I am trying to port nvhpc-sdk to NixOS, however, nvfortran
does not work (ld
error while compiling a simple “hello world” fortran program). The reason is, nvfortran
passed a directory to ld
as a link script, then ld
complains read in flex scanner failed
. Could anyone please help me figure out, why nvhpc
always pass this directory to ld
Here is the log. nvfortran
first call fort1
, then fort2
, then llc
and append
, these calls are all success. Finally it calls ld
and failed.
hdf5-fortran> -- Check for working Fortran compiler: /nix/store/slyw83jlrp6vyjwyqxvka8wvkr6893mz-nvhpc-wrapper-24.11/bin/nvfortran
hdf5-fortran> -- Check for working Fortran compiler: /nix/store/slyw83jlrp6vyjwyqxvka8wvkr6893mz-nvhpc-wrapper-24.11/bin/nvfortran - broken
hdf5-fortran> CMake Error at /nix/store/7yhxinagh4i7q1kw9fn7mdz4bcjakcy9-cmake-3.30.5/share/cmake-3.30/Modules/CMakeTestFortranCompiler.cmake:59 (message):
hdf5-fortran> The Fortran compiler
hdf5-fortran>
hdf5-fortran> "/nix/store/slyw83jlrp6vyjwyqxvka8wvkr6893mz-nvhpc-wrapper-24.11/bin/nvfortran"
hdf5-fortran>
hdf5-fortran> is not able to compile a simple test program.
hdf5-fortran>
hdf5-fortran> It fails with the following output:
hdf5-fortran>
hdf5-fortran> Change Dir: '/build/source/build/CMakeFiles/CMakeScratch/TryCompile-eBSskw'
hdf5-fortran>
hdf5-fortran> Run Build Command(s): /nix/store/7yhxinagh4i7q1kw9fn7mdz4bcjakcy9-cmake-3.30.5/bin/cmake -E env VERBOSE=1 /nix/store/2bmv1q22qv2a1zns2jjhwyabddb4vaqv-gnumake-4.4.1/bin/make -f Makefile cmTC_48388/fast
hdf5-fortran> /nix/store/2bmv1q22qv2a1zns2jjhwyabddb4vaqv-gnumake-4.4.1/bin/make -f CMakeFiles/cmTC_48388.dir/build.make CMakeFiles/cmTC_48388.dir/build
hdf5-fortran> make[1]: Entering directory '/build/source/build/CMakeFiles/CMakeScratch/TryCompile-eBSskw'
hdf5-fortran> Building Fortran object CMakeFiles/cmTC_48388.dir/testFortranCompiler.f.o
hdf5-fortran> /nix/store/slyw83jlrp6vyjwyqxvka8wvkr6893mz-nvhpc-wrapper-24.11/bin/nvfortran -fPIE -c /build/source/build/CMakeFiles/CMakeScratch/TryCompile-eBSskw/testFortranCompiler.f -o CMakeFiles/cmTC_48388.dir/testFortranCompiler.f.o
hdf5-fortran> nvfortran-Warning-Unknown switch: -B/nix/store/89w3fyyzmif5kjjjnhqmyavg9fniljd3-glibc-2.40-36/lib/
hdf5-fortran> nvfortran-Warning-Unknown switch: -idirafter
hdf5-fortran> nvfortran-Warning-Unknown switch: -B/nix/store/8sp3373my4lnvcsn9l1b18q45mwn11zb-nvhpc-24.11/lib
hdf5-fortran> nvfortran-Warning-Unknown switch: -B/nix/store/qxz7l1jv1kj8548dld4qyaa9ddfw18sz-binutils-wrapper-2.43.1/bin/
hdf5-fortran> nvfortran-Warning-Unknown switch: -frandom-seed=mi5d914g7q
hdf5-fortran> nvfortran-Warning-The -gpu option has no effect unless a language-specific option to enable GPU code generation is used (e.g.: -acc, -mp=gpu, -stdpar, -cuda)
