I’ve just installed Ubuntu 10.10 64 the 64 bit cudatools and devdriver 64. I have code that compiles and runs on 10.10 32. The code compiles on the 64 bit machine OK but gives the error message error while loading shared libraries: libcudart.so.3: cannot open shared object file: No such file or directory. The LD_LIBRARY_PATH is set to the required /usr/local/cuda/lib64. I’ve also tried /usr/local/cuda/lib to no avail. the PATH contains /usr/local/cuda/bin nvcc is found OK. Is Ubunto 10.10 64 incompatible? Do I need to go back to 32 bit operating system. Graphically the card works OK.
Any thoughts
Ben External Image
Any thoughts
Ben External Image
I don’t if this helps any but here’s the modprobe results
ben@ben-GA-MA78LMT-S2:~$ sudo modprobe -l | grep nvid
kernel/drivers/video/backlight/mbp_nvidia_bl.ko
kernel/drivers/video/nvidia/nvidiafb.ko
kernel/drivers/video/nvidia.ko
Got it fixed.
Got it fixed.
I’m experiencing the exact same problem on Ubuntu 10.10 64bit. Although the PATH and LD_LIBRARY_PATH are set correctly it still complains about not finding libcudart.so.3 . Would you mind to share how you got it fixed?
Thanks in advance!
Thanks in advance!
Ok I got it fixed now :).
The problem was of course with the LD_LIBRARY_PATH. I originally prepended the $LD_LIBRARY_PATH like this in my .bashrc file:
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/cuda/lib64
But this did not work! It should look like this:
export PATH=/usr/local/cuda/bin:$PATH
export LD_LIBRARY_PATH=/usr/local/cuda/lib64:$LD_LIBRARY_PATH
Then just logout and login again and all worked fine.
