Hi, I have an SoftRoCE setup on CentOS 6.6 and its throws an error related to default_roce_mode. I have the configfs mounted and even if I try to add the version manually it throws the same error.
Here are the details -
cat /etc/*release
CentOS release 6.6 (Final)
$ ibv_devices
device node GUID
rxe0 2a6ed4fffe0feba7
mount
none on /sys/kernel/config type configfs (rw)
rxe_cfg start
IBOE V2
tee: /sys/kernel/config/rdma_cm/rxe0/default_roce_mode: Invalid argument
Name Link Driver Speed NMTU IPv4_addr RDEV RMTU
eth0 no tg3 1500
eth1 no tg3 1500
eth2 no tg3 1500
eth3 no tg3 1500
eth4 no tg3 1500
eth5 yes tg3 1500 10.213.41.228 rxe0 1024 (3)
Trying to add the version manually -
mkdir /sys/kernel/config/rdma_cm/rxe0
cat /sys/kernel/config/rdma_cm/rxe0/default_roce_mode
IB/RoCE V1
echo IBOE V2 > /sys/kernel/config/rdma_cm/rxe0/default_roce_mode
bash: echo: write error: Invalid argument
Can you please share the possible cause of this error.