hdf5-fortran> /build/source/build/CMakeFiles/CMakeScratch/TryCompile-eBSskw/testFortranCompiler.f:
hdf5-fortran>
hdf5-fortran> /nix/store/8sp3373my4lnvcsn9l1b18q45mwn11zb-nvhpc-24.11/opt/nvidia/hpc_sdk/Linux_x86_64/24.11/compilers/bin/tools/fort1 /build/source/build/CMakeFiles/CMakeScratch/TryCompile-eBSskw/testFortranCompiler.f -opt 1 -nostatic -x 19 0x400000 -quad -x 59 4 -x 15 2 -x 49 0x400004 -x 51 0x20 -x 57 0x4c -x 58 0x10000 -x 124 0x1000 -tp znver4 -x 57 0xfb0000 -x 58 0x78031040 -x 47 0x08 -x 48 4608 -x 49 0x100 -stdinc /nix/store/8sp3373my4lnvcsn9l1b18q45mwn11zb-nvhpc-24.11/opt/nvidia/hpc_sdk/Linux_x86_64/24.11/compilers/include:/nix/store/8sp3373my4lnvcsn9l1b18q45mwn11zb-nvhpc-24.11/opt/nvidia/hpc_sdk/Linux_x86_64/24.11/compilers/include-stdexec:/nix/store/0dynnad751nnm3bczxscvc50sdmp867v-dpkg-1.22.10/include:/nix/store/icsq0mbjhzfmjw1asm7v2556k3822z4r-glibc-multi-2.40-36-dev/include:/nix/store/r2c59ahksdblhnaqrn24yp6kcs7di2m2-libz-1.2.8.2015.12.26-unstable-2018-03-31-dev/include:/nix/store/49v6ljxl1h5i22iw90bhx56p31nipas3-libxml2-2.13.4-dev/include:/nix/store/wr7935gmcwn1626h26qh024w85dxq280-zstd-1.5.6-dev/include:/nix/store/lzf45yqida6l8bqf5isz7wfllwlg2jv1-numactl-2.0.18-dev/include:/nix/store/pk11q25n9bmn5jz294zcrnw0429py0gy-ncurses-6.4.20221231-dev/include:/nix/store/605hgp0v6rf9945vmvz2pizz069h5bvc-gcc-13.3.0/lib/gcc/x86_64-unknown-linux-gnu/13.3.0/include:/nix/store/605hgp0v6rf9945vmvz2pizz069h5bvc-gcc-13.3.0/include:/nix/store/605hgp0v6rf9945vmvz2pizz069h5bvc-gcc-13.3.0/lib/gcc/x86_64-unknown-linux-gnu/13.3.0/include-fixed:/nix/store/axv588igjrlrbxhw1k2mh943dydb6q78-glibc-2.40-36-dev/include:/nix/store/vp90z3pv4k9d1ra7b5j0rvm072igncx4-zlib-1.3.1-dev/include:/nix/store/vp90z3pv4k9d1ra7b5j0rvm072igncx4-zlib-1.3.1-dev/include -cmdline '+nvfortran /build/source/build/CMakeFiles/CMakeScratch/TryCompile-eBSskw/testFortranCompiler.f -tp=znver4 -gpu=cc89 -# -fPIE -pie -c -o CMakeFiles/cmTC_48388.dir/testFortranCompiler.f.o -# -noswitcherror -isystem /nix/store/vp90z3pv4k9d1ra7b5j0rvm072igncx4-zlib-1.3.1-dev/include -isystem /nix/store/vp90z3pv4k9d1ra7b5j0rvm072igncx4-zlib-1.3.1-dev/include' -def __unix -def __unix__ -def unix -def linux -def __linux -def __linux__ -def __ELF__ -def __NO_MATH_INLINES -def __LP64__ -def __x86_64 -def __x86_64__ -def __LONG_MAX__=9223372036854775807L -def '__SIZE_TYPE__=unsigned long int' -def '__PTRDIFF_TYPE__=long int' -def __amd64 -def __amd64__ -def __k8 -def __k8__ -def __MMX__ -def __SSE_MATH__ -def __MMX_WITH_SSE__ -def __SSE__ -def __SSE2__ -def __SSE2_MATH__ -def __SSE3__ -def __SSSE3__ -def __SSE4A__ -def __SSE4_1__ -def __SSE4_2__ -def __ABM__ -def __ADX__ -def __AES__ -def __AVX__ -def __AVX2__ -def __AVX512BF16__ -def __AVX512BITALG__ -def __AVX512BW__ -def __AVX512CD__ -def __AVX512DQ__ -def __AVX512F__ -def __AVX512IFMA__ -def __AVX512VBMI__ -def __AVX512VBMI2__ -def __AVX512VL__ -def __AVX512VNNI__ -def __AVX512VPOPCNTDQ__ -def __BMI__ -def __BMI2__ -def __CLFLUSHOPT__ -def __CLWB__ -def __CLZERO__ -def __F16C__ -def __FMA__ -def __FSGSBASE__ -def __FXSR__ -def __GFNI__ -def __LZCNT__ -def __MOVBE__ -def __MWAITX__ -def __PCLMUL__ -def __PKU__ -def __POPCNT__ -def __PRFCHW__ -def __RDPID__ -def __RDRND__ -def __RDSEED__ -def __LAHF_SAHF__ -def __SHA__ -def __VAES__ -def __VPCLMULQDQ__ -def __WBNOINVD__ -def __XSAVE__ -def __XSAVEC__ -def __XSAVEOPT__ -def __XSAVES__ -idir /nix/store/vp90z3pv4k9d1ra7b5j0rvm072igncx4-zlib-1.3.1-dev/include -idir /nix/store/vp90z3pv4k9d1ra7b5j0rvm072igncx4-zlib-1.3.1-dev/include -def __PGLLVM__ -def __NVCOMPILER_LLVM__ -def __extension__= -def __NVCOMPILER_GPU_SEPARATE_MEM -def __PIC__ -def __PIE__ -def __PIC__ -def __PIE__ -nofreeform -vect 48 -x 54 1 -mach 0 -nomach 0 -x 68 0x1 -x 70 0x40000000 -x 70 0x40000000 -x 68 0x1 -x 124 1 -x 195 0x8000 -y 163 0xc0000000 -x 189 0x10 -stbfile /build/nvfortranw-cbcHx8CnYf.stb -modexport /build/nvfortrang-cbsPtcruoB.cmod -modindex /build/nvfortran2-cbIZWpA1MN.cmdx -cci /build/nvfortranM-cbYkMmqogs.cci -output /build/nvfortran2-cbIwlyNTwX.ilm
hdf5-fortran> 0 inform, 0 warnings, 0 severes, 0 fatal for testfortran
hdf5-fortran> NVFORTRAN/x86-64 Linux 24.11-0: compilation successful
hdf5-fortran>
hdf5-fortran> /nix/store/8sp3373my4lnvcsn9l1b18q45mwn11zb-nvhpc-24.11/opt/nvidia/hpc_sdk/Linux_x86_64/24.11/compilers/bin/tools/fort2 /build/nvfortran2-cbIwlyNTwX.ilm -fn /build/source/build/CMakeFiles/CMakeScratch/TryCompile-eBSskw/testFortranCompiler.f -opt 1 -x 51 0x20 -x 119 0xa10000 -x 122 0x40 -x 123 0x1000 -x 127 4 -x 127 17 -x 19 0x400000 -x 28 0x40000 -x 120 0x10000000 -x 70 0x8000 -x 122 1 -x 125 0x20000 -quad -x 59 4 -tp znver4 -x 120 0x1000 -x 124 0x1400 -y 15 2 -x 57 0x3b0000 -x 58 0x48000000 -x 49 0x100 -astype 0 -x 121 1 -x 183 4 -x 121 0x800 -mach 0 -nomach 0 -x 68 0x1 -x 8 0x40000000 -x 70 0x40000000 -x 56 0x10 -x 54 0x10 -x 249 170 -x 68 0x20 -x 70 0x40000000 -x 8 0x40000000 -x 164 0x800000 -x 71 0x2000 -x 71 0x4000 -x 34 0x40000000 -x 120 0x1000000 -x 73 0x04 -x 231 0x800 -x 68 0x1 -x 39 4 -x 56 0x10 -x 26 0x10 -x 26 1 -x 56 0x4000 -x 124 1 -x 197 0 -x 175 0 -x 203 0 -x 204 0 -x 227 0xFFFF -y 163 0xc0000000 -x 189 0x10 -y 189 0x4000000 -x 60 512 -x 62 8 -x 62 8 -cci /build/nvfortranM-cbYkMmqogs.cci -cmdline '+nvfortran /build/source/build/CMakeFiles/CMakeScratch/TryCompile-eBSskw/testFortranCompiler.f -tp=znver4 -gpu=cc89 -# -fPIE -pie -c -o CMakeFiles/cmTC_48388.dir/testFortranCompiler.f.o -# -noswitcherror -isystem /nix/store/vp90z3pv4k9d1ra7b5j0rvm072igncx4-zlib-1.3.1-dev/include -isystem /nix/store/vp90z3pv4k9d1ra7b5j0rvm072igncx4-zlib-1.3.1-dev/include' -stbfile /build/nvfortranw-cbcHx8CnYf.stb -asm /build/nvfortranw-cbcoXsGUNy.ll
