I ve been trying to just compile my code using gcc and I get the above error.
I try to declare an unused variable as half * but compiler does not find the half type. I include “cuda_fp16.h”. What could give this error?
I also tried nvcc and the error seems to stay.
I don t know what info should I give to be more helpful
Hi @thanasisGiannis
According to the documentation, it is __half
instead of half
For more info: CUDA Math API :: CUDA Toolkit Documentation
Regards,
Leon
I used that too. Nothing changed
Could you copy and paste the complete error message?
Regards,
Leon
//ex_eig.c
#include <cuda_fp16.h>
int main(){
__half tmpH;
return 0;
// Compilation and Error
/usr/local/cuda-10.2/bin/nvcc examples/ex_eig.c -I/usr/local/cuda-10.2/include -L/usr/local/cuda-10.2/lib64 -lm -lcusolver -lcusparse -lcurand -lcublas -lculibos -lcudart -lpthread -ldl --std=c++11 -arch=sm_60 -o examples/ex_eigs
examples/ex_eig.c: In function ‘main’:
examples/ex_eig.c:76:2: error: unknown type name ‘__half’; did you mean ‘__half_raw’?
__half tmpH;
__half_raw
Makefile:23: recipe for target ‘examples/ex_eigs’ failed
make: *** [examples/ex_eigs] Error 1
Thank you very much for your time!
It seems that the problem is that I used .c file instead of .cu file. Strange that I cannot use this in .c files.
Thank you for your time!
