To answer your question, we need to consider the PCIe configuration of the Jetson AGX Orin Developer Kit and the compatibility of the ConnectX-5 CX512A PCIe card.
According to the provided context, the Jetson AGX Orin Developer Kit has three PCIe controllers:
- PCIe C1: Root port, x1 link width, M.2 Key E slot (supports Wi-Fi cards)
- PCIe C4: Root port, up to x4 link width, M.2 Key M slot (supports NVMe cards)
- PCIe C5: Root port or Endpoint, up to x8 link width, PCIe slot (supports PCIe CEM endpoints, but operates in x8 mode despite being a x16 slot)
The ConnectX-5 CX512A PCIe card is a high-performance, low-latency InfiniBand and Ethernet adapter that supports RDMA. However, its compatibility with the Jetson AGX Orin Developer Kit depends on the PCIe configuration.
The ConnectX-5 CX512A card requires a PCIe x8 or x16 slot to operate at its full potential. Since the Jetson AGX Orin Developer Kit’s PCIe C5 slot is a x16 slot but operates in x8 mode, it might be possible to use the ConnectX-5 CX512A card in this slot. However, the actual performance might be limited by the x8 mode operation.
Before purchasing the ConnectX-5 CX512A card, consider the following:
- Compatibility: Verify that the ConnectX-5 CX512A card is compatible with the Jetson AGX Orin Developer Kit’s PCIe configuration. You may need to check the card’s documentation or contact the manufacturer for confirmation.
- Performance: Since the PCIe C5 slot operates in x8 mode, the ConnectX-5 CX512A card’s performance might be limited. You may need to evaluate whether the reduced performance will still meet your requirements.
- Power consumption: The ConnectX-5 CX512A card is a high-performance adapter that may require significant power. Ensure that the Jetson AGX Orin Developer Kit’s power supply can handle the additional power requirements.
- Software support: Verify that the necessary software and drivers are available for the ConnectX-5 CX512A card on the Jetson AGX Orin Developer Kit. You may need to check the manufacturer’s website or contact their support team for more information.
In summary, while it might be possible to use the ConnectX-5 CX512A PCIe card on the Jetson AGX Orin Developer Kit, you should carefully evaluate the compatibility, performance, power consumption, and software support before making a purchase.
As a comparison, you may also consider other PCIe cards that support RDMA and are specifically designed for the Jetson AGX Orin Developer Kit. These cards might be optimized for the kit’s PCIe configuration and provide better performance and compatibility.
To run the network-accelerated imx274player example, you will also need to ensure that the necessary software and drivers are installed and configured correctly on the Jetson AGX Orin Developer Kit. This may involve installing additional packages or configuring the system to use the RDMA-capable NIC.
