Hi all,
I want to exit from my program directly from kernel.
As we use exit in C.
I want to exit from kernel only!
Suppose,
global void kernel()
if(…)
//exit from the whole program
//exit() is not working inside kernel
Hi all,
Suppose,
if(…)
You can’t terminate your host process from device code.
If you want to halt a kernel execution, you can use:
assert(0);
however this corrupts the CUDA context.
As txbob says, you cannot terminate the host process from within the kernel. To exit from a kernel you could simply
return;
in every thread. If all threads need to do that in response to a special event detected by just one threads or a few threads, you may need to atomically increment a flag that all threads check periodically.
Thanks @txbob.
Thank you @njuffa(I already have that idea!).
Thanks @txbob.
