Hello!
For inference of trt-engines (they are obtained after onnx format using trtexec) I try to use PyCuda package.
I run this command for install PyCuda:
pip3 install pycuda --user
And I get a lot of erros… Some o fthem are below…
Keyring is skipped due to an exception: Item does not exist!
Collecting pycuda
Downloading pycuda-2021.1.tar.gz (1.7 MB)
|████████████████████████████████| 1.7 MB 530 kB/s
Installing build dependencies … error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-hnlymubh/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i Simple index – setuptools wheel ‘numpy; python_version >= ‘"’“‘3.10’”’“‘’ 'numpy==1.19.5; python_version >= '”‘“‘3.8’”’“’ and python_version < '”‘“‘3.10’”’“‘’ 'numpy==1.15.4; python_version >= '”‘“‘3.7’”’“’ and python_version < '”‘“‘3.8’”’“‘’ 'numpy==1.12.1; python_version < '”‘“‘3.7’”’"‘’
cwd: None
Complete output (2489 lines):
Ignoring numpy: markers ‘python_version >= “3.10”’ don’t match your environment
Ignoring numpy: markers ‘python_version >= “3.8” and python_version < “3.10”’ don’t match your environment
Ignoring numpy: markers ‘python_version >= “3.7” and python_version < “3.8”’ don’t match your environment
Collecting setuptools
etc…
Nevertheless on the end I get:
WARNING: Discarding https://files.pythonhosted.org/packages/5a/56/4682a5118a234d15aa1c8768a528aac4858c7b04d2674e18d586d3dfda04/pycuda-2021.1.tar.gz#sha256=ab87312d0fc349d9c17294a087bb9615cffcf966ad7b115f5b051008a48dd6ed (from Links for pycuda) (requires-python:~=3.6). Command errored out with exit status 1: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-hnlymubh/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i Simple index – setuptools wheel ‘numpy; python_version >= ‘"’“‘3.10’”’“‘’ 'numpy==1.19.5; python_version >= '”‘“‘3.8’”’“’ and python_version < '”‘“‘3.10’”’“‘’ 'numpy==1.15.4; python_version >= '”‘“‘3.7’”’“’ and python_version < '”‘“‘3.8’”’“‘’ 'numpy==1.12.1; python_version < '”‘“‘3.7’”’"‘’ Check the logs for full command output.
Downloading pycuda-2020.1.tar.gz (1.6 MB)
|████████████████████████████████| 1.6 MB 13.9 MB/s
Requirement already satisfied: pytools>=2011.2 in /usr/local/lib/python3.6/dist-packages (from pycuda) (2021.2.7)
Requirement already satisfied: decorator>=3.2.0 in /usr/lib/python3/dist-packages (from pycuda) (4.1.2)
Requirement already satisfied: appdirs>=1.4.0 in /usr/local/lib/python3.6/dist-packages (from pycuda) (1.4.4)
Requirement already satisfied: mako in /usr/lib/python3/dist-packages (from pycuda) (1.0.7)
Requirement already satisfied: numpy>=1.6.0 in /usr/local/lib/python3.6/dist-packages (from pytools>=2011.2->pycuda) (1.19.4)
Requirement already satisfied: dataclasses>=0.7 in /usr/local/lib/python3.6/dist-packages (from pytools>=2011.2->pycuda) (0.8)
Building wheels for collected packages: pycuda
Building wheel for pycuda (setup.py) … done
Created wheel for pycuda: filename=pycuda-2020.1-cp36-cp36m-linux_aarch64.whl size=637057 sha256=900f89fca1be16d3fa4a4e5194fdc4cdc16a9180acc12a91517475c63b578ac7
Stored in directory: /home/alex283h/.cache/pip/wheels/3a/3e/e1/1054e1683e5874983562141f4dd9b5e9f5801b4a8aafab4bef
Successfully built pycuda
Installing collected packages: pycuda
Successfully installed pycuda-2020.1
It looks like th epycuda package as been install…
Could you give me advice how can I install PyCuda without this erros (correctly)?
Ot maybe can I use some another package for inference trt-engines on Jetson NX with Python?
Just check the command for NX.
