hey trying to run the tensorrt example and io keep getting this error
Any help is appreciated thanks
Converting ssd_inception_v2_coco to trt…
2020-03-25 12:56:57.029303: F tensorflow/core/util/device_name_utils.cc:92] Check failed: IsJobName(job)
Aborted (core dumped)
Some user also meet this issue. The root cause is that NMS cannot be run with CPU model on Jetson.
You can find more detail here: JetPack-4.3 for Jetson Nano
To workaround this issue, please using following patch which provided by jkjung-avt.
diff --git a/utils/od_utils.py b/utils/od_utils.py
index 2755bb5..b8ebe1b 100644
--- a/utils/od_utils.py
+++ b/utils/od_utils.py
@@ -52,7 +52,9 @@ def build_trt_pb(model_name, pb_path, download_dir='data'):
get_egohands_model(model_name)
frozen_graph_def, input_names, output_names = build_detection_graph(
config=config_path,
- checkpoint=checkpoint_path
+ checkpoint=checkpoint_path,
+ force_nms_cpu=False,
+ force_frcn2_cpu=False,
trt_graph_def = trt.create_inference_graph(
input_graph_def=frozen_graph_def,
@@ -77,8 +79,8 @@ def load_trt_pb(pb_path):
node.device = '/device:GPU:0'
if 'faster_rcnn_' in pb_path and 'SecondStage' in node.name:
- if 'NonMaxSuppression' in node.name:
- node.device = '/device:CPU:0'
+ #if 'NonMaxSuppression' in node.name:
+ # node.device = '/device:CPU:0'
with tf.Graph().as_default() as trt_graph:
tf.import_graph_def(trt_graph_def, name='')
return trt_graph
Thanks for you quick reply. He is changing the code in build trt model and loading the converted model however i am having issues in the create_inference_graph function
also making the changes he suggested results in the following error
File “/home/mehul/Robotics/jetson-detectors/src/loader/trtloader.py”, line 32, in load_model
TypeError: build_detection_graph() got an unexpected keyword argument ‘force_frcn2_cpu’
Solved! solution was to add this line force_nms_cpu=False in build_detection_graph
frozen_graph, input_names, output_names = build_detection_graph(
config=config_path,
force_nms_cpu=False
Good to know this!
Thanks to share your status with us.
