Error: Unaligned memory accesses not supported aligned memory accesses
When compiling, I get the following error: Error: Unaligned memory accesses not supported
__device__  void function()
      uint8_t  ib[8], block[8];
     extern __shared__ uint8_t pkt[];
     .... init ...
     for( i = 1; i < n + 1; i++ )
        ... does stuff here...
       for( j = 0; j < 8; j++ )
            pkt[iHeader+8*(i-1)+j] = ib[j] ^ block[j]; //unalignment
the strange thing is that the following replaced in the code compiles fine:
uint8_t temp = ib[j] ^ block[j];
pkt[iHeader+8*(i-1)+j] = 0; //this is not the same ofcourse
but
pkt[iHeader+8*(i-1)+j] = temp
doesnt work.
Can someone point me toward the sollution or origin of this problem? I have left out alot of code for clearity. Please ask if you need to see more code.
Thanks in advance!
I found a way to avoid the error but i still don’t understand the problem:
i just replaced:
with
pkt[iHeader+8*(i-1)  ] =ib[0] ^ block[0];
pkt[iHeader+8*(i-1)+1] =ib[1] ^ block[1];
pkt[iHeader+8*(i-1)+2] =ib[2] ^ block[2];
pkt[iHeader+8*(i-1)+3] =ib[3] ^ block[3];
pkt[iHeader+8*(i-1)+4] =ib[4] ^ block[4];
pkt[iHeader+8*(i-1)+5] =ib[5] ^ block[5];
pkt[iHeader+8*(i-1)+6] =ib[6] ^ block[6];
pkt[iHeader+8*(i-1)+7] =ib[7] ^ block[7];
This still seams to be a problem.
I am uploading a complete example which causes nvcc to fail
bug_371104.cu (19.6 KB)
