error while loading shared libraries: libcudart.so.4: cannot open shared object file: No such file o
I am trying to run the following program. It contains OpenMPI and CUDA code.
#include <stdio.h>
#include <stdlib.h>
#include <cuda.h>
#include <cuda_runtime.h>
#include <sys/time.h>
#include <mpi.h>
#define NREPEAT 10
#define NBYTES 10.e6
int main (int argc, char *argv[])
int rank, size, n, len, numbytes;
void *a_h, *a_d;
struct timeval time[2];
double bandwidth;
char name[MPI_MAX_PROCESSOR_NAME];
MPI_Status status;
MPI_Init (&argc, &argv);
MPI_Comm_rank (MPI_COMM_WORLD, &rank);
MPI_Comm_size (MPI_COMM_WORLD, &size);
MPI_Get_processor_name(name, &len);
printf("Process %d is on %s\n", rank, name);
printf("Using regular memory \n");
a_h = malloc(NBYTES);
cudaMalloc( (void **) &a_d, NBYTES);
/* Test host -> device bandwidth. */
MPI_Barrier(MPI_COMM_WORLD);
gettimeofday(&time[0], NULL);
for (n=0; n<NREPEAT; n )
cudaMemcpy(a_d, a_h, NBYTES, cudaMemcpyHostToDevice);
gettimeofday(&time[1], NULL);
bandwidth = time[1].tv_sec - time[0].tv_sec;
bandwidth = 1.e-6*(time[1].tv_usec - time[0].tv_usec);
bandwidth = NBYTES*NREPEAT/1.e6/bandwidth;
printf("Host->device bandwidth for process %d: %f MB/sec\n",rank,bandwidth);
/* Test MPI send/recv bandwidth. */
if (rank == 0)
MPI_Send(a_h, NBYTES/sizeof(int), MPI_INT, 1, 0, MPI_COMM_WORLD);
else
MPI_Recv(a_h, NBYTES/sizeof(int), MPI_INT, 0, 0, MPI_COMM_WORLD, &status);
if (rank == 0)
printf("MPI send/recv bandwidth: %f MB/sec\n", bandwidth);
cudaFree(a_d);
free(a_h);
MPI_Finalize();
return 0;
To compile I am using :
mpicc mpibandwidth.c -o mpibandwidth -I /usr/local/cuda/include -L /usr/local/cuda/lib -lcudart
To execute I am using :
/usr/local/bin/mpirun --mca btl tcp,self --mca btl_tcp_if_include eth0 --hostfile slaves -np 5 mpibandwidth
I am getting error after executing :
error while loading shared libraries: libcudart.so.4: cannot open shared object file: No such file or directory
My PATH and LD_LIBRARY_PATH variables are:
PATH = /usr/lib/qt-3.3/bin:/usr/local/ns-allinone/bin:/usr/local/ns-allinone/tcl8.4.18/unix:/usr/local/ns-allinone/tk8.4.18/unix:/usr/local/cuda/cuda/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/sbin:/sbin:/usr/local/lib/:/usr/local/lib/openmpi:/usr/local/cuda/bin
LD_LIBRARY_PATH = :/usr/local/lib:/usr/local/lib/openmpi/:/usr/local/cuda/lib
libcudart.so.4 is present in usr/local/cuda/lib and it is in LD path
Any idea what is missing?
Can someone help please
Are you on a 32 bit system?
If you are on a 64 bit system the link should be -L/usr/local/cuda/lib64.
Is the library present on the “slaves” systems?
What is the output on ldd on the remote systems when you run through ssh (" ssh slave0 ldd mpibandwidth", assuming slave0 is the name of one of the 5 systems in slaves)?
The machine is 64 bit but installed cuda is 32 bit.
Yes all the machines have same installation and path variables.
Although , ssh slave01 ldd mpibandwidth.exe gives me
ldd : ./mpibadwidth.exe no such file or directory :sad:
Any ideas?
Your executable is called mpibandwidth not mpibandwidth.exe ( you are specifying -o mpibandwidth when you compile).
Mixing 64-bit libraries and 32-bit libraries is not a good idea (mpicc is probably compiling for a 64 bit target).
Do a “file mpibandwidth” to see if your executable is 32 or 64 bit.
M
Sorry for the confusion.
Even ssh slave0 ldd mpibandwidth gives same error
ldd : ./mpibadwidth no such file or directory
file mpibandwidth gives
mpibandwidth: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.18, not stripped
I have several other Openmpi programs which work fine on slaves using shared libraries.
Is LD_LIBRARY_PATH properly set on the slaves?
BTW, with 32 bit executables you will not be able to use the new GPU-aware MPI.
The code you are trying to run is correct ( it was written in my group and we use it routinely to check clusters), so the problem
is in your set up.
Yes the LD paths are correctly set on slaves.
I got this sample code from this forum and i just want to test my cluster setup is correct.
“32 bit executables you will not be able to use the new GPU-aware MPI” - What does this actually means? Any alternatives for this?
I am using mpi 1.4.5 and cuda 4.1 toolkit
Would it work if I keep mpi and cuda code separately and then compile them into single object file?
When I run that executable on only one machine it works. If it works on 1 machines it should work on cluster? all machines have same configuration.
