I’m using Jetson AGX Xavier on custom hardware with an FPGA based frame grabber.
The physical address of the DMA memory is known to the FPGA and the FPGA writes data to the DMA memory.
I want to use GPU as DMA memory without CPU->GPU memcpy using GPUDirectRDMA.
So, I wrote a custom driver for FPGA and tested it, but when the FPGA tries to write data to the DMA memory, the following error occurs.
arm-smmu 12000000.iommu: Unhandled context error: fsr=0x80000402, iova=0xffc00000, fsynr=0x13, cbfrsynra=0x145b, cb=7’
I wrote the code by looking at GitHub - NVIDIA/jetson-rdma-picoevb: Minimal HW-based demo of GPUDirect RDMA on NVIDIA Jetson AGX Xavier running L4T.
How to use GPUDirectRDMA correctly?
Which part do I need to edit?
This is the code I wrote.
<User Program>
#define DMA_ADDR_L 0x20000
#define DMA_ADDR_H 0x20004
typedef struct _PHYS_DMA_MEM_INFO
unsigned long memNum;
unsigned long memSize;
unsigned long long physAddr[MAX_PHYS_DMA_MEM_NUM];
unsigned long long virtAddr[MAX_PHYS_DMA_MEM_NUM];
unsigned long long userAddr[MAX_PHYS_DMA_MEM_NUM];
}PHYS_DMA_MEM_INFO;
bool DrvWrite32(int handle, unsigned int addr, unsigned int data)
int length = sizeof(unsigned int);
DRV_REG_MEM_RW Info;
Info.offset = addr;
Info.size = length;
memcpy((void *)&Info.data, (void*)&data, length);
if(ioctl(handle, IOCTL_DRV_WRITE, &Info) < 0)
return false;
return true;
int main()
uint8_t pRdma;
int nRdmaSize = 1 * 1024 * 1024;
unsigned int flag = 1;
cudaError_t ce = cudaHostAlloc((void**)&pRdma, nRdmaSize * sizeof(uint8_t), cudaHostAllocDefault);
if (ce != cudaSuccess)
qDebug() << "Allocation of src_d failed: " << ce;
return false;
CUresult cr = cuPointerSetAttribute(&flag, CU_POINTER_ATTRIBUTE_SYNC_MEMOPS, (CUdeviceptr)pRdma);
if (cr != CUDA_SUCCESS)
qDebug() << "cuPointerSetAttribute(src_d) failed: " << cr;
return false;
PHYS_DMA_MEM_INFO DevDmaMemInfo;
DevDmaMemInfo.memNum = 1;
DevDmaMemInfo.memSize = nRdmaSize;
DevDmaMemInfo.userAddr[0] = (unsigned long long)pRdma;
char strFileName[255];
sprintf(strFileName, "/dev/RDMATEST0");
int handle = open(strFileName, O_RDWR);
if(handle < 0)
return false;
if(ioctl(handle, IOCTL_DRV_GET_CUDA_DMA_MEM_INFO0, &DevDmaMemInfo) < 0)
return false;
for(int index =0; index<DevDmaPhyMemInfo.memNum; index++)
uint32_t Addr_h = ( DevDmaMemInfo.nPhysAddr[index] >> 32) & 0xffffffff;
uint32_t Addr_l = ( DevDmaMemInfo.nPhysAddr[index] >> 0) & 0xffffffff;
DrvWrite32(handle, DMA_ADDR_H +0x8 * index, Addr_h);
DrvWrite32(handle, DMA_ADDR_L +0x8 * index, Addr_l);
return true;
<Driver Program>
#define GPU_PAGE_SHIFT 12
#define GPU_PAGE_SIZE (((u64)1) << GPU_PAGE_SHIFT)
#define GPU_PAGE_OFFSET (GPU_PAGE_SIZE - 1)
#define GPU_PAGE_MASK (~GPU_PAGE_OFFSET)
#define VENDOR_ID 0x1172
#define INTERFACE_ID 0xe00c
#define INTERFACE_CLASS 0xFF00
#define INTERFACE_NAME "RDMATEST"
struct InterfaceInfo_t
/* the kernel pci device data structure */
