omni.add_on.ros_bridge: ROS Bridge (add-on)
This extension enables publishing additional rostopics using ROS.
GitHub links:
- README: https://github.com/Toni-SM/omni.add_on.ros_bridge
- Extension (zip file): omni.add_on.ros_bridge
GitHub links:
This extension allows publishing additional topics and enabling services for agile development of robotic application prototypes in ROS
GitHub links:
Update:
Dear community,
The extension has been rewritten to integrate the omni.add_on.ros_control_bridge extension features.
In addition, its source code has been released…
src folder)omni.add_on.ros_control_bridge)omni.add_on.ros_control_bridge)I have add the extension follow this
narwal@sz-0203062590:~/ros_bag_file/slam_0514$ rosnode info /OmniAddOnRosBridge
Node [/OmniAddOnRosBridge]
Publications:
* /rosout [rosgraph_msgs/Log]
Subscriptions: None
Services:
* /OmniAddOnRosBridge/get_loggers
* /OmniAddOnRosBridge/set_logger_level
contacting node http://sz-0203062590:39465/ ...
Pid: 101519
Connections:
* topic: /rosout
* to: /rosout
* direction: outbound (38879 - 10.1.41.40:35094) [345]
* transport: TCPROS
Hi @fzg7919
To enable the services, it is necessary to add a RosAttribute prim to the current stage and play the simulation, as shown in the following image
Sorry I don’t have RosAttribute in the ‘Create->Isaac->Ros’ ,
and I am sure the extensions are enable .
the Compressed Camera 、Follow Joint Trajectory 、Gripper Command are all normal, only Attributes lost
Hi @fzg7919
My mistake, I forgot to create the release with the compressed file for the latest version of the omni.add_on.ros_bridge_ui extension (v0.0.2)
Now, you can find it on GitHub…
In addition, you can install the extension using the link (which always pulls the latest version directly) to avoid similar situations in the future :)
git+https://github.com/Toni-SM/omni.add_on.ros_bridge_ui.git?branch=main&dir=exts
It is okay now !!! Thanks very much !!!
Dear community,
It is time to move to OmniGraph :)
This extension has been migrated to OmniGraph…
The entire source is available on https://github.com/Toni-SM/semu.robotics.ros_bridge (Note: The extension was renamed semu.robotics.ros_bridge to distinguish it from the original NVIDIA Omniverse namespaces)
