currently I am working on a project, where I have to set bits on a device array to track the code coverage of the cude code.
I have an array of a given size, which I need in device and on host.
On host, it works fine.
I declare in the normal cu files:
extern unsigned char hostArray;
and in another cu file I define it:
unsiged char hostArray[7];
The same thing I want to do is for the device.
I tried
extern device unsigned char deviceArray;
but then my system tells me: size not known.
if I declare
extern device unsigned char deviceArray[7];
it seems to let the cudaMemCpyFromSymbol fail, if I want to retrieve the data.
If I let it copy from the defining .cu-file, The array is just empty, so it seems it is only touched by the defining cuda.
I suspect both .cu-Files get their own device unsigned charArray;
TL;DR;
How can I use an array allocated on device across multiple .cu-files (just like a global c-array)?
had time to try it and it works. Thank you very much. Also works now with Unified Memory (managed)
If someone runs into similiar Problems and uses VS2013 and CUDA 7.5:
Change Project-config:
CUDA C/C+±>Device->Code Generation: Switch of inheritance and crank it up to: compute_30,sm_30 (I think this is only needed because auf managed but who knows?)
CUDA C/C+±>Common->Generate Relocatable Device Code: Yes (-rdc=true)
