Hello. I found a GitHub rep and I am trying to run the python code on my Ubuntu machine. The rep is an application of Yolo model for face detection with DeepStream. However, every time I try to run the code I am getting the following error.
WARNING: …/nvdsinfer/nvdsinfer_model_builder.cpp:1487 Deserialize engine failed because file path: /home/ubuntu/DeepStream-Yolo-Face/yolov8n-face.onnx_b1_gpu0_fp32.engine open error
0:00:01.434567838 4366 0x2db0260 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1976> [UID = 1]: deserialize engine from file :/home/ubuntu/DeepStream-Yolo-Face/yolov8n-face.onnx_b1_gpu0_fp32.engine failed
0:00:01.484250357 4366 0x2db0260 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2081> [UID = 1]: deserialize backend context from engine from file :/home/ubuntu/DeepStream-Yolo-Face/yolov8n-face.onnx_b1_gpu0_fp32.engine failed, try rebuild
0:00:01.484263856 4366 0x2db0260 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2002> [UID = 1]: Trying to create engine from model files
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:307 Cannot access ONNX file ‘/home/ubuntu/DeepStream-Yolo-Face/yolov8n-face.onnx’
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:971 failed to build network since parsing model errors.
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:804 failed to build network.
0:00:02.667742677 4366 0x2db0260 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2022> [UID = 1]: build engine file failed
0:00:02.719529681 4366 0x2db0260 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2108> [UID = 1]: build backend context failed
0:00:02.719548264 4366 0x2db0260 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1282> [UID = 1]: generate backend failed, check config file settings
0:00:02.719748316 4366 0x2db0260 WARN nvinfer gstnvinfer.cpp:898:gst_nvinfer_start: error: Failed to create NvDsInferContext instance
0:00:02.719753855 4366 0x2db0260 WARN nvinfer gstnvinfer.cpp:898:gst_nvinfer_start: error: Config file path: config_infer_primary_yoloV8_face.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
[NvMultiObjectTracker] De-initialized
ERROR: gst-resource-error-quark: Failed to create NvDsInferContext instance (1): gstnvinfer.cpp(898): gst_nvinfer_start (): /GstPipeline:pipeline0/GstNvInfer:pgie:
