Error when allocating mapped memory after allocating other memory
Hello!
I have encountered a weird problem and I wonder whether this is a bug or my bad:
I am trying to allocate mapped memory. That works without a problem, but if I allocated some host memory before (using cudaHostAlloc) I am getting an error. Here is some code that causes the problem:
#include <stdio.h>
int main() {
	cudaError_t err;
	int *host;
	int host_size = 1073741824;
	cudaSetDevice(0);
	err = cudaHostAlloc((void **) &host, host_size, cudaHostAllocDefault);
	printf("cudaHostAlloc returned %d: %s\n", err, cudaGetErrorString(err));
	cudaFree(host);
	err = cudaHostAlloc((void **) &host, host_size, cudaHostAllocMapped);
	cudaFree(host);
	return 0;
The output on my system is
No error occurs if the flags of the second cudaHostAlloc are set to cudaHostAllocPortable, cudaHostAllocWriteCombined or cudaHostAllocDefault.
Is there something wrong with my setup? I am using the toolkit version 3.0 on Debian lenny.
Volker
Use
cudaFreeHost
Use
cudaFreeHost
I am also facing the same problem but with ‘cudaHostAllocPortable’ flag (and I am using ‘cudaFreeHost()’ ).
the error says " unknown error"
