Hardware - GPU RTX3090
Hardware - Xeon(R) Silver 4216
Operating System - Ubuntu Server 18.04
Riva Version 1.8.0b0
Hellow! I used the standard nemo model “stt_en_conformer_ctc_large”.
This model was converted from .nemo to .riva format using “nemo2riva-1.8.0b0-py3-none-any.whl” script
I run Riva build with parameters for Conformer-CTC model, build finished with no errors:
riva-build speech_recognition \
--force \
/servicemaker-dev/stt_en_conformer_ctc_large.rmir \
/servicemaker-dev/stt_en_conformer_ctc_large.riva \
--name=test_conformer \
--decoder_type=greedy \
--chunk_size=0.8 \
--padding_size=1.6 \
--ms_per_timestep=40 \
--nn.use_onnx_runtime \
--greedy_decoder.asr_model_delay=-1 \
--vad.residue_blanks_at_start=-2 \
--featurizer.use_utterance_norm_params=False \
--featurizer.precalc_norm_time_steps=0 \
--featurizer.precalc_norm_params=False
But when running the stream recognition example in the “riva-speech-client” container , I get the error:
!python3 …/examples/riva_streaming_asr_client.py --input-file=out.wav
Number of clients: 1
Number of iteration: 1
Input file: out.wav
File duration: 82.66s
Exception in thread Thread-1:
File "/usr/lib/python3.8/threading.py", line 932, in _bootstrap_inner
self.run()
File "/usr/lib/python3.8/threading.py", line 870, in run
self._target(*self._args, **self._kwargs)
File "../examples/riva_streaming_asr_client.py", line 137, in asr_client
print_to_file(responses, output_file, max_alternatives, word_time_offsets)
File "../examples/riva_streaming_asr_client.py", line 53, in print_to_file
for response in responses:
File "/usr/local/lib/python3.8/dist-packages/grpc/_channel.py", line 426, in __next__
return self._next()
File "/usr/local/lib/python3.8/dist-packages/grpc/_channel.py", line 826, in _next
raise self
grpc._channel._MultiThreadedRendezvous: <_MultiThreadedRendezvous of RPC that terminated with:
status = StatusCode.UNKNOWN
details = "in ensemble 'test_conformer', onnxruntime execute failure 6: Non-zero status code returned while running Reshape node. Name:'Reshape_349' Status Message: /workspace/onnxruntime/onnxruntime/core/providers/cpu/tensor/reshape_helper.h:36 onnxruntime::ReshapeHelper::ReshapeHelper(const onnxruntime::TensorShape&, std::vector<long int>&, bool) size != 0 && (input_shape.Size() % size) == 0 was false. The input tensor cannot be reshaped to the requested shape. Input shape:{1,101,512}, requested shape:{16,-1,8,64}
debug_error_string = "{"created":"@1640329690.215318026","description":"Error received from peer ipv4:127.0.0.1:50051","file":"src/core/lib/surface/call.cc","file_line":1063,"grpc_message":"in ensemble 'test_conformer', onnxruntime execute failure 6: Non-zero status code returned while running Reshape node. Name:'Reshape_349' Status Message: /workspace/onnxruntime/onnxruntime/core/providers/cpu/tensor/reshape_helper.h:36 onnxruntime::ReshapeHelper::ReshapeHelper(const onnxruntime::TensorShape&, std::vector<long int>&, bool) size != 0 && (input_shape.Size() % size) == 0 was false. The input tensor cannot be reshaped to the requested shape. Input shape:{1,101,512}, requested shape:{16,-1,8,64}\n","grpc_status":2}"
1 threads done, output written to output_<thread_id>.txt
Logs “sudo docker logs riva-speech” output: logs.txt (33.5 KB)
