GPUDirect RDMA on NVIDIA Jetson AGX Xavier
Originally published at: https://developer.nvidia.com/blog/gpudirect-rdma-nvidia-jetson-agx-xavier/
Remote Direct Memory Access (RDMA) allows computers to exchange data in memory without the involvement of a CPU. The benefits include low latency and high bandwidth data exchange. GPUDirect RDMA extends the same philosophy to the GPU and the connected peripherals in Jetson AGX Xavier. GPUDirect RDMA enables a direct path for data exchange between…
Is there any benchmark between using GPUDirect RDMA or Standard DMA Transfer regarding the latency on Xavier? I am asking this because I know that in Jetson family devices, the memory is accessible with pointers between CPU and GPU (no memcopy operation is required) which means that we can use zero-copy.
thank you
