I have declared a struct as follows:
typedef unsigned int fieldSet;
typedef unsigned int fieldSetDouble;
struct __align(16)__ task {
fieldSet cols;
fieldSet rows;
fieldSetDouble diagP;
fieldSetDouble diagN;
int nextRow;
The following code gives me an error when compiling:
_
_device__ void initTask(task* t) {
t->cols = 0;
t->rows = 0;
t->diagP = 0;
t->diagN = 0;
t->nextRow = 0;
Each line inside the function gives an “Error: Unaligned memory accesses not supported”.
I’ve searched the forums and there are some threads referencing this error, but none discuses this specific issue. At least I couldn’t figure out :P
So, if you can help me! Thanks a lot!
Erik
