I have a few questions about GPU Direct RDMA
I want to use gpu direct rdma on jetson agx xavier.
So I am making a Linux kernel source by looking at an example.
But I have a few questions.
  1. Is it correct to proceed in the following order to use cuda memory as dma?
    Assign with cudaHostAlloc → cuPointerSetAttribute → nvidia_p2p_get_page → nvidia_p2p_dma_map_page
  2. If I use the nvidia_p2p_dma_map_page function, can I get the physical address of the memory allocated by cudaHostAlloc?
    (Is the hw_address variable in the struct nvidia_p2p_dma_mapping the physical address of the memory allocated by cudaHostAlloc?)
  3. If hw_address is the physical address of the memory allocated by cudaHostAlloc, is it possible to write data to hw_address to write data to cudaDMA?
  4. Why dmam_alloc_coherent in the GPUDirectRDMA example?
    Shouldn’t nvidia_p2p_dma_map_page be used to use cudaDMA?
Help me. thank you
Have you checked the below document before?
Hi, AstaLLL
I have read the documentation.
But I can’t find the answer to question 4.
Hi
Did you mean the code below?
The function is for the PCIe device.