hdf5-fortran>
hdf5-fortran> /nix/store/8sp3373my4lnvcsn9l1b18q45mwn11zb-nvhpc-24.11/opt/nvidia/hpc_sdk/Linux_x86_64/24.11/compilers/share/llvm/bin/llc /build/nvfortranw-cbcoXsGUNy.ll -march=x86-64 -mcpu=znver4 -mattr=+mmx -mattr=+sse -mattr=+sse2 -mattr=+sse3 -mattr=+ssse3 -mattr=+sse4a -mattr=+sse4.1 -mattr=+sse4.2 -mattr=+avx -mattr=+avx2 -mattr=+avx512f -mattr=+avx512cd -mattr=+avx512vl -mattr=+avx512bw -mattr=+avx512dq -mattr=+avx512ifma -mattr=+avx512vbmi -mattr=+avx512vbmi2 -mattr=+avx512bitalg -mattr=+avx512vpopcntdq -mattr=+avx512vnni -mattr=+f16c -mattr=+fma -mattr=+xsave -mattr=+xsaveopt -mattr=+xsavec -mattr=+xsaves -mattr=+popcnt -mattr=+sha -mattr=+aes -mattr=+pclmul -mattr=+clflushopt -mattr=+fsgsbase -mattr=+rdrnd -mattr=+bmi -mattr=+bmi2 -mattr=+lzcnt -mattr=+fxsr -mattr=+mwaitx -mattr=+clzero -mattr=+pku -mattr=+gfni -mattr=+vaes -mattr=+vpclmulqdq -mattr=+adx -mattr=+avx512bf16 -mattr=+clwb -mattr=+movbe -mattr=+prfchw -mattr=+rdpid -mattr=+rdseed -mattr=+sahf -mattr=+wbnoinvd -O1 -x86-cmov-converter=0 -dwarf-directory=false -non-global-value-max-name-size=4294967295 --align-all-functions=6 -nvhpc-memzero -relocation-model=pic -filetype=obj --frame-pointer=none -o CMakeFiles/cmTC_48388.dir/testFortranCompiler.f.o
hdf5-fortran>
hdf5-fortran> /nix/store/8sp3373my4lnvcsn9l1b18q45mwn11zb-nvhpc-24.11/opt/nvidia/hpc_sdk/Linux_x86_64/24.11/compilers/bin/tools/append -noerror CMakeFiles/cmTC_48388.dir/testFortranCompiler.f.o -name .IPDINFO /build/nvfortrang-cbsPtcruoB.cmod -name .IPEINFO /build/nvfortran2-cbIZWpA1MN.cmdx
hdf5-fortran> Linking Fortran executable cmTC_48388
hdf5-fortran> /nix/store/7yhxinagh4i7q1kw9fn7mdz4bcjakcy9-cmake-3.30.5/bin/cmake -E cmake_link_script CMakeFiles/cmTC_48388.dir/link.txt --verbose=1
hdf5-fortran> /nix/store/slyw83jlrp6vyjwyqxvka8wvkr6893mz-nvhpc-wrapper-24.11/bin/nvfortran CMakeFiles/cmTC_48388.dir/testFortranCompiler.f.o -o cmTC_48388
hdf5-fortran>
hdf5-fortran> /nix/store/fxk79n9111mmlj4lpyas8lfivfj9ridj-gfortran-wrapper-13.3.0/bin/ld /nix/store/5x5mdv676x7qxc3vp6nyrinv52g6h9mc-glibc-multi-2.40-36/lib/crt1.o /nix/store/5x5mdv676x7qxc3vp6nyrinv52g6h9mc-glibc-multi-2.40-36/lib/crti.o /nix/store/605hgp0v6rf9945vmvz2pizz069h5bvc-gcc-13.3.0/lib/gcc/x86_64-unknown-linux-gnu/13.3.0//crtbegin.o /nix/store/8sp3373my4lnvcsn9l1b18q45mwn11zb-nvhpc-24.11/opt/nvidia/hpc_sdk/Linux_x86_64/24.11/compilers/lib/f90main.o --eh-frame-hdr -m elf_x86_64 -dynamic-linker /nix/store/89w3fyyzmif5kjjjnhqmyavg9fniljd3-glibc-2.40-36/lib64/ld-linux-x86-64.so.2 -T /nix/store/8sp3373my4lnvcsn9l1b18q45mwn11zb-nvhpc-24.11/opt/nvidia/hpc_sdk/Linux_x86_64/24.11/compilers/lib/nvhpc.ld -L/nix/store/i1r25z2pfsiqwbvhqw75l4hd9yvm5j6r-zlib-1.3.1/lib -L/nix/store/i1r25z2pfsiqwbvhqw75l4hd9yvm5j6r-zlib-1.3.1/lib -L/nix/store/i1r25z2pfsiqwbvhqw75l4hd9yvm5j6r-zlib-1.3.1/lib -L/nix/store/89w3fyyzmif5kjjjnhqmyavg9fniljd3-glibc-2.40-36/lib -L/nix/store/8sp3373my4lnvcsn9l1b18q45mwn11zb-nvhpc-24.11/lib -L/nix/store/qagmkpkfy4kviil6winzxz7kx443kr4y-gcc-13.3.0-lib/lib -L/nix/store/8sp3373my4lnvcsn9l1b18q45mwn11zb-nvhpc-24.11/opt/nvidia/hpc_sdk/Linux_x86_64/24.11/compilers/lib -L/nix/store/5x5mdv676x7qxc3vp6nyrinv52g6h9mc-glibc-multi-2.40-36/lib -L/nix/store/605hgp0v6rf9945vmvz2pizz069h5bvc-gcc-13.3.0/lib/gcc/x86_64-unknown-linux-gnu/13.3.0/ -dynamic-linker=/nix/store/89w3fyyzmif5kjjjnhqmyavg9fniljd3-glibc-2.40-36/lib/ld-linux-x86-64.so.2 CMakeFiles/cmTC_48388.dir/testFortranCompiler.f.o /nix/store/axv588igjrlrbxhw1k2mh943dydb6q78-glibc-2.40-36-dev/include -rpath /nix/store/mi5d914g7qg8asah7mb98rc9r9y7hx8j-hdf5-fortran-1.14.5/lib -rpath /nix/store/8sp3373my4lnvcsn9l1b18q45mwn11zb-nvhpc-24.11/opt/nvidia/hpc_sdk/Linux_x86_64/24.11/compilers/lib -rpath /nix/store/605hgp0v6rf9945vmvz2pizz069h5bvc-gcc-13.3.0/lib/gcc/x86_64-unknown-linux-gnu/13.3.0//../../../../lib64 -o cmTC_48388 -L/nix/store/605hgp0v6rf9945vmvz2pizz069h5bvc-gcc-13.3.0/lib/gcc/x86_64-unknown-linux-gnu/13.3.0//../../../../lib64 -lnvf -lnvomp -ldl --as-needed -lnvhpcatm -latomic --no-as-needed -lpthread -lnvcpumath -lnsnvc -lnvc -lrt -lpthread -lgcc -lc -lgcc_s -lm /nix/store/605hgp0v6rf9945vmvz2pizz069h5bvc-gcc-13.3.0/lib/gcc/x86_64-unknown-linux-gnu/13.3.0//crtend.o /nix/store/5x5mdv676x7qxc3vp6nyrinv52g6h9mc-glibc-multi-2.40-36/lib/crtn.o
hdf5-fortran> /nix/store/pg61jb4gf8wdrskinznhk9sn6sgb0xln-binutils-2.43.1/bin/ld: read in flex scanner failed
hdf5-fortran> nvfortran-Fatal-linker completed with exit code 1
hdf5-fortran>
hdf5-fortran> make[1]: *** [CMakeFiles/cmTC_48388.dir/build.make:99: cmTC_48388] Error 2
hdf5-fortran> make[1]: Leaving directory '/build/source/build/CMakeFiles/CMakeScratch/TryCompile-eBSskw'
hdf5-fortran> make: *** [Makefile:127: cmTC_48388/fast] Error 2
hdf5-fortran>
hdf5-fortran>
hdf5-fortran>
hdf5-fortran>
hdf5-fortran>
hdf5-fortran> CMake will not be able to correctly generate this project.
hdf5-fortran> Call Stack (most recent call first):
hdf5-fortran> config/cmake/HDFUseFortran.cmake:16 (enable_language)
hdf5-fortran> config/cmake/HDF5UseFortran.cmake:17 (include)
hdf5-fortran> CMakeLists.txt:1115 (include)
hdf5-fortran>
hdf5-fortran>
hdf5-fortran> -- Configuring incomplete, errors occurred!
