I want to replicate the behavior of the OmniGraph node “On Playback Tick” inside an Omniverse extension (not OmniGraph related). The handler should be called on each tick only when playback is active. How would I implement that? I have seen the subscriptions described here: Event streams — kit-manual 104.0 documentation
But I am not sure if that is the right thing to use. For example, it does not seem to take the playback state into consideration.
Bruno
