I use “return” in the kernel, as following:
__global__ void mykernel()
int i=threadIdx.x;
if(i>100) return;
When I run the kernel, i gol a lot of error.
Is it because I use “return” in the kernel?
int i=threadIdx.x;
if(i>100) return;
kernel is always void type, So cant return anything
kernel is always void type, So cant use return statement
Why not? Indeed, you can’t
return value;
But
return;
is always legal.
Regards
Navier
Yea, Navier is right. I should have say " Cant Return value"
I used to play with returns a lot with kernels, for some reason it is not mentioned at all in guides. My observations are:
It is perfectly OK to have some individual threads return early, despite what others in this thread have said. You just have to be careful with __synthreads() so you don’t cause deadlocks.
The return statement, however, does just that. Only the current thread returns. There is no way to stop an entire kernel from running with a decision made in a single thread.
