Error while using different precisions with tensor cores
Hello Guys,
I have a problem with the SimpleTensorCoreGemm code. As the documentation https://docs.nvidia.com/cuda/cuda-c-programming-guide/index.html#wmma says it’s possible to declare the fragments with different precisions. The code runs perfectly if I use float or half, but with int, unsigned char and signed char it doesn’t works.
My code:
#include <stdio.h>
#include <curand.h>
#include <cublas_v2.h>
// Define some error checking macros.
#define cudaErrCheck(stat) { cudaErrCheck_((stat), __FILE__, __LINE__); }
void cudaErrCheck_(cudaError_t stat, const char *file, int line) {
   if (stat != cudaSuccess) {
      fprintf(stderr, "CUDA Error: %s %s %d\n", cudaGetErrorString(stat), file, line);
#define cublasErrCheck(stat) { cublasErrCheck_((stat), __FILE__, __LINE__); }
void cublasErrCheck_(cublasStatus_t stat, const char *file, int line) {
   if (stat != CUBLAS_STATUS_SUCCESS) {
      fprintf(stderr, "cuBLAS Error: %d %s %d\n", stat, file, line);
#define curandErrCheck(stat) { curandErrCheck_((stat), __FILE__, __LINE__); }
void curandErrCheck_(curandStatus_t stat, const char *file, int line) {
   if (stat != CURAND_STATUS_SUCCESS) {
      fprintf(stderr, "cuRand Error: %d %s %d\n", stat, file, line);
#include <mma.h>
using namespace nvcuda;
// Must be multiples of 16 for wmma code to work
#define MATRIX_M 16384
#define MATRIX_N 16384
#define MATRIX_K 16384
// The only dimensions currently supported by WMMA
const int WMMA_M = 16;
const int WMMA_N = 16;
const int WMMA_K = 16;
__global__ void wmma_example(half *a, half *b, float *c, int M, int N, int K, float alpha, float beta) {
   // Leading dimensions. Packed with no transpositions.
   int lda = M;
   int ldb = K;
   int ldc = M;
   // Tile using a 2D grid
   int warpM = (blockIdx.x * blockDim.x + threadIdx.x) / warpSize;
   int warpN = (blockIdx.y * blockDim.y + threadIdx.y);
   //Declare the fragments
   wmma::fragment<wmma::matrix_a, WMMA_M, WMMA_N, WMMA_K, half, wmma::col_major> a_frag;
   wmma::fragment<wmma::matrix_b, WMMA_M, WMMA_N, WMMA_K, half, wmma::col_major> b_frag;
   wmma::fragment<wmma::accumulator, WMMA_M, WMMA_N, WMMA_K, int> acc_frag;
   wmma::fragment<wmma::accumulator, WMMA_M, WMMA_N, WMMA_K, float> c_frag;
   wmma::fill_fragment(acc_frag, 0.0f);
   // Loop over k
   for (int i = 0; i < K; i += WMMA_K) {
      int aRow = warpM * WMMA_M;
      int aCol = i;
      int bRow = i;
      int bCol = warpN * WMMA_N;
      // Bounds checking
      if (aRow < M && aCol < K && bRow < K && bCol < N) {
         // Load the inputs
         wmma::load_matrix_sync(a_frag, a + aRow + aCol * lda, lda);
         wmma::load_matrix_sync(b_frag, b + bRow + bCol * ldb, ldb);
         // Perform the matrix multiplication
         wmma::mma_sync(acc_frag, a_frag, b_frag, acc_frag);
   // Load in the current value of c, scale it by beta, and add this our result scaled by alpha
   int cRow = warpM * WMMA_M;
   int cCol = warpN * WMMA_N;
   if (cRow < M && cCol < N) {
      wmma::load_matrix_sync(c_frag, c + cRow + cCol * ldc, ldc, wmma::mem_col_major);
for(int i=0; i < c_frag.num_elements; i++) {
