Compilation error when using Cuda HPC package + cmake
When I am compiling my Cmake project using Cuda HPC I am facing cuda files compilation error:
/opt/nvidia/hpc_sdk/Linux_x86_64/22.9//cuda/bin/nvcc -forward-unknown-to-host-compiler -DBOOST_ALL_NO_LIB -DBOOST_CHRONO_DYN_LINK -DBOOST_DATE_TIME_DYN_LINK -DBOOST_FILESYSTEM_DYN_LINK -DBOOST_REGEX_DYN_LINK -DBOOST_SYSTEM_DYN_LINK -DBOOST_THREAD_DYN_LINK -DBOOST_TIMER_DYN_LINK -DGIT_DATE="\"Tue Mar 14 13:03:23 2023\"" -DGIT_SHA1=\"98411eb\" -DGIT_TAG=\"\" -DUSE_CUTENSOR -DUSE_ENABLE_KD_BFLOAT=true -DUSE_GPU -DUSE_GPUG80 -DUSE_NVHPC -I/usr/local/include/opencv4 -I/home/Yehonatans/work/nlirRef/nlircloud/src/ImageRec/KsKd -I/home/Yehonatans/work/nlirRef/nlircloud/src/ImageRec/Freq2FreqTransfer -I/home/Yehonatans/work/nlirRef/nlircloud/src/ImageRec/CsiFirstStage -I/home/Yehonatans/work/nlirRef/nlircloud/src/ImageRec/CsiSecondStage -I/home/Yehonatans/work/nlirRef/nlircloud/src/ImageRec/CsiRunner -I/home/Yehonatans/work/nlirRef/nlircloud/src/ImageRec/CsiInitialization -I/home/Yehonatans/work/nlirRef/nlircloud/src/ImageRec/common -I/home/Yehonatans/work/nlirRef/nlircloud/src/ImageRec/BoundaryConditions -I/home/Yehonatans/work/nlirRef/nlircloud/src/ImageRec/Antenna -I/home/Yehonatans/work/nlirRef/nlircloud/src/ImageRec/DataReceiver -I/home/Yehonatans/work/nlirRef/nlircloud/src/ImageRec/DataExporter -I/home/Yehonatans/work/nlirRef/nlircloud/src/algorithms/SigProc/Volume -I/home/Yehonatans/work/nlirRef/nlircloud/src/utils/general -I/home/Yehonatans/work/nlirRef/nlircloud/src/utils/threads -I/home/Yehonatans/work/nlirRef/nlircloud/src/NVHPC::MATH -I/home/Yehonatans/work/nlirRef/nlircloud/src/NVHPC::CUDA -I/home/Yehonatans/work/nlirRef/nlircloud/src/NVHPC::NVRTC -I/home/Yehonatans/work/nlirRef/nlircloud/src/NVHPC::CUDART -I/home/Yehonatans/work/nlirRef/nlircloud/src/utils/hpc -isystem=/usr/local/include -isystem=/usr/local/include/eigen3 -isystem=/opt/nvidia/hpc_sdk/Linux_x86_64/22.9/cmake/../math_libs/11.7/include -isystem=/opt/nvidia/hpc_sdk/Linux_x86_64/22.9/cmake/../cuda/11.7/include -isystem=/opt/nvidia/hpc_sdk/Linux_x86_64/22.9/comm_libs/openmpi/openmpi-3.1.5/include -isystem=/opt/nvidia/hpc_sdk/Linux_x86_64/22.9/cmake/../comm_libs/11.7/nccl/include -isystem=/usr/include --expt-extended-lambda --default-stream per-thread -Xcudafe --diag_suppress=esa_on_defaulted_function_ignored --generate-code=arch=compute_80,code=[compute_80,sm_80] -std=c++17 -MD -MT ImageRec/common/CMakeFiles/nlir_common.dir/commonKernel.cu.o -MF ImageRec/common/CMakeFiles/nlir_common.dir/commonKernel.cu.o.d -x cu -dc /home/Yehonatans/work/nlirRef/nlircloud/src/ImageRec/common/commonKernel.cu -o ImageRec/common/CMakeFiles/nlir_common.dir/commonKernel.cu.o
In file included from /opt/nvidia/hpc_sdk/Linux_x86_64/22.9/cmake/../cuda/11.7/include/crt/math_functions.h:10545,
                 from /opt/nvidia/hpc_sdk/Linux_x86_64/22.9/cmake/../cuda/11.7/include/crt/common_functions.h:303,
                 from /opt/nvidia/hpc_sdk/Linux_x86_64/22.9/cmake/../cuda/11.7/include/cuda_runtime.h:115,
                 from <command-line>:
The root cause for the error is the command “-isystem=/usr/include” which is being added automatically when running the cmake file.
