I’ve been trying to get the thumbs project working after training with a CSI camera.
It keeps freezing and I’ve read from other posts it’s likely to be due to swap.
I’ve tried to increase the size of the swap but it ends up using all the space available on the card and I can’t undo the change or install anything so have to reflash.
I’ve tried allocating the swap size when launching the container as well.
I’ve tried booting from a much faster USB and get the same result. Both sdcard and USB are 32g.
Cloning to a 64g sdcard worked a bit better, but froze too.
I was thinking, why not have the swap on a USB and the OS on the SDCard for some improvement?
I can’t understand why it runs the NVIDIA inference docker and not the simple thumbs tutorial?
Actually, it depends on the memory usage of your model.
Have you measured the memory amount of your inference task?
If not, please do so.
Since Nano only has 4GB memory, it’s more recommended to use a lightweight model.
And please noted that swap memory cannot be accessed via GPU.
This indicates if you run an inference with GPU, the available memory won’t increase by adding swap.