         c_frag.x[i] = alpha * acc_frag.x[i] + beta * c_frag.x[i];
      // Store the output
      wmma::store_matrix_sync(c + cRow + cCol * ldc, c_frag, ldc, wmma::mem_col_major);
__global__ void convertFp32ToFp16 (half *out, float *in, int n) {
   int idx = blockDim.x * blockIdx.x + threadIdx.x;
   if (idx < n) {
      out[idx] = in[idx];
int main(int argc, char* argv[]) {
   float *a_fp32;
   float *b_fp32;
   half *a_fp16;
   half *b_fp16;
   float *c;
   float *c_cublas;
   float *c_wmma;
   float *c_host_cublas;
   float *c_host_wmma;
   curandGenerator_t gen;
   cublasHandle_t cublasHandle;
   cudaEvent_t startWMMA;
   cudaEvent_t stopWMMA;
   cudaEvent_t startcublas;
   cudaEvent_t stopcublas;
   cudaErrCheck(cudaEventCreate(&startWMMA));
   cudaErrCheck(cudaEventCreate(&stopWMMA));
   cudaErrCheck(cudaEventCreate(&startcublas));
   cudaErrCheck(cudaEventCreate(&stopcublas));
cublasErrCheck(cublasCreate(&cublasHandle));
   // Use tensor cores
   cublasErrCheck(cublasSetMathMode(cublasHandle, CUBLAS_TENSOR_OP_MATH));
   cudaErrCheck(cudaMalloc((void**)&a_fp32, MATRIX_M * MATRIX_K * sizeof(float)));
   cudaErrCheck(cudaMalloc((void**)&b_fp32, MATRIX_K * MATRIX_N * sizeof(float)));
   cudaErrCheck(cudaMalloc((void**)&a_fp16, MATRIX_M * MATRIX_K * sizeof(half)));
   cudaErrCheck(cudaMalloc((void**)&b_fp16, MATRIX_K * MATRIX_N * sizeof(half)));
   cudaErrCheck(cudaMalloc((void**)&c, MATRIX_M * MATRIX_N * sizeof(float)));
   cudaErrCheck(cudaMalloc((void**)&c_cublas, MATRIX_M * MATRIX_N * sizeof(float)));
   cudaErrCheck(cudaMalloc((void**)&c_wmma, MATRIX_M * MATRIX_N * sizeof(float)));
   c_host_cublas = (float*)malloc(MATRIX_M * MATRIX_N * sizeof(float));
   c_host_wmma = (float*)malloc(MATRIX_M * MATRIX_N * sizeof(float));
   curandErrCheck(curandCreateGenerator(&gen, CURAND_RNG_PSEUDO_DEFAULT));
   curandErrCheck(curandSetPseudoRandomGeneratorSeed(gen, 1337ULL));
   curandErrCheck(curandGenerateUniform(gen, a_fp32, MATRIX_M * MATRIX_K));
   curandErrCheck(curandGenerateUniform(gen, b_fp32, MATRIX_K * MATRIX_N));
   // curand doesn't currently support fp16 so we generate in fp32 and convert to fp16.
   convertFp32ToFp16 <<< (MATRIX_M * MATRIX_K + 255) / 256, 256 >>> (a_fp16, a_fp32, MATRIX_M * MATRIX_K);
   convertFp32ToFp16 <<< (MATRIX_K * MATRIX_N + 255) / 256, 256 >>> (b_fp16, b_fp32, MATRIX_K * MATRIX_N);
   curandErrCheck(curandGenerateUniform(gen, c, MATRIX_M * MATRIX_N));
   curandErrCheck(curandDestroyGenerator(gen));
   cudaErrCheck(cudaMemcpy(c_cublas, c, MATRIX_M * MATRIX_N * sizeof(float), cudaMemcpyDeviceToDevice));
   cudaErrCheck(cudaMemcpy(c_wmma, c, MATRIX_M * MATRIX_N * sizeof(float), cudaMemcpyDeviceToDevice));
   float alpha = 2.0f;
   float beta = 2.0f;
printf("\nM = %d, N = %d, K = %d. alpha = %f, beta = %f\n\n", MATRIX_M, MATRIX_N, MATRIX_K, alpha, beta);
   // First: using WMMA
   dim3 gridDim;
   dim3 blockDim;
   // blockDim.x must be a multple of warpSize
   // 128x4 means we have 16 warps and a block computes a 64x64 output tile
   blockDim.x = 128;
   blockDim.y = 4;
   gridDim.x = (MATRIX_M + (WMMA_M * blockDim.x / 32 - 1)) / (WMMA_M * blockDim.x / 32);