When I manually compiled the file without -isystem=/usr/include the compilation was Ok
An example for broken compilation line
cd /home/Yehonatans/work/Ref/cloud/src/build/ImageRec/common && /opt/nvidia/hpc_sdk/Linux_x86_64/23.3//cuda/bin/nvcc -forward-unknown-to-host-compiler -DBOOST_ALL_NO_LIB -DBOOST_CHRONO_DYN_LINK -DBOOST_DATE_TIME_DYN_LINK -DBOOST_FILESYSTEM_DYN_LINK -DBOOST_REGEX_DYN_LINK -DBOOST_SYSTEM_DYN_LINK -DBOOST_THREAD_DYN_LINK -DBOOST_TIMER_DYN_LINK -DGIT_DATE="\"Tue Mar 14 13:03:23 2023\"" -DGIT_SHA1=\"98411eb\" -DGIT_TAG=\"\" -DUSE_CUTENSOR -DUSE_ENABLE_KD_BFLOAT=true -DUSE_GPU -DUSE_GPUG80 -DUSE_NVHPC -I/usr/local/include/opencv4 -I/home/Yehonatans/work/Ref/cloud/src/ImageRec/KsKd -I/home/Yehonatans/work/Ref/cloud/src/ImageRec/Freq2FreqTransfer -I/home/Yehonatans/work/Ref/cloud/src/ImageRec/CsiFirstStage -I/home/Yehonatans/work/Ref/cloud/src/ImageRec/CsiSecondStage -I/home/Yehonatans/work/Ref/cloud/src/ImageRec/CsiRunner -I/home/Yehonatans/work/Ref/cloud/src/ImageRec/CsiInitialization -I/home/Yehonatans/work/Ref/cloud/src/ImageRec/common -I/home/Yehonatans/work/Ref/cloud/src/ImageRec/BoundaryConditions -I/home/Yehonatans/work/Ref/cloud/src/ImageRec/Antenna -I/home/Yehonatans/work/Ref/cloud/src/ImageRec/DataReceiver -I/home/Yehonatans/work/Ref/cloud/src/ImageRec/DataExporter -I/home/Yehonatans/work/Ref/cloud/src/algorithms/SigProc/Volume -I/home/Yehonatans/work/Ref/cloud/src/utils/general -I/home/Yehonatans/work/Ref/cloud/src/utils/threads -I/home/Yehonatans/work/Ref/cloud/src/NVHPC::MATH -I/home/Yehonatans/work/Ref/cloud/src/NVHPC::CUDA -I/home/Yehonatans/work/Ref/cloud/src/NVHPC::NVRTC -I/home/Yehonatans/work/Ref/cloud/src/NVHPC::CUDART -I/home/Yehonatans/work/Ref/cloud/src/utils/hpc -isystem=/usr/local/include -isystem=/usr/local/include/eigen3 -isystem=/opt/nvidia/hpc_sdk/Linux_x86_64/23.3/cmake/../math_libs/11.8/include -isystem=/opt/nvidia/hpc_sdk/Linux_x86_64/23.3/cmake/../cuda/11.8/include -isystem=/opt/nvidia/hpc_sdk/Linux_x86_64/23.3/cmake/../comm_libs/11.8/nccl/include -isystem=/usr/include --expt-extended-lambda --default-stream per-thread -Xcudafe --diag_suppress=esa_on_defaulted_function_ignored --generate-code=arch=compute_80,code=[compute_80,sm_80] -Xcompiler -pthread -std=c++17 -MD -MT ImageRec/common/CMakeFiles/_common.dir/commonKernel.cu.o -MF CMakeFiles/_common.dir/commonKernel.cu.o.d -x cu -dc /home/Yehonatans/work/Ref/cloud/src/ImageRec/common/commonKernel.cu -o CMakeFiles/_common.dir/commonKernel.cu.o
