Error while installing PyCUDA
I have recently set up my xavier board.
I am getting following error while installing pycuda.
How can I resolve this issue?
Collecting pycuda
Collecting pytools>=2011.2 (from pycuda)
Collecting mako (from pycuda)
  Using cached https://files.pythonhosted.org/packages/f3/54/dbc07fbb20865d3b78fdb7cf7fa713e2cba4f87f71100074ef2dc9f9d1f7/Mako-1.1.4-py2.py3-none-any.whl
Collecting appdirs>=1.4.0 (from pycuda)
  Using cached https://files.pythonhosted.org/packages/3b/00/2344469e2084fb287c2e0b57b72910309874c3245463acd6cf5e3db69324/appdirs-1.4.4-py2.py3-none-any.whl
Collecting dataclasses>=0.7; python_version <= "3.6" (from pytools>=2011.2->pycuda)
  Using cached https://files.pythonhosted.org/packages/fe/ca/75fac5856ab5cfa51bbbcefa250182e50441074fdc3f803f6e76451fab43/dataclasses-0.8-py3-none-any.whl
Collecting numpy>=1.6.0 (from pytools>=2011.2->pycuda)
  Using cached https://files.pythonhosted.org/packages/51/60/3f0fe5b7675a461d96b9d6729beecd3532565743278a9c3fe6dd09697fa7/numpy-1.19.5.zip
Collecting MarkupSafe>=0.9.2 (from mako->pycuda)
Building wheels for collected packages: numpy
  Running setup.py bdist_wheel for numpy ... error
  Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-uv6d1d6z/numpy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/tmp64r9ehqqpip-wheel- --python-tag cp36:
  Running from numpy source directory.
  Cythonizing sources
  Processing numpy/random/_bounded_integers.pxd.in
  Processing numpy/random/bit_generator.pyx
    File "/tmp/pip-build-uv6d1d6z/numpy/tools/cythonize.py", line 59, in process_pyx
      from Cython.Compiler.Version import version as cython_version
  ModuleNotFoundError: No module named 'Cython'
  During handling of the above exception, another exception occurred:
    File "/tmp/pip-build-uv6d1d6z/numpy/tools/cythonize.py", line 235, in <module>
      main()
    File "/tmp/pip-build-uv6d1d6z/numpy/tools/cythonize.py", line 231, in main
      find_process_files(root_dir)
    File "/tmp/pip-build-uv6d1d6z/numpy/tools/cythonize.py", line 222, in find_process_files
      process(root_dir, fromfile, tofile, function, hash_db)
    File "/tmp/pip-build-uv6d1d6z/numpy/tools/cythonize.py", line 188, in process
      processor_function(fromfile, tofile)
    File "/tmp/pip-build-uv6d1d6z/numpy/tools/cythonize.py", line 64, in process_pyx
      raise OSError('Cython needs to be installed in Python as a module')
  OSError: Cython needs to be installed in Python as a module
    File "<string>", line 1, in <module>
    File "/tmp/pip-build-uv6d1d6z/numpy/setup.py", line 508, in <module>
      setup_package()
    File "/tmp/pip-build-uv6d1d6z/numpy/setup.py", line 488, in setup_package
      generate_cython()
    File "/tmp/pip-build-uv6d1d6z/numpy/setup.py", line 285, in generate_cython
      raise RuntimeError("Running cythonize failed!")
  RuntimeError: Running cythonize failed!
  Failed building wheel for numpy
  Running setup.py clean for numpy
  Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-uv6d1d6z/numpy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" clean --all:
  `setup.py clean` is not supported, use one of the following instead:
    - `git clean -xdf` (cleans all files)
    - `git clean -Xdf` (cleans all versioned files, doesn't touch
                        files that aren't checked into the git repo)
  Add `--force` to your command to use it anyway if you must (unsupported).
  Failed cleaning build dir for numpy
Failed to build numpy
Installing collected packages: dataclasses, appdirs, numpy, pytools, MarkupSafe, mako, pycuda
  Running setup.py install for numpy ... error
    Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-uv6d1d6z/numpy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-dza_wi2b-record/install-record.txt --single-version-externally-managed --compile --user --prefix=:
    Note: if you need reliable uninstall behavior, then install
    with pip instead of using `setup.py install`:
      - `pip install .`       (from a git repo or downloaded source
                               release)
      - `pip install numpy`   (last NumPy release on PyPi)
    Cythonizing sources
    numpy/random/_bounded_integers.pxd.in has not changed
        main()
        setup_package()
        generate_cython()
Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-uv6d1d6z/numpy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-dza_wi2b-record/install-record.txt --single-version-externally-managed --compile --user --prefix=" failed with error code 1 in /tmp/pip-build-uv6d1d6z/numpy/
Please install Cython first and try it again.
$ pip3 install cython
