Hi, I am writing to inquire about an issue with the NVIDIA NVHPC toolchain I initially reported in LLNL/zfp#163.
Lawrence Livermore National Laboratory’s (LLNL) ZFP conforms to the Fortran 2018 standard in its C to Fortran interface while using the c_ptrdiff_t
type from ISO_C_BINDING
as well as others already present in earlier standards. However, there currently is no support for these types. Further problems are encountered when attempting to replace them with equivalents, the callee receiving unrecognizable values. Thus, at the moment, it is not possible to compile and use a functional version of ZFP that utilizes the ZFP to Fortran interface, using NVHPC, thereby not letting users leverage Cuda GPU acceleration. I notice that OLCF’s Summit’s zfp-gpu
module does not include Fortran bindings.
These additional interoperability features, which include c_ptrdiff_t
, were initially described in TS 29113 (“Further interoperability of Fortran with C”) and were implemented by many compiler vendors as an extension to F2003/2008 (DOI 10.1145/2179280.2179282). To the best of my knowledge, TS 29113 was formally included and extended as part of Fortran 2018. NVFortran implicitly advertises compliance with ISO/IEC 1539-1 : 2018, Information technology – Programming Languages – Fortran, Geneva, 2018 (Fortran 2018) in the Compatibility and Conformance to Standards section of the NVHPC SDK’s online documentation by listing it under “further information”. I, unfortunately, do not have access to these ISO standards and therefore can only assume that the aforementioned standard includes the additional C interrogability features mentioned in The new features of Fortran 2018 by the WG5 sub-committee, as well as compilers’ documentation/release notes/statuses such as GNU’s. The referenced ISO document is the -1
part of the full F2018 standard but the other sections either appear to be withdrawn, related to other concerns, or nonexistent (in our case). I am not certain how vastly the “Base Language” title should be interpreted as.
I apologize in advance for any inaccuracies as I don’t have access to ISO standards and am trying to reconstruct the feature’s history from a diverse set of sources. I was only trying to decipher why we couldn’t access to these features.
In any case, I believe that these additional C interoperability features with Fortran ought to be included in the NVHPC toolchain, as C–Fortran binding is important to many codes, and these new features improve the development experience as well as the reliability of the written software.
In the issue I mentioned at the beginning of this post, I explain in some detail this and other issues faced while building and running a simple Fortran test program using ZFP, relating to the NVHPC toolchain. I would appreciate it if you could consider adding support for these features to a future release of the NVHPC SDK. Using LLNL/zfp#163 to work on this problem would be beneficial because you might discover other issues, especially in the handling of C enumerations (mentioned in issue).
Thank you for your time and consideration.