You can install it with the following:
$ sudo apt-get install python3-pip
$ pip3 install Cython
$ pip3 install pycuda --user
This command (pip3 install numpy pycuda --user) gives me the next errors:
Collecting pycuda
Using cached pycuda-2021.1.tar.gz (1.7 MB)
command: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-yivouqca/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i Simple index – setuptools wheel ‘numpy; python_version >= ‘"’"‘3.10’"’"’’ ‘numpy==1.19.5; python_version >= ‘"’"‘3.8’"’"’ and python_version < ‘"’"‘3.10’"’"’’ ‘numpy==1.15.4; python_version >= ‘"’"‘3.7’"’"’ and python_version < ‘"’"‘3.8’"’"’’ ‘numpy==1.12.1; python_version < ‘"’"‘3.7’"’"’’
cwd: None
Complete output (2488 lines):
Using cached setuptools-57.2.0-py3-none-any.whl (818 kB)
Collecting wheel
Using cached wheel-0.36.2-py2.py3-none-any.whl (35 kB)
Collecting numpy==1.12.1
Using cached numpy-1.12.1.zip (4.8 MB)
Building wheels for collected packages: numpy
Building wheel for numpy (setup.py): started
Building wheel for numpy (setup.py): still running…
Building wheel for numpy (setup.py): finished with status ‘error’
command: /usr/bin/python3 -u -c ‘import io, os, sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/tmp/pip-install-gt4iqm1r/numpy_4ffb26f2b4e3445eb0bec93cb49f69dc/setup.py’"’"’; file=’"’"’/tmp/pip-install-gt4iqm1r/numpy_4ffb26f2b4e3445eb0bec93cb49f69dc/setup.py’"’"’;f = getattr(tokenize, ‘"’"‘open’"’"’, open)(file) if os.path.exists(file) else io.StringIO(’"’"‘from setuptools import setup; setup()’"’"’);code = f.read().replace(’"’"’\r\n’"’"’, ‘"’"’\n’"’"’);f.close();exec(compile(code, file, ‘"’"‘exec’"’"’))’ bdist_wheel -d /tmp/pip-wheel-ig5n9soi
cwd: /tmp/pip-install-gt4iqm1r/numpy_4ffb26f2b4e3445eb0bec93cb49f69dc/
Complete output (2152 lines):
Running from numpy source directory.
blas_opt_info:
blas_mkl_info:
libraries mkl_rt not found in [’/usr/local/lib’, ‘/usr/lib’, ‘/usr/lib/aarch64-linux-gnu’]
NOT AVAILABLE
blis_info:
…etc…
WARNING: Discarding https://files.pythonhosted.org/packages/5a/56/4682a5118a234d15aa1c8768a528aac4858c7b04d2674e18d586d3dfda04/pycuda-2021.1.tar.gz#sha256=ab87312d0fc349d9c17294a087bb9615cffcf966ad7b115f5b051008a48dd6ed (from Links for pycuda) (requires-python:~=3.6). Command errored out with exit status 1: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-yivouqca/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i Simple index – setuptools wheel ‘numpy; python_version >= ‘“’”‘3.10’“’”’’ ‘numpy==1.19.5; python_version >= ‘“’”‘3.8’“’”’ and python_version < ‘“’”‘3.10’“’”’’ ‘numpy==1.15.4; python_version >= ‘“’”‘3.7’“’”’ and python_version < ‘“’”‘3.8’“’”’’ ‘numpy==1.12.1; python_version < ‘“’”‘3.7’“’”’’ Check the logs for full command output.
Using cached pycuda-2020.1-cp36-cp36m-linux_aarch64.whl
Now pycuda appeared in list of packages, but I surprised the huge number of errors while install… Is it ok??
Please also check Run model engine on Jetson NX win Python for information.
NOT AVAILABLE
The error is related to NumPy that complains about a missing library.
To solve this issue, you can install all the dependencies and try it again.
sudo apt-get update
sudo apt-get install -y build-essential libatlas-base-dev
sudo apt-get install libatlas-base-dev gfortran
Since NumPy is a frequently used library, you may already have a workable version in the environment.
Thank you! I will try to do it.
