NVHPC 22.5 fort2 TERMINATED by signal 11
Context: I have been porting my research group’s MFC project to CMake. It is an OpenACC accelerated high fidelity CFD code written in Fortran. My current developement fork is available here: GitHub - henryleberre/MFC: High-fidelity multiphase flow simulation.
We encounter what seems to be an internal compiler error from NVHPC 22.5 when attempting to compile the “simulation” executable on some systems. On ORNL’s Summit no error is generated, and all tests pass. However, any other system I have tried it on produces (with NVHPC 22.5):
NVFORTRAN-W-0435-Array declared with zero size (/home/henryleberre/MFC/src/common/autogen/m_global_parameters.f90: 822)
NVFORTRAN-W-0435-Array declared with zero size (/home/henryleberre/MFC/src/common/autogen/m_global_parameters.f90: 823)
NVFORTRAN-W-0435-Array declared with zero size (/home/henryleberre/MFC/src/common/autogen/m_global_parameters.f90: 824)
NVFORTRAN-W-0435-Array declared with zero size (/home/henryleberre/MFC/src/common/autogen/m_global_parameters.f90: 825)
NVFORTRAN-W-0435-Array declared with zero size (/home/henryleberre/MFC/src/common/autogen/m_global_parameters.f90: 826)
NVFORTRAN-W-0435-Array declared with zero size (/home/henryleberre/MFC/src/common/autogen/m_global_parameters.f90: 1123)
NVFORTRAN-W-0155-Constant or Parameter used in data clause - weno_polyn (/home/henryleberre/MFC/src/common/autogen/m_global_parameters.f90: 483)
NVFORTRAN-W-0155-Constant or Parameter used in data clause - nb (/home/henryleberre/MFC/src/common/autogen/m_global_parameters.f90: 484)
  0 inform,   2 warnings,   0 severes, 0 fatal for s_initialize_global_parameters_module
s_initialize_global_parameters_module:
    750, Generating update device(re_idx(:,:),re_size(:))
    786, Generating update device(startz,starty,startx)
s_comp_n_from_cons:
   1029, Generating acc routine seq
         Generating NVIDIA GPU code
s_comp_n_from_prim:
   1069, Generating acc routine seq
s_quad:
   1099, Generating acc routine seq
nvfortran-Fatal-/opt/nvidia/hpc_sdk/Linux_x86_64/22.5/compilers/bin/tools/fort2 TERMINATED by signal 11
Arguments to /opt/nvidia/hpc_sdk/Linux_x86_64/22.5/compilers/bin/tools/fort2
/opt/nvidia/hpc_sdk/Linux_x86_64/22.5/compilers/bin/tools/fort2 /tmp/nvfortranmhIKgCQT5tQ.ilm -fn /home/henryleberre/MFC/src/common/autogen/m_global_parameters.f90 -debug -x 120 0x200 -x 123 0x400 -opt 0 -terse 1 -inform warn -x 51 0x20 -x 119 0xa10000 -x 122 0x40 -x 123 0x1000 -x 127 4 -x 127 17 -x 19 0x400000 -x 28 0x40000 -x 120 0x10000000 -x 70 0x8000 -x 122 1 -x 125 0x20000 -quad -x 59 4 -tp haswell -x 124 0x1400 -y 15 2 -x 57 0x3b0000 -x 58 0x48000000 -x 49 0x100 -astype 0 -x 121 1 -x 183 4 -x 121 0x800 -x 68 0x1 -x 8 0x40000000 -x 70 0x40000000 -x 56 0x10 -x 54 0x10 -x 120 0x2000000 -x 120 0x2000000 -x 249 140 -x 68 0x20 -x 70 0x40000000 -x 8 0x40000000 -x 164 0x800000 -x 71 0x2000 -x 71 0x4000 -x 34 0x40000000 -x 83 0x1 -x 85 0x1 -x 206 0x02 -x 68 0x1 -x 39 4 -x 56 0x10 -x 26 0x10 -x 26 1 -x 56 0x4000 -x 124 1 -accel tesla -accel host -x 197 0 -x 175 0 -x 203 0 -x 204 0 -x 180 0x4000400 -x 121 0xc00 -x 186 0x80 -x 180 0x4000400 -x 121 0xc00 -x 194 0x40000 -x 163 0x1 -x 186 0x80000 -cudaver 11070 -x 176 0x100 -cudacap 35 -cudacap 50 -cudacap 60 -cudacap 61 -cudacap 70 -cudacap 75 -cudacap 80 -cudacap 86 -cudaroot /opt/nvidia/hpc_sdk/Linux_x86_64/22.5/cuda/11.7 -x 189 0x8000 -y 163 0xc0000000 -x 163 0x800000 -x 189 0x10 -y 189 0x4000000 -cudaroot /opt/nvidia/hpc_sdk/Linux_x86_64/22.5/cuda/11.7 -x 187 0x40000 -x 187 0x8000000 -x 60 512 -x 0 0x1000000 -x 2 0x100000 -x 0 0x2000000 -x 161 16384 -x 162 16384 -x 124 0x20 -x 62 8 -cci /tmp/nvfortranShIe78ZaBXo.cci -cmdline '+nvfortran /home/henryleberre/MFC/src/common/autogen/m_global_parameters.f90 -I/home/henryleberre/MFC/build/install/include -isystem /opt/nvidia/hpc_sdk/Linux_x86_64/22.5/comm_libs/openmpi/openmpi-3.1.5/include -isystem /opt/nvidia/hpc_sdk/Linux_x86_64/22.5/comm_libs/openmpi/openmpi-3.1.5/lib -isystem /opt/nvidia/hpc_sdk/Linux_x86_64/22.5/cuda/11.7/include -isystem /opt/nvidia/hpc_sdk/Linux_x86_64/22.5/math_libs/include -g -gopt -r8 -cpp -Mpreprocess -Mfreeform -lcutensor -Minfo=accel -Mr8intrinsics -fPIC -acc -Mpreprocess -c -o CMakeFiles/simulation.dir/__/common/autogen/m_global_parameters.f90.o' -stbfile /tmp/nvfortranmhIKtK5KqRN.stb -asm /tmp/nvfortranmhIKD56NGRl.ll
make[3]: *** [src/simulation_code/CMakeFiles/simulation.dir/build.make:145: src/simulation_code/CMakeFiles/simulation.dir/__/common/autogen/m_global_parameters.f90.o] Error 127
make[2]: *** [CMakeFiles/Makefile2:113: src/simulation_code/CMakeFiles/simulation.dir/all] Error 2
make[1]: *** [CMakeFiles/Makefile2:120: src/simulation_code/CMakeFiles/simulation.dir/rule] Error 2
make: *** [Makefile:169: simulation] Error 2
Other online posts I have seen on this issue referenced earlier versions of NVHPC and all seemed to be associated with a compiler bug.
The simplest way to replicate this error would be, provided Python 3.8 or newer is installed, to:
    1. git clone https://github.com/henryleberre/MFC
    1. cd MFC
    1. pip3 install pyyaml rich fypp
    1. pip3 install -e toolchain/
    1. mkdir build
    1. python3 toolchain/mfc/main.py test -j $(nproc) -m release-gpu -o 5EB1467A
This is (thankfully) not how regular users would interact with MFC but this alternative will produce the error with fewer steps. The last command instructs the code to run the first test case with OpenACC enabled. We use a preprocessor for Fortran (Fypp) that converts .fpp files into autogen/.f90 files. The case that a user wishes to run is passed to the FYPP prior to compilation.
The last command will compile (and run) the pre_process code first, and then attempt to build the “simulation” code. Once an error occurs, the entire output will be printed to the console. You can now henceforth run only the simulation component of MFC on this test case with
./mfc.sh run tests/5EB1467A/case.json -j 8 -t simulation
I would greatly appreciate any help you could provide us. If this is indeed a compiler bug, are there ways to circumvent it?
Update: I tried compiling with GNU 12.1 + OpenACC to see whether it would produce any errors or warnings that could help me fix this. It produced an error for each Fortran parameter that was in an OpenACC statement (create, update, …). NVHPC only produced warnings and did not mention all instances. I had tried removing the ones it did but the error still remained.
After removing those mentions to Fortran parameters (as per GNU’s instructions), it compiled! It would be great if NVHPC could produce an error message instead of crashing.
Hi Henry,
Are you able to provide a minimal reproducing example?
I tried your steps above but get the following error:
/MFC% python3 toolchain/mfc/main.py test -j 1 -m release-gpu -o 5EB1467A
  File "toolchain/mfc/main.py", line 9, in <module>
    from mfc.util.common  import MFC_LOGO, MFCException, quit, delete_directory, format_list_to_string
ModuleNotFoundError: No module named 'mfc'
Plus I’m not seeing these parameter variables in a declare create directive in “m_global_parameters.fpp” so presume you’ve already updated the file in the git repo.
