NX default is python3.6, but to low, so i install with “atp install python3.8”. but not to work as flow:
Successfully installed setuptools-53.0.0
e]0;root@b1f3bd116116: /opt/srcroot@b1f3bd116116:/opt/src# pip3 install --upgrade setuptoolsr myrequirements.txt
Collecting matplotlib>=3.2.2 (from -r myrequirements.txt (line 6))
Using cached https://files.pythonhosted.org/packages/22/d4/e7ca532e68a9357742604e1e4ae35d9c09a4a810de39a9d80402bd12f50f/matplotlib-3.3.4.tar.gz
Complete output from command python setup.py egg_info:
ERROR: Failed to build one or more wheels
File “/usr/local/lib/python3.8/dist-packages/setuptools/installer.py”, line 75, in fetch_build_egg
subprocess.check_call(cmd)
File “/usr/lib/python3.8/subprocess.py”, line 364, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command ‘[’/usr/bin/python3.8’, ‘-m’, ‘pip’, ‘–disable-pip-version-check’, ‘wheel’, ‘–no-deps’, ‘-w’, ‘/tmp/tmpfwuwxqfm’, ‘–quiet’, ‘numpy>=1.15’]’ returned non-zero exit status 1.
The above exception was the direct cause of the following exception:
File "<string>", line 1, in <module>
File "/tmp/pip-build-atrkgz3i/matplotlib/setup.py", line 256, in <module>
setup( # Finally, pass this all along to distutils to do the heavy lifting.
File "/usr/local/lib/python3.8/dist-packages/setuptools/__init__.py", line 152, in setup
_install_setup_requires(attrs)
File "/usr/local/lib/python3.8/dist-packages/setuptools/__init__.py", line 147, in _install_setup_requires
dist.fetch_build_eggs(dist.setup_requires)
File "/usr/local/lib/python3.8/dist-packages/setuptools/dist.py", line 686, in fetch_build_eggs
resolved_dists = pkg_resources.working_set.resolve(
File "/usr/local/lib/python3.8/dist-packages/pkg_resources/__init__.py", line 766, in resolve
dist = best[req.key] = env.best_match(
File "/usr/local/lib/python3.8/dist-packages/pkg_resources/__init__.py", line 1051, in best_match
return self.obtain(req, installer)
File "/usr/local/lib/python3.8/dist-packages/pkg_resources/__init__.py", line 1063, in obtain
return installer(requirement)
File "/usr/local/lib/python3.8/dist-packages/setuptools/dist.py", line 745, in fetch_build_egg
return fetch_build_egg(self, req)
File "/usr/local/lib/python3.8/dist-packages/setuptools/installer.py", line 77, in fetch_build_egg
raise DistutilsError(str(e)) from e
distutils.errors.DistutilsError: Command '['/usr/bin/python3.8', '-m', 'pip', '--disable-pip-version-check', 'wheel', '--no-deps', '-w', '/tmp/tmpfwuwxqfm', '--quiet', 'numpy>=1.15']' returned non-zero exit status 1.
Edit setup.cfg to change the build options; suppress output with --quiet.
BUILDING MATPLOTLIB
matplotlib: yes [3.3.4]
python: yes [3.8.0 (default, Oct 28 2019, 16:14:01) [GCC 8.3.0]]
platform: yes [linux]
sample_data: yes [installing]
tests: no [skipping due to configuration]
macosx: no [Mac OS-X only]
Command “python setup.py egg_info” failed with error code 1 in /tmp/pip-build-atrkgz3i/matplotlib/
e]0;root@b1f3bd116116: /opt/srcroot@b1f3bd116116:/opt/src# pip3 install -r myrequirements.txt matplotlib>=3.2.2
Could not open requirements file: [Errno 2] No such file or directory: ‘matplotlib’
e]0;root@b1f3bd116116: /opt/srcroot@b1f3bd116116:/opt/src# pip3 install -r matplotlib>=3.2.2
Command “python setup.py egg_info” failed with error code 1 in /tmp/pip-build-it64iglw/matplotlib/
e]0;root@b1f3bd116116: /opt/srcroot@b1f3bd116116:/opt/src# pip3 install matplotlib>=3.2.2 un
Cannot uninstall requirement matplotlib, not installed
e]0;root@b1f3bd116116: /opt/srcroot@b1f3bd116116:/opt/src# pip3 install neuralpy
Collecting neuralpy
Downloading https://files.pythonhosted.org/packages/aa/6f/5d4f1c90fd944108d63428a33fae99d931da110cf13a8c64991474d87f90/neuralpy-1.3.0.tar.gz
File “”, line 1, in
File “/tmp/pip-build-3wd4hruu/neuralpy/setup.py”, line 2
print find_packages(exclude=[‘DEPneuralpy’])
SyntaxError: invalid syntax
Command “python setup.py egg_info” failed with error code 1 in /tmp/pip-build-3wd4hruu/neuralpy/
e]0;root@b1f3bd116116: /opt/srcroot@b1f3bd116116:/opt/src# pip install --upgrade setuptools --user python3.83
Requirement already up-to-date: setuptools in /usr/local/lib/python3.8/dist-packages
Collecting python3.8
Exception:
File “/usr/lib/python3/dist-packages/pip/basecommand.py”, line 215, in main
status = self.run(options, args)
File “/usr/lib/python3/dist-packages/pip/commands/install.py”, line 353, in run
wb.build(autobuilding=True)
File “/usr/lib/python3/dist-packages/pip/wheel.py”, line 749, in build
self.requirement_set.prepare_files(self.finder)
File “/usr/lib/python3/dist-packages/pip/req/req_set.py”, line 376, in prepare_files
discovered_reqs.extend(self._prepare_file(
File “/usr/lib/python3/dist-packages/pip/req/req_set.py”, line 551, in _prepare_file
req_to_install.populate_link(
File “/usr/lib/python3/dist-packages/pip/req/req_install.py”, line 278, in populate_link
self.link = finder.find_requirement(self, upgrade)
File “/usr/lib/python3/dist-packages/pip/index.py”, line 465, in find_requirement
all_candidates = self.find_all_candidates(req.name)
File “/usr/lib/python3/dist-packages/pip/index.py”, line 423, in find_all_candidates
for page in self._get_pages(url_locations, project_name):
File “/usr/lib/python3/dist-packages/pip/index.py”, line 568, in _get_pages
page = self._get_page(location)
File “/usr/lib/python3/dist-packages/pip/index.py”, line 683, in _get_page
return HTMLPage.get_page(link, session=self.session)
File “/usr/lib/python3/dist-packages/pip/index.py”, line 795, in get_page
resp.raise_for_status()
File “/usr/share/python-wheels/requests-2.18.4-py2.py3-none-any.whl/requests/models.py”, line 935, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 404 Client Error: Not Found for url: https://pypi.org/simple/python3-8/
e]0;root@b1f3bd116116: /opt/srcroot@b1f3bd116116:/opt/src# pip3 install --upgrade setuptools --user python3.8
Collecting python3
Exception:
requests.exceptions.HTTPError: 404 Client Error: Not Found for url: https://pypi.org/simple/python3/
