We Reboot our 32G Orin Module on our customized carrier board,it would occur kernel panic occasionally
60.391389] —[ end trace 7adf9bdd9d8529fb ]—
[ 60.396174] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1a0/0x1e0
[ 60.405706] —[ end trace 7adf9bdd9d8529fc ]—
[ 60.410491] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1a0/0x1e0
[ 60.420020] —[ end trace 7adf9bdd9d8529fd ]—
[ 60.424806] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1a0/0x1e0
[ 60.434342] —[ end trace 7adf9bdd9d8529fe ]—
[ 60.439125] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1a0/0x1e0
[ 60.448703] —[ end trace 7adf9bdd9d8529ff ]—
[ 60.453489] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1a0/0x1e0
[ 60.463032] —[ end trace 7adf9bdd9d852a00 ]—
[ 60.467817] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1a0/0x1e0
[ 60.477349] —[ end trace 7adf9bdd9d852a01 ]—
[ 60.482132] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1a0/0x1e0
[ 60.491664] —[ end trace 7adf9bdd9d852a02 ]—
[ 60.496448] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1a0/0x1e0
[ 60.505983] —[ end trace 7adf9bdd9d852a03 ]—
[ 60.510768] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1a0/0x1e0
[ 60.520302] —[ end trace 7adf9bdd9d852a04 ]—
[ 60.525085] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1a0/0x1e0
[ 60.534615] —[ end trace 7adf9bdd9d852a05 ]—
[ 60.539397] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1a0/0x1e0
[ 60.548950] —[ end trace 7adf9bdd9d852a06 ]—
[ 60.553725] watchdog: BUG: soft lockup - CPU#0 stuck for 22s! [swapper/0:0]
[ 60.561024] Kernel panic - not syncing: softlockup: hung tasks
[ 60.567028] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W OEL 5.10.104-tegra #55
[ 60.575361] Hardware name: /, BIOS 1.0-d7fb19b 08/10/2022
[ 60.581003] Call trace:
[ 60.583518] dump_backtrace+0x0/0x1d0
[ 60.587287] show_stack+0x2c/0x40
[ 60.590707] dump_stack+0xd8/0x138
[ 60.594208] panic+0x178/0x380
[ 60.597353] watchdog_timer_fn+0x200/0x250
[ 60.601576] __hrtimer_run_queues+0x144/0x370
[ 60.606060] hrtimer_interrupt+0xec/0x240
[ 60.610197] arch_timer_handler_phys+0x3c/0x50
[ 60.614769] handle_percpu_devid_irq+0x8c/0x280
[ 60.619437] generic_handle_irq+0x3c/0x60
[ 60.623566] __handle_domain_irq+0x6c/0xc0
[ 60.627786] gic_handle_irq+0x64/0x130
[ 60.631648] el1_irq+0xd0/0x180
[ 60.634885] __do_softirq+0xb0/0x3e0
[ 60.638568] irq_exit+0xc0/0xe0
[ 60.641806] __handle_domain_irq+0x70/0xc0
[ 60.646020] gic_handle_irq+0x64/0x130
[ 60.649882] el1_irq+0xd0/0x180
[ 60.653108] cpuidle_enter_state+0xb4/0x400
[ 60.657409] cpuidle_enter+0x3c/0x50
[ 60.661092] call_cpuidle+0x40/0x70
[ 60.664688] do_idle+0x1fc/0x260
[ 60.668017] cpu_startup_entry+0x28/0x70
[ 60.672053] rest_init+0xd8/0xe4
[ 60.675380] arch_call_rest_init+0x14/0x1c
[ 60.679595] start_kernel+0x50c/0x540
[ 60.683376] SMP: stopping secondary CPUs
[ 60.687421] Kernel Offset: 0x3a7a9abf0000 from 0xffff800010000000
[ 60.693692] PHYS_OFFSET: 0xfffff26400000000
[ 60.697996] CPU features: 0x0040006,4a80aa38
[ 60.702400] Memory Limit: none
[ 60.712706] —[ end Kernel panic - not syncing: softlockup: hung tasks ]—
Which JetPack SW you’re using?
Reproduce rate?
R35.1,Reproduce rate is not sure ,We would test this case free time
Is this still an issue to support? Any result can be shared? Thanks