-Mat
Apologies for the delay, I had missed the notification. You can now use CMake directly if you pull the latest commit from the GPU branch (now the main branch). I originally posted this issue while refactoring our build system.
mkdir build && cd build
cmake .. -GNinja -DMFC_WITH_OPEN_ACC=ON -DMFC_BUILD_SIMULATION=ON -DCMAKE_BUILD_TYPE=Debug
ninja
Fortunately, the issue seems to have been resolved, as our code now doesn’t fail to build with NVHPC versions 21.9 and 22.5 in debug mode. I recently removed the linkage to the regular FFTW3 library when building with OpenACC (as we already include cuFFT with NVHPC).
I did try to build again but now get the following CMake errors:
% cmake .. -GNinja -DMFC_WITH_OPEN_ACC=ON -DMFC_BUILD_SIMULATION=ON -DCMAKE_BUILD_TYPE=Debug
CMake Error: CMake was unable to find a build program corresponding to "Ninja".  CMAKE_MAKE_PROGRAM is not set.  You probably need to select a different build tool.
CMake Error: CMAKE_C_COMPILER not set, after EnableLanguage
CMake Error: CMAKE_CXX_COMPILER not set, after EnableLanguage
CMake Error: CMAKE_Fortran_COMPILER not set, after EnableLanguage
-- Configuring incomplete, errors occurred!
Not sure if these are problems with the CMakeLists.txt or if I need to set these variables explicitly.
Though since it sounds like the issue no longer occurs, I wont worry about it. Though we can work through these issues if needed.
If you don’t have Ninja installed you can remove -GNinja from the CMake invocation. CMake will then default to use Make. The remaining errors might be fixed by running (given you have NVHPC installed):
export CC=$(which nvc)
export CXX=$(which nvc++)
export FC=$(which nvfortran)
Either way, as you mentioned, this issue has been resolved. Thank you for taking a look! However, this error should maybe be addressed. If more users face it. The compiler segfaulting while compiling is generally not intended behavior. If a fatal error occurred, an error message would be useful.
Definitely a complier segv is bad and we want to fix them once they are known. So if you encounter it again and can get us a reproducing example, I can file a report for engineering.
Tried building again, but it looks like Ninja is required for your build:
% cmake .. -DMFC_WITH_OPEN_ACC=ON -DMFC_BUILD_SIMULATION=ON -DCMAKE_BUILD_TYPE=Debug -DCMAKE_MAKE_PROGRAM=make -DCMAKE_C_COMPILER=nvc -DCMAKE_CXX_COMPILER=nvc++ -DCMAKE_Fortran_COMPILER=nvfortran
CMake Error at CMakeLists.txt:3 (PROJECT):
  The Ninja generator does not support Fortran using Ninja version
    GNU Make 4.1
  Built for x86_64-pc-linux-gnu
  Copyright (C) 1988-2014 Free Software Foundation, Inc.
  License GPLv3+: GNU GPL version 3 or later
  <http://gnu.org/licenses/gpl.html>
  This is free software: you are free to change and redistribute it.
  There is NO WARRANTY, to the extent permitted by law.
  due to lack of required features.  Ninja 1.10 or higher is required.
Hi @MatColgrove – We have run into this issue again and now have a more robust build system. The issue is here: MFC simulation doesn't build with `--debug` on GPU · Issue #123 · MFlowCode/MFC · GitHub
It’s essentially the same thing reported initially by @henryleberre .
Oddly, I’m not able to reproduce the error with 22.5 or 22.11, but can with 23.1 and our development compiler. Sometimes this can mean that there’s a UMR or other memory issue where it only shows up occasionally, but running the 22.11 back-end compiler through valgrind shows no issues. Hence while it’s likely the same issue, I’m not 100% sure.
I filed a problem report, TPR #33317, and sent it to engineering for investigation.
In my case, if I add an opt level, i.e. change “-O0” to “-O1” or “-O2”, the error goes away. You might try this as well, just as a work around until we can get this fixed.
-Mat
Thanks, @MatColgrove – good find. Prescribing-O0 is good enough for me and indeed fixes it on my end.
Hi Spenser, Henry,
TPR #33317 should be fixed in our 23.5 release. Though given I wasn’t 100% I reproduced your exact case, please give it try to see if the error goes away for you as well.
-Mat
