I’m new to CUDA programming and still going through the documentation, and my brain is currently stuck in an infinite loop trying to understand statements in the CUDA programming guide…
@ page 29 in the pdf it is mentionned:
and later @ page 30 it is mentionned:
I don’t know but that seems like a contradiction right there… :wacko:
BTW what would be the purpose of declaring variables as extern? To ease passing parameters between functions defined in different files?
In general, device-side variables cannot be extern.
However, the first construct with the array of unspecified size is a special construct where one can specify the size of the shared memory at run time – which is useful when the required size of the shared memory isn’t known at compile-time.