   gridDim.y = (MATRIX_N + WMMA_N * blockDim.y - 1) / (WMMA_N * blockDim.y);
   printf("Running with wmma...\n");
   cudaErrCheck(cudaEventRecord(startWMMA));
   wmma_example <<< gridDim, blockDim >>> (a_fp16, b_fp16, c_wmma, MATRIX_M, MATRIX_N, MATRIX_K, alpha, beta);
   cudaErrCheck(cudaEventRecord(stopWMMA));
// Now using cuBLAS
   printf("Running with cuBLAS...\n");
   cudaErrCheck(cudaEventRecord(startcublas));
   cublasErrCheck(cublasGemmEx(cublasHandle, CUBLAS_OP_N, CUBLAS_OP_N,
                &alpha,
                a_fp16, CUDA_R_16F, MATRIX_M,
                b_fp16, CUDA_R_16F, MATRIX_K,
                &beta,
                c_cublas, CUDA_R_32F, MATRIX_M,
                CUDA_R_32F, CUBLAS_GEMM_DFALT_TENSOR_OP));
   cudaErrCheck(cudaEventRecord(stopcublas));
   // Error checking
   printf("\nChecking results...\n");
   cudaErrCheck(cudaMemcpy(c_host_wmma, c_wmma, MATRIX_M * MATRIX_N * sizeof(float), cudaMemcpyDeviceToHost));
   cudaErrCheck(cudaMemcpy(c_host_cublas, c_cublas, MATRIX_M * MATRIX_N * sizeof(float), cudaMemcpyDeviceToHost));
   // 0.01% relative tolerance. 1e-5 absolute tolerance.
   int errors = 0;
   for (int i = 0; i < MATRIX_M * MATRIX_N; i++) {
      float v1 = c_host_wmma[i];
      float v2 = c_host_cublas[i];
      if (v1 / v2 > 1.0001 || v2 / v1 > 1.0001 || abs(v1 - v2) > 1e-5) {
         errors++;
         if (errors < 10) printf("%f %f\n", v1, v2);
   if (errors > 0) {
      printf("WMMA does not agree with cuBLAS! %d errors!\n", errors);
   else {
      printf("Results verified: cublas and WMMA agree.\n\n");
      float wmmaTime;
      float cublasTime;
      cudaErrCheck(cudaEventSynchronize(stopWMMA));
      cudaErrCheck(cudaEventSynchronize(stopcublas));
      cudaErrCheck(cudaEventElapsedTime(&wmmaTime, startWMMA, stopWMMA));
      cudaErrCheck(cudaEventElapsedTime(&cublasTime, startcublas, stopcublas));
      printf("wmma took %fms\n", wmmaTime);
      printf("cublas took %fms\n", cublasTime);
cudaErrCheck(cudaEventDestroy(startWMMA));
   cudaErrCheck(cudaEventDestroy(stopWMMA));
   cudaErrCheck(cudaEventDestroy(startcublas));
   cudaErrCheck(cudaEventDestroy(stopcublas));
   cudaErrCheck(cudaFree(a_fp32));
   cudaErrCheck(cudaFree(b_fp32));
   cudaErrCheck(cudaFree(a_fp16));
   cudaErrCheck(cudaFree(b_fp16));
   cudaErrCheck(cudaFree(c));
   cudaErrCheck(cudaFree(c_cublas));
   cudaErrCheck(cudaFree(c_wmma));
   free(c_host_cublas);
   free(c_host_wmma);
   cudaErrCheck(cudaDeviceReset());
   return 0;
Compiling I have this error:
make all
nvcc -o TCGemm -arch=sm_70 -lcublas -lcurand simpleTensorCoreGEMM.cu
simpleTensorCoreGEMM.cu(57): error: incomplete type is not allowed
1 error detected in the compilation of "/tmp/tmpxft_000025bb_00000000-8_simpleTensorCoreGEMM.cpp1.ii".
Makefile:29: recipe for target 'all' failed
make: * [all] Error 1
What could be wrong? I’m running on a Titan V
Integer operations require Geforce RTX and sm_75. Cheers.
when output half-type result to share memory with store_matrix_sync(), it works correctly on Turing GPU, but It fails on
the TitanV(Volta) GPU.
And I compiles with SM75 and SM70 for these gpus.
Are there differences for store_matrix_sync on these two different gpus?