struct pci_dev * pcidev;
/* length of memory region. Used for error checking. */
unsigned long barlengths;
/* kernel's virtual addr. for the mapped BARs */
void * __iomem bar;
/* character device */
dev_t cdevNum;
struct cdev cdev;
struct class* ifClass;
int ifNum;
int major;
int minor;
/* Interrupt */
unsigned int ifIrqNum;
// bus num
unsigned int busNum;
struct rdmaTest_cuda_surface
u64 virtAddr;
u64 offset;
u64 len;
struct nvidia_p2p_page_table* page_table;
struct rdmaTest_userbuf_dma
dma_addr_t addr;
u64 len;
bool cuda;
int n_dmas;
struct rdmaTest_userbuf_dma *dmas;
union
struct
int to_dev;
int pagecount;
struct page **pages;
struct sg_table *sgt;
int map_ret;
} pages;
struct
struct rdmaTest_cuda_surface *cusurf;
struct nvidia_p2p_dma_mapping *map;
} cuda;
} priv;
struct InterfaceInfo_t* InterfaceInfo;
static void rdmaTest_put_userbuf_cuda(struct rdmaTest_userbuf *ubuf)
if (ubuf->priv.cuda.map)
nvidia_p2p_dma_unmap_pages(ubuf->priv.cuda.map);
static void rdmaTest_put_userbuf(struct rdmaTest_userbuf *ubuf)
if (ubuf->cuda)
rdmaTest_put_userbuf_cuda(ubuf);
kfree(ubuf->dmas);
static void rdmaTest_userbuf_add_dma_chunk(struct rdmaTest_userbuf *ubuf, dma_addr_t addr, u64 len)
struct rdmaTest_userbuf_dma *dma;
dma_addr_t end;
printk(KERN_INFO "ubuf->n_dmas : %d\n", ubuf->n_dmas);
if (ubuf->n_dmas)
dma = &ubuf->dmas[ubuf->n_dmas - 1];
end = dma->addr + dma->len;
if (addr == end)
dma->len += len;
return;
dma = &ubuf->dmas[ubuf->n_dmas];
dma->addr = addr;
dma->len = len;
ubuf->n_dmas++;
static int rdmaTest_get_userbuf_cuda(struct rdmaTest_userbuf *ubuf, struct rdmaTest_cuda_surface* cusurf, __u64 len, int to_dev)
int id, ret, i;
u64 offset, len_left;
ubuf->cuda = true;
ubuf->priv.cuda.cusurf = cusurf;
if (len > cusurf->len)
return -EINVAL;
ret = nvidia_p2p_dma_map_pages(&InterfaceInfo->pcidev->dev, cusurf->page_table, &ubuf->priv.cuda.map, to_dev ? DMA_TO_DEVICE : DMA_FROM_DEVICE);
if (ret < 0)
return ret;
ubuf->dmas = kmalloc_array(ubuf->priv.cuda.map->entries, sizeof(*ubuf->dmas), GFP_KERNEL);
if (!ubuf->dmas)
return -ENOMEM;
offset = cusurf->offset;
len_left = cusurf->len;
printk(KERN_INFO "ubuf->priv.cuda.map->entries : %d\n", ubuf->priv.cuda.map->entries);
for (i = 0; i < ubuf->priv.cuda.map->entries; i++)
dma_addr_t dma_this = ubuf->priv.cuda.map->hw_address[i];
u64 len_this = ubuf->priv.cuda.map->hw_len[i];
printk(KERN_INFO "[%d] dma_addr : %llx, len : %ld\n", i, dma_this, len_this);
dma_this += offset;
rdmaTest_userbuf_add_dma_chunk(ubuf, dma_this, len_this);
if (len_this >= len_left)
break;
len_left -= len_this;
offset = 0;
return 0;
static void rdmaTest_p2p_free_callback(void *data)
struct rdmaTest_cuda_surface *cusurf = data;
nvidia_p2p_free_page_table(cusurf->page_table);
kfree(cusurf);
static int rdmaTest_ioctl_GetCudaDMAMemInfo(unsigned long arg)
void __user *argp = (void __user *)arg;
PHYS_DMA_MEM_INFO cudaMemInfo;
