I’ve been experimenting with HW-accelerated encoding pretty much non-stop ever since I got my Nano a couple weeks back.
While doing so, I noticed that sometimes, regardless of my settings or the input, the “gst-launch-1.0” process would sit idle and never finish.
I started experimenting, trying to find a pattern to this behavior, and while there are certain input files that’d ALWAYS hang, for others it’s kind of a hit or miss.
Generally speaking, if I add audio the chance of the process hanging goes up several times, and if I add audio conversion to the mix it’d hang 50% of the times, or more. Running the same command several times (in a loop or parallel) almost guarantees one of the processes would hang.
Now it’s time to get technical. I’ll try to provide every piece of information to help with recreating what I experience:
- OS: Ubuntu 18.04 (Jetson official image)
- Kernel version: 4.9.140-tegra
- Gstreamer vesion: 1.14.1
For the target video I chose the good old Big Buck Bunny (http://commondatastorage.googleapis.com/gtv-videos-bucket/sample/BigBuckBunny.mp4).
Here’s the command I use:
gst-launch-1.0 filesrc location=BigBuckBunny.mp4 ! \
qtdemux name=demux demux.video_0 ! queue ! \
h264parse ! nvv4l2decoder enable-max-performance=1 ! \
nvvidconv interpolation-method=5 ! video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12 ! \
nvv4l2h265enc bitrate=1000000 peak-bitrate=1100000 EnableTwopassCBR=1 control-rate=0 preset-level=4 \
maxperf-enable=1 iframeinterval=60 qp-range="25,35:21,28:-1,-1" ! h265parse ! queue ! \
qtmux name=mux ! filesink location=jetson-BigBuckBunny.mp4 \
demux.audio_0 ! queue ! avdec_aac ! audioconvert ! voaacenc bitrate=64000 ! aacparse ! queue ! mux.
Here’s the output of the above command:
Setting pipeline to PAUSED ...
Opening in BLOCKING MODE
Pipeline is PREROLLING ...
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading sys.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
Redistribute latency...
NvMMLiteOpen : Block : BlockType = 8
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 8
NVMEDIA: H265 : Profile : 1
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
^Chandling interrupt. <-- Terminaled by <C-c>
Interrupt: Stopping pipeline ...
Execution ended after 0:20:33.033821132 <-- Job sat idle
Setting pipeline to READY ...
And the mediainfo of the output file “jetson-BigBuckBunny.mp4”:
General
Complete name : jetson-BigBuckBunny.mp4
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt 2005.03 (qt )
File size : 31.8 MiB
Please note that I deliberately chose to present a complex example, as it’s more prone to failure.
I could recreate the problem without audio conversion and with no options set for the video encode.
For example, this command would also hang: (not necessarily on the first try)
h264parse ! nvv4l2decoder ! \
nvv4l2h265enc ! h265parse ! queue ! \
demux.audio_0 ! queue ! mux.
Investigating furthermore, I set the GST_DEBUG=3 global variable and saw the following warning:
0x7f8015a8a0 WARN v4l2bufferpool gstv4l2bufferpool.c:1483:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0x7f800034a0 FIXME h265parse gsth265parse.c:1712:gst_h265_parse_parse_frame:<h265parse0> Implement timestamp/duration interpolation based on SEI message
It’s actually similar to the warning mentioned on this thread: https://devtalk.nvidia.com/default/topic/1052057/l4t-32-1-problems-switching-from-omxh264enc-to-nvv4l2h264enc/
However, it’s on a different platform (TX2), and on H264 I also get this FIXME warning. Moreover, those messages show up even on successful tries.
Other things I did trying to mitigate the problem:
- Use queue2 instead of queue (which surprisingly improved the situation).
- Use the now deprecated OMX decoder/encoder.
- Randomly increasing buffers (since the queue is obviously getting stuck somewhere...)
I’ll appreciate any help with solving this issue :)
Thank you.
