Example code licensing
the code examples like the “gst-plugins/gst-dsexample” contain a NVIDIA licensing banner that states that modified derivates need to retain this license, ie. that code deriving from this samples need to be open source too.
This sounds like a really bad idea for sample code since this would mean one has to write a new Gst plugin from scratch in order to create a closed source custom element, instead of deriving the official samples.
Could the copyright banners please be changed by NVIDIA?
+1
Sorry for late response!
Will check and get back to you ASAP.
Hello user,
According to our EULA, you are allow to modify any code and distribute it as a binary. The licensing banner only applies if you plan to distribute the source code.
I would recommend reading the licensing term in our the EULA.
Thanks,
Chintan
