:42:03] [   41.156387] pc : tegra_channel_set_format+0x60/0xf0
[2023-12-21 14:42:03] [   41.161386] lr : tegra_channel_set_format+0x44/0xf0
[2023-12-21 14:42:03] [   41.166392] sp : ffff800014f6bb50
[2023-12-21 14:42:03] [   41.169783] x29: ffff800014f6bb50 x28: ffff6dfad3eed100
[2023-12-21 14:42:03] [   41.175235] x27: 00000000c0d05605 x26: 0000000000000000
[2023-12-21 14:42:03] [   41.180688] x25: ffff6dfad3eed400 x24: ffff6dfa8367d1f8
[2023-12-21 14:42:03] [   41.186135] x23: ffff6dfad3eed100 x22: ffff6dfa80df9410
[2023-12-21 14:42:03] [   41.191584] x21: ffff6dfa8367d080 x20: ffff6dfad3eed408
[2023-12-21 14:42:03] [   41.197039] x19: ffff6dfad3eed400 x18: 0000000000000001
[2023-12-21 14:42:03] [   41.202488] x17: 0000000000000000 x16: 0000000000000000
[2023-12-21 14:42:03] [   41.207932] x15: ffff6dfa920f0570 x14: ffffffffffffffff
[2023-12-21 14:42:03] [   41.213386] x13: ffff800014f6bb48 x12: 0000000000000028
[2023-12-21 14:42:03] [   41.218846] x11: 0101010101010101 x10: ffff7f7f7f7f7f7f
[2023-12-21 14:42:03] [   41.224293] x9 : fefdff2f64636e6c x8 : ffffffffffffffff
[2023-12-21 14:42:03] [   41.229746] x7 : fefefefefefefefe x6 : 0000000000800000
[2023-12-21 14:42:03] [   41.235204] x5 : 0000000000000000 x4 : ffffffffffffffff
[2023-12-21 14:42:03] [   41.240652] x3 : 0000000000000000 x2 : ffffbc3c6c7cad58
[2023-12-21 14:42:03] [   41.246104] x1 : 0000000000000000 x0 : 0000000000000000
[2023-12-21 14:42:03] [   41.251565] Call trace:
[2023-12-21 14:42:03] [   41.254085]  tegra_channel_set_format+0x60/0xf0
[2023-12-21 14:42:03] [   41.258736]  v4l_s_fmt+0x308/0x568
[2023-12-21 14:42:03] [   41.262221]  __video_do_ioctl+0x188/0x3f8
[2023-12-21 14:42:03] [   41.266333]  video_usercopy+0x280/0x790
[2023-12-21 14:42:03] [   41.270269]  video_ioctl2+0x40/0x178
[2023-12-21 14:42:03] [   41.273933]  v4l2_ioctl+0x68/0x90
[2023-12-21 14:42:03] [   41.277331]  __arm64_sys_ioctl+0xac/0xf0
[2023-12-21 14:42:03] [   41.281355]  el0_svc_common.constprop.0+0x80/0x1c8
[2023-12-21 14:42:03] [   41.286275]  do_el0_svc+0x38/0xa8
[2023-12-21 14:42:03] [   41.289676]  el0_svc+0x1c/0x28
[2023-12-21 14:42:03] [   41.292803]  el0_sync_handler+0xa8/0xb0
[2023-12-21 14:42:03] [   41.296737]  el0_sync+0x16c/0x180
[2023-12-21 14:42:03] [   41.300142] Code: d100e063 b9400a60 121e7400 b9000a60 (b9022c60)
[2023-12-21 14:42:03] [   41.306409] ---[ end trace c6847b5f00b90ec6 ]---
[2023-12-21 14:42:03] [   41.316716] Kernel panic - not syncing: Oops: Fatal exception
[2023-12-21 14:42:03] [   41.322618] SMP: stopping secondary CPUs
[2023-12-21 14:42:03] [   41.326650] Kernel Offset: 0x3c3c5c610000 from 0xffff800010000000
[2023-12-21 14:42:03] [   41.332899] PHYS_OFFSET: 0xffff920680000000
[2023-12-21 14:42:03] [   41.337196] CPU features: 0x08040006,4a80aa38
[2023-12-21 14:42:03] [   41.341667] Memory Limit: none
[2023-12-21 14:42:03] [   41.350152] ---[ end Kernel panic - not syncing: Oops: Fatal exception ]---
[2023-12-21 14:42:04] ��WARNING @ [platform/drivers/mailbox/ivc_link_provider/mail_imo.c]: mail imo TX timeout
[2023-12-21 14:42:04] failed to send thermal trip message to cpu!
[2023-12-21 14:42:05] WARNING @ [platform/drivers/mailbox/ivc_link_provider/mail_imo.c]: mail imo TX timeout
[2023-12-21 14:42:05] failed to send thermal trip message to cpu!
[2023-12-21 14:42:07] WARNING @ [platform/drivers/mailbox/ivc_link_provider/mail_imo.c]: mail imo TX timeout
[2023-12-21 14:42:07] failed to send thermal trip message to cpu!
[2023-12-21 14:42:10] WARNING @ [platform/drivers/mailbox/ivc_link_provider/mail_imo.c]: mail imo TX timeout
[2023-12-21 14:42:10] failed to send thermal trip message to cpu!
