I am following Victor Gordan’s tutorial on OpenGL. Everything has been going smoothly until I’ve encountered a strange error to which I couldn’t find a solution anywhere. The IDE is VS Community 2022 and I’m using it’s built-in debugger. The debugger is flagging an exception on Line 37 ‘glGenerateMipmap(GL_TEXTURE_2D);’ and it’s contents are: Exception thrown at 0x00007FF891080BDB (nvoglv64.dll) in OpenGL.exe: 0xC0000005: Access violation reading location 0x0000021123175000. Full Texture Class code:
#include"Texture.h"
Texture::Texture(const char* image, GLenum texType, GLenum slot, GLenum format, GLenum pixelType)
// Assigns the type of the texture ot the texture object
type = texType;
// Stores the width, height, and the number of color channels of the image
int widthImg, heightImg, numColCh;
// Flips the image so it appears right side up
stbi_set_flip_vertically_on_load(true);
// Reads the image from a file and stores it in bytes
unsigned char* bytes = stbi_load(image, &widthImg, &heightImg, &numColCh, 0);
if (!bytes) std::cout << "wtf";
// Generates an OpenGL texture object
glGenTextures(1, &ID);
// Assigns the texture to a Texture Unit
glActiveTexture(slot);
glBindTexture(texType, ID);
// Configures the type of algorithm that is used to make the image smaller or bigger
glTexParameteri(texType, GL_TEXTURE_MIN_FILTER, GL_NEAREST_MIPMAP_LINEAR);
glTexParameteri(texType, GL_TEXTURE_MAG_FILTER, GL_NEAREST);
// Configures the way the texture repeats (if it does at all)
glTexParameteri(texType, GL_TEXTURE_WRAP_S, GL_REPEAT);
glTexParameteri(texType, GL_TEXTURE_WRAP_T, GL_REPEAT);
// Extra lines in case you choose to use GL_CLAMP_TO_BORDER
// float flatColor[] = {1.0f, 1.0f, 1.0f, 1.0f};
// glTexParameterfv(GL_TEXTURE_2D, GL_TEXTURE_BORDER_COLOR, flatColor);
// Assigns the image to the OpenGL Texture object
glTexImage2D(texType, 0, GL_RGBA, widthImg, heightImg, 0, format, pixelType, bytes);
// Generates MipMaps
// Deletes the image data as it is already in the OpenGL Texture object
stbi_image_free(bytes);
// Unbinds the OpenGL Texture object so that it can't accidentally be modified
glBindTexture(texType, 0);
void Texture::texUnit(Shader& shader, const char* uniform, GLuint unit)
// Gets the location of the uniform
GLuint texUni = glGetUniformLocation(shader.ID, uniform);
// Shader needs to be activated before changing the value of a uniform
shader.Activate();
// Sets the value of the uniform
glUniform1i(texUni, unit);
void Texture::Bind()
glBindTexture(type, ID);
void Texture::Unbind()
glBindTexture(type, 0);
void Texture::Delete()
glDeleteTextures(1, &ID);