struct rdmaTest_cuda_surface* cusurf;
int ret;
if (copy_from_user(&cudaMemInfo, argp, sizeof(PHYS_DMA_MEM_INFO)))
return -EFAULT;
cusurf = kzalloc(sizeof(*cusurf), GFP_KERNEL);
if (!cusurf)
return -ENOMEM;
cusurf->virtAddr = cudaMemInfo.userAddr[0] & GPU_PAGE_MASK;
cusurf->offset = cudaMemInfo.userAddr[0] & GPU_PAGE_OFFSET;
cusurf->len = cudaMemInfo.memSize;
u64 aligned_len = (cusurf->offset + cusurf->len + GPU_PAGE_SIZE - 1) & GPU_PAGE_MASK;
ret = nvidia_p2p_get_pages(cusurf->virtAddr, aligned_len, &cusurf->page_table, rdmaTest_p2p_free_callback, cusurf);
if (ret < 0)
kfree(cusurf);
return ret;
struct rdmaTest_userbuf ubuf = {0};
ret = rdmaTest_get_userbuf_cuda(&ubuf, cusurf, cudaMemInfo.memSize, 1);
if (ret)
goto put_userbuf_dst;
cudaMemInfo.physAddr[0] = ubuf.priv.cuda.map->hw_address[0];
ret = copy_to_user(argp, &cudaMemInfo, sizeof(PHYS_DMA_MEM_INFO));
put_userbuf_dst:
rdmaTest_put_userbuf(&ubuf);
return ret;
long drv_ioctl(struct file* filePtr, unsigned int cmd, unsigned long arg)
void * baseAddrPtr;
baseAddrPtr = (void*)InterfaceInfo->bar;
switch(cmd)
case IOCTL_DRV_GET_CUDA_DMA_MEM_INFO0:
return rdmaTest_ioctl_GetCudaDMAMemInfo(arg);
break;
return 0;
int pci_probe(struct pci_dev *pdev, const struct pci_device_id *id)
InterfaceInfo = NULL;
InterfaceInfo = kzalloc(sizeof(struct InterfaceInfo_t), GFP_KERNEL);
if (!InterfaceInfo)
return -1;
InterfaceInfo->pcidev = pdev;
InterfaceInfo->busNum = pdev->bus->number;
if(pci_enable_device(pdev))
return -1;
if(pci_request_regions(pdev, INTERFACE_NAME))
return -1;
unsigned long barStart = pci_resource_start(pdev, 0); //get BAR(base address register) start
unsigned long barEnd = pci_resource_end(pdev, 0);
unsigned long barLength = barEnd - barStart + 1; //pci_resource_len(struct pci_dev *pdev, int bar)
InterfaceInfo->barlengths = barLength;
if (!barStart || !barEnd)
barLength = 0;
InterfaceInfo->bar = pci_iomap(InterfaceInfo->pcidev, 0, barLength);
if (!InterfaceInfo->bar)
return -1;
InterfaceInfo->ifIrqNum = pdev->irq;
unsigned long ifId = (unsigned long)INTERFACE_ID;
if(request_irq(InterfaceInfo->ifIrqNum , drv_interrupt, IRQF_SHARED, INTERFACE_NAME, (void *)ifId) < 0)
return -1;
pci_set_master(pdev);
int minor = 0;
int major = 0;
int ifNum = -1;
int nRet = alloc_chrdev_region(&InterfaceInfo->cdevNum, minor, 1 , INTERFACE_NAME);
if (nRet < 0)
return nRet;
major = MAJOR(InterfaceInfo->cdevNum);
minor = MINOR(InterfaceInfo->cdevNum);
ifNum = MKDEV(major, minor);
InterfaceInfo->ifClass = class_create(THIS_MODULE, INTERFACE_NAME);
cdev_init(&InterfaceInfo->cdev, &fileOps);
InterfaceInfo->cdev.owner = THIS_MODULE;
InterfaceInfo->cdev.ops = &fileOps;
nRet = cdev_add(&InterfaceInfo->cdev, ifNum, 1 );
if (nRet)
return -1;
else
device_create(InterfaceInfo->ifClass, NULL, ifNum, NULL, "%s%u", INTERFACE_NAME, minor);
InterfaceInfo->ifNum = ifNum;
InterfaceInfo->major = major;
InterfaceInfo->minor = minor;
return 0;
