"unaligned memory accesses not supported"
Hi everyone.
I’m having trouble compiling a program I made. I’m so very close to getting it working, but it gives me:
Assertion failure at line 548 of ../../be/cg/NVISA/exp_loadstore.cxx:
Compiler Error in file /tmp/tmpxft_00000640_00000000-1.i during Code_Expansion phase:
When I try to ‘make’ it. I’ll paste my kernel code in:
__global__ void
compareHash(testValue* gTestValues, int* testValuesLoc, hash* gHashTable, int* hashLoc, int* hashSize, int* hashEnd)
	const unsigned int tid = threadIdx.x;
	const unsigned int bid = blockIdx.x;
	const unsigned int num_threads = blockDim.x;
	const unsigned int mem_size = HASH_MEM_SIZE / sizeof(unsigned long long);
	unsigned long long* sHashTable = (unsigned long long*)sharedMem;
	bool* found = (bool*)&sHashTable[mem_size];
	testValue* currentValue = (testValue*)&found[1];
	if (tid == 0)
  currentValue->value = gTestValues[testValuesLoc[0]].value;
  currentValue->stopLoc = gTestValues[testValuesLoc[0]--].stopLoc;
	__syncthreads();
	while (testValuesLoc[0] >= BLOCKS && hashEnd[0] <= hashSize[0])
  // copy table from global to shared mem
  for (int x = tid; x < mem_size; x += num_threads)
  	if (hashLoc[0] * mem_size + x > hashEnd[0]) sHashTable[x] = 0;
  	else sHashTable[x] = gHashTable[hashLoc[0] * mem_size + x].value;
  // run comparisons
  if (tid == 0) *found = false;
  __syncthreads();
  for (int x = tid; x < mem_size && !*found; x += num_threads)
  	if (sHashTable[x] == currentValue->value)
    *found = true;
    gHashTable[hashLoc[0] * mem_size + x].count++;
    currentValue->stopLoc = gTestValues[testValuesLoc[0]].stopLoc;
    currentValue->value = gTestValues[testValuesLoc[0]--].value;
  __syncthreads();
  if (tid == 0 && *hashLoc == currentValue->stopLoc)
  	*found = true;
  	gHashTable[hashEnd[0]].value = currentValue->value;
  	gHashTable[hashEnd[0]++].count = 0;
  	currentValue->stopLoc = hashLoc[0];
  if (tid == 0 && bid == 0)
  	hashLoc[0] += mem_size;
  	if (hashLoc[0] >= hashEnd[0]) hashLoc[0] = 0;
  __syncthreads();
Also, if I’m doing something stupid in the code, let me know. I’m pretty new at this whole thing.
Hmm I guess you can disregard that then. I changed the testValue from a shared to local and it compiled.