Here is my localrc
set LDSO=/nix/store/89w3fyyzmif5kjjjnhqmyavg9fniljd3-glibc-2.40-36/lib64/ld-linux-x86-64.so.2;
set GCCDIR=/nix/store/605hgp0v6rf9945vmvz2pizz069h5bvc-gcc-13.3.0/lib/gcc/x86_64-unknown-linux-gnu/13.3.0/;
set OEM_INFO=64-bit target on x86-64 Linux $INFOTPVAL;
set GNUATOMIC=-latomic;
set GCCINC=/nix/store/0dynnad751nnm3bczxscvc50sdmp867v-dpkg-1.22.10/include /nix/store/icsq0mbjhzfmjw1asm7v2556k3822z4r-glibc-multi-2.40-36-dev/include /nix/store/r2c59ahksdblhnaqrn24yp6kcs7di2m2-libz-1.2.8.2015.12.26-unstable-2018-03-31-dev/include /nix/store/49v6ljxl1h5i22iw90bhx56p31nipas3-libxml2-2.13.4-dev/include /nix/store/wr7935gmcwn1626h26qh024w85dxq280-zstd-1.5.6-dev/include /nix/store/lzf45yqida6l8bqf5isz7wfllwlg2jv1-numactl-2.0.18-dev/include /nix/store/pk11q25n9bmn5jz294zcrnw0429py0gy-ncurses-6.4.20221231-dev/include /nix/store/605hgp0v6rf9945vmvz2pizz069h5bvc-gcc-13.3.0/lib/gcc/x86_64-unknown-linux-gnu/13.3.0/include /nix/store/605hgp0v6rf9945vmvz2pizz069h5bvc-gcc-13.3.0/include /nix/store/605hgp0v6rf9945vmvz2pizz069h5bvc-gcc-13.3.0/lib/gcc/x86_64-unknown-linux-gnu/13.3.0/include-fixed /nix/store/axv588igjrlrbxhw1k2mh943dydb6q78-glibc-2.40-36-dev/include;
set GPPDIR=/nix/store/0dynnad751nnm3bczxscvc50sdmp867v-dpkg-1.22.10/include /nix/store/icsq0mbjhzfmjw1asm7v2556k3822z4r-glibc-multi-2.40-36-dev/include /nix/store/r2c59ahksdblhnaqrn24yp6kcs7di2m2-libz-1.2.8.2015.12.26-unstable-2018-03-31-dev/include /nix/store/49v6ljxl1h5i22iw90bhx56p31nipas3-libxml2-2.13.4-dev/include /nix/store/wr7935gmcwn1626h26qh024w85dxq280-zstd-1.5.6-dev/include /nix/store/lzf45yqida6l8bqf5isz7wfllwlg2jv1-numactl-2.0.18-dev/include /nix/store/pk11q25n9bmn5jz294zcrnw0429py0gy-ncurses-6.4.20221231-dev/include /nix/store/605hgp0v6rf9945vmvz2pizz069h5bvc-gcc-13.3.0/include/c++/13.3.0/ /nix/store/605hgp0v6rf9945vmvz2pizz069h5bvc-gcc-13.3.0/include/c++/13.3.0//x86_64-unknown-linux-gnu /nix/store/605hgp0v6rf9945vmvz2pizz069h5bvc-gcc-13.3.0/include/c++/13.3.0//backward /nix/store/605hgp0v6rf9945vmvz2pizz069h5bvc-gcc-13.3.0/lib/gcc/x86_64-unknown-linux-gnu/13.3.0/include /nix/store/605hgp0v6rf9945vmvz2pizz069h5bvc-gcc-13.3.0/include /nix/store/605hgp0v6rf9945vmvz2pizz069h5bvc-gcc-13.3.0/lib/gcc/x86_64-unknown-linux-gnu/13.3.0/include-fixed /nix/store/axv588igjrlrbxhw1k2mh943dydb6q78-glibc-2.40-36-dev/include;
set NUMALIBNAME=-lnuma;
set LOCALRC=YES;
set EXTENSION=__extension__=;
set LC=-lgcc -lc $if(-Bstatic,-lgcc_eh, -lgcc_s);
# GLIBC version 2.40
# GCC version 13.3.0
set GCCVERSION=130300;
set LIBNCURSES=YES;
export PGI=$COMPBASE;
Additionally, I passed the following content through NVLOCALRC
set DEFLIBDIR=/nix/store/5x5mdv676x7qxc3vp6nyrinv52g6h9mc-glibc-multi-2.40-36/lib;
set DEFSTDOBJDIR=/nix/store/5x5mdv676x7qxc3vp6nyrinv52g6h9mc-glibc-multi-2.40-36/lib;