We were able to get IMX-296 working on the Orin development board.
On OV5693 sensor integration on custom board I do not encounter this issue.
JetPack: 5.1.2
BSP - 35.4.1
Please advice.
Could be the pixel format report incorrect cause the problem.
@ShaneCCC
Sorry I did not get you.
Could be your sensor driver report incorrect format cause the problem.
@ShaneCCC
How do i debug this issue further?
This the log obtained after the orin shuts down:
[   40.644272] Unable to handle kernel NULL pointer dereference at virtual address 000000000000022c
[   40.653335] Mem abort info:
[   40.656225]   ESR = 0x96000045
[   40.659363]   EC = 0x25: DABT (current EL), IL = 32 bits
[   40.664844]   SET = 0, FnV = 0
[   40.668027]   EA = 0, S1PTW = 0
[   40.671249] Data abort info:
[   40.674215]   ISV = 0, ISS = 0x00000045
[   40.678163]   CM = 0, WnR = 1
[   40.681223] user pgtable: 4k pages, 48-bit VAs, pgdp=00000001426da000
[   40.687856] [000000000000022c] pgd=000000010d47e003, p4d=000000010d47e003, pud=0000000000000000
[   40.696817] Internal error: Oops: 96000045 [#1] PREEMPT SMP
[   40.702542] Modules linked in: nvidia_modeset(OE) fuse(E) lzo_rle(E) lzo_compress(E) zram(E) ramoops(E) reed_solomon(E) loop(E) snd_soc_tegra186_asrc(E) snd_soc_tegra210_ope(E) snd_soc_tegra210_iqc(E))
[   40.702618]  nvgpu(E) nvmap(E) ip_tables(E) x_tables(E) [last unloaded: mtd]
[   40.801673] CPU: 3 PID: 2354 Comm: pool-gnome-init Tainted: G           OE     5.10.120-tegra #2
[   40.810681] Hardware name: Unknown NVIDIA Orin NX Developer Kit/NVIDIA Orin NX Developer Kit, BIOS 4.1-33958178 08/01/2023
[   40.822007] pstate: 60400009 (nZCv daif +PAN -UAO -TCO BTYPE=--)
[   40.828177] pc : tegra_channel_set_format+0x60/0xf0
[   40.833179] lr : tegra_channel_set_format+0x44/0xf0
[   40.838169] sp : ffff80001e54bb50
[   40.841561] x29: ffff80001e54bb50 x28: ffff2cc500313d00
[   40.847012] x27: 00000000c0d05605 x26: 0000000000000000
[   40.852455] x25: ffff2cc553875500 x24: ffff2cc845c5d1f8
[   40.857897] x23: ffff2cc500313d00 x22: ffff2cc500dfd810
[   40.863343] x21: ffff2cc845c5d080 x20: ffff2cc553875508
[   40.868791] x19: ffff2cc553875500 x18: 0000000000000001
[   40.874233] x17: 0000000000000000 x16: 0000000000000000
[   40.879677] x15: ffff2cc53fae8570 x14: ffffffffffffffff
[   40.885116] x13: ffff80001e54bb48 x12: 0000000000000028
[   40.890563] x11: 0101010101010101 x10: ffff7f7f7f7f7f7f
[   40.896017] x9 : fefdff2f64636e6c x8 : ffffffffffffffff
[   40.901459] x7 : fefefefefefefefe x6 : 0000000000800000
[   40.906898] x5 : 0000000000000000 x4 : ffffffffffffffff
[   40.912347] x3 : 0000000000000000 x2 : ffffcbcafa25ad58
[   40.917798] x1 : 0000000000000000 x0 : 0000000000000000
[   40.923239] Call trace:
[   40.925747]  tegra_channel_set_format+0x60/0xf0
[   40.930393]  v4l_s_fmt+0x308/0x568
[   40.933874]  __video_do_ioctl+0x188/0x3f8
[   40.937990]  video_usercopy+0x280/0x790
[   40.941924]  video_ioctl2+0x40/0x178
[   40.945581]  v4l2_ioctl+0x68/0x90
[   40.948983]  __arm64_sys_ioctl+0xac/0xf0
[   40.953002]  el0_svc_common.constprop.0+0x80/0x1c8
[   40.957908]  do_el0_svc+0x38/0xa8
[   40.961304]  el0_svc+0x1c/0x28
[   40.964436]  el0_sync_handler+0xa8/0xb0
[   40.968363]  el0_sync+0x16c/0x180
[   40.971758] Code: d100e063 b9400a60 121e7400 b9000a60 (b9022c60)
[   40.978018] ---[ end trace bb317f81424924a5 ]---
[   40.988290] Kernel panic - not syncing: Oops: Fatal exception
[   40.994179] SMP: stopping secondary CPUs
[   40.998200] Kernel Offset: 0x4bcaea0a0000 from 0xffff800010000000
[   41.004449] PHYS_OFFSET: 0xffffd33c00000000
[   41.008731] CPU features: 0x08040006,4a80aa38
[   41.013190] Memory Limit: none
[   41.021885] ---[ end Kernel panic - not syncing: Oops: Fatal exception ]---
Reference to ov5693 to implement the IMX-296 from crash again.
@ShaneCCC
the clock was not synchronized before loading the new module, also updated initramfs for the new driver. hence the issue is resolved.
