I’m using jetpack 4.4.1.
I ran
model.save ('path')
to save the trained efficientnet model, but it’s unclear why it’s an HDF document instead of the saved model format. Do you understand?
In short, I can’t create a folder
You may need a root authority to create a folder under some folder.
Could you give it a try?
〈effi_model_save.py〉
import os
import sys
import numpy as np
from tensorflow.keras.preprocessing import image
from keras.applications.imagenet_utils import decode_predictionsfrom efficientnet.keras import EfficientNetB2
from efficientnet.keras import preprocess_input
import tensorflow as tf
from tensorflow import kerasmodel = EfficientNetB2(weights=‘imagenet’)
save_path = ‘/home/effi_test/effi_saved_model’
model.save(save_path)
sudo python3 effi_model_save.py
I ran it with sudo as above, but got the following error:
2021-03-08 00:57:31.962215: W tensorflow/stream_executor/platform/default/dso_loader.cc:59] Could not load dynamic library ‘libcudart.so.10.2’; dlerror: libcudart.so.10.2: cannot open shared object file: No such file or directory
2021-03-08 00:57:31.962311: I tensorflow/stream_executor/cuda/cudart_stub.cc:29] Ignore above cudart dlerror if you do not have a GPU set up on your machine.
2021-03-08 00:57:31.962488: W tensorflow/stream_executor/platform/default/dso_loader.cc:59] Could not load dynamic library ‘libcudart.so.10.2’; dlerror: libcudart.so.10.2: cannot open shared object file: No such file or directory
2021-03-08 00:57:31.962529: I tensorflow/stream_executor/cuda/cudart_stub.cc:29] Ignore above cudart dlerror if you do not have a GPU set up on your machine.
Segmentation fault
By the way, I am using a docker container. The mount destination mounts /home/effi_test on the host to /home on the container.
In the case of
the folder cannot be created and it becomes an HDF document.
How can I solve it by saving it in saved model format in a container anyway?
The default format in TF 1.x is HDF5.
Could you set the save_format to tf to see if it works?
save_format Either 'tf' or 'h5', indicating whether to save the model to Tensorflow SavedModel or HDF5. Defaults to 'tf' in TF 2.X, and 'h5' in TF 1.X.
Try
model.save (save_path, save_format=‘tf’)
By the way
Looking at
https://www.tensorflow.org/versions/r1.15/api_docs/python/tf/keras/applications
it is said that efficientnet of tf.keras.applications is not supported by TF1.x and is supported by TF2.x. Since my environment is TF1.15, I don’t use
from tf.keras.applications import EfficientNetBx
, I use
from efficientnet.keras import EfficientNetBx
Are they the same?
thank you
In my environment, it is jetpack 4.4.1 with xavier AGX.
The container uses ceai3216217 / j44_tf2.3.0: v1 (built by changing the wheel version of Dockerfile.tensorflow to tensorflow2.3.0)
・Start the container and pip3 install pillow
・When I ran pred.py the time for 100 inferences was about 20 seconds.
・Then save the trained model with effi_model_save.py
・Then convert the trained model with tf_convert.py
・Finally run suiron_rt.py. The inference time of 100 times is 269 seconds, which is considerably slower than the normal pred.py.
I don’t know the cause.
〈pred.py〉
import os
import sys
import numpy as np
from tensorflow.keras.applications.efficientnet import preprocess_input, decode_predictions
import timemodel = tf.keras.applications.EfficientNetB2(weights=‘imagenet’)
img_path = ‘./panda.jpg’
img = image.load_img(img_path, target_size=(260, 260))
x = image.img_to_array(img)
x = np.expand_dims(x, axis=0)
x = preprocess_input(x)
x = tf.constant(x)start = time.time()
for ii in range(100):
y = model.predict(x,steps=1)
elapsed_time = time.time() - start
print (“elapsed_time:{0}”.format(elapsed_time) + “[sec]”)print(decode_predictions(y))
import os
import sys
import numpy as np
import tensorflow as tfsave_path = ‘effi_saved_model’
〈tf_convert.py〉
import os
import sys
from tensorflow.python.compiler.tensorrt import trt_convert as trtload_path = ‘effi_saved_model’
save_path = ‘effi_saved_model_TFTRT’conversion_params = trt.DEFAULT_TRT_CONVERSION_PARAMS._replace(precision_mode=trt.TrtPrecisionMode.FP16,max_workspace_size_bytes=8000000000)
converter = trt.TrtGraphConverterV2(input_saved_model_dir=load_path, conversion_params=conversion_params)
converter.convert()
converter.save(output_saved_model_dir=save_path)
〈suiron_rt.py〉
from future import absolute_import, division, print_function, unicode_literals
import os
import sys
import numpy as np
import timefrom tensorflow.python.compiler.tensorrt import trt_convert as trt
from tensorflow.python.saved_model import tag_constantsdef predict_tftrt(input_saved_model):
x = tf.constant(x)saved_model_loaded = tf.saved_model.load(input_saved_model, tags=[tag_constants.SERVING]) signature_keys = list(saved_model_loaded.signatures.keys()) #print(signature_keys) infer = saved_model_loaded.signatures['serving_default'] #print(infer.structured_outputs) start = time.time() for ii in range(100): labeling = infer(x) elapsed_time = time.time() - start print ("elapsed_time:{0}".format(elapsed_time) + "[sec]") preds = labeling['predictions'].numpy() print('{} - Predicted: {}'.format(img_path, decode_predictions(preds, top=3)[0]))input_saved_model=“effi_saved_model_TFTRT”
I don’t understand why the inference time of TF-TRT is slow
Do you maximize the device performance first?
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
Originally, power_mode was performed as instructed by 0: MAXN, but no effect was obtained.
Do you also fix the clock to maximal with jetson_clocks.
To figure the bottleneck, it’s recommended to run your application with our profiler first.
https://developer.nvidia.com/tools-overview