The main Cmake file is:
#set(CMAKE_EXE_LINKER_FLAGS "${CMAKE_EXE_LINKER_FLAGS} -wl,--stack,32000")
cmake_minimum_required(VERSION 3.17)
### Require out-of-source builds
file(TO_CMAKE_PATH "${PROJECT_BINARY_DIR}/CMakeLists.txt" LOC_PATH)
if(EXISTS "${LOC_PATH}")
 message(FATAL_ERROR "You cannot build in a source directory (or any directory with a CMakeLists.txt file). Please make a build subdirectory. Feel free to remove CMakeCache.txt and CMakeFiles.")
endif()
 message("Cmake version ${CMAKE_VERSION}")
IF(NVHPC_ENABLE)
 message("NVHPC_ENABLE is active")
 add_definitions("-DUSE_NVHPC")
ENDIF()
set(CMAKE_CUDA_ARCHITECTURES  80)
set(CMAKE_CUDA_COMPILER   "$ENV{NVHPC_PATH}//cuda/bin/nvcc")
set(CMAKE_CUDA_COMPILER_FORCED TRUE)
project(Proj C CXX CUDA)
set(CUTLASS_ENABLE "ON")
set(NVHPC_ENABLE "ON")
add_definitions("-DUSE_GPU")
set(CUDA_ENABLE "ON")
set(ALGS_USE_EM "ON")
add_definitions("-DUSE_ENABLE_KD_BFLOAT=true")
add_definitions("-DUSE_GPUG80")
set(CMAKE_VERBOSE_MAKEFILE OFF)
set(CMAKE_PREFIX_PATH ${CMAKE_PREFIX_PATH} "$ENV{NVHPC_PATH}/cmake" )
set(CMAKE_PREFIX_PATH ${CMAKE_PREFIX_PATH} "$ENV{NVHPC_PATH}/cutlass/lib64/cmake" )
find_package(MPI  REQUIRED )
find_package(NVHPC REQUIRED COMPONENTS CUDA MATH  NCCL)
#find_package(NvidiaCutlass REQUIRED nvidia::cutlass::library)
ADD_LIBRARY(utils_cuda INTERFACE)
TARGET_INCLUDE_DIRECTORIES(utils_cuda INTERFACE NVHPC::MATH NVHPC::CUDA  NVHPC::NVRTC NVHPC::CUDART)
TARGET_LINK_DIRECTORIES(utils_cuda INTERFACE NVHPC::MATH NVHPC::CUDA NVHPC::NVRTC NVHPC::CUDART)
TARGET_LINK_LIBRARIES(utils_cuda INTERFACE NVHPC::MATH NVHPC::CUDA NVHPC::NVRTC NVHPC::CUDART)
IF(DBG MATCHES "ON")
 set(CMAKE_BUILD_TYPE Debug) # Release | Debug
ELSEIF(DBG MATCHES "OFF")
 set(CMAKE_BUILD_TYPE Release) # Release | Debug
ENDIF(DBG MATCHES "ON")
message("CUDA INCLUDE: ${CUDAToolkit_INCLUDE_DIRS}")
INCLUDE_DIRECTORIES(${CUDAToolkit_INCLUDE_DIRS})
set(CMAKE_CUDA_FLAGS "--expt-extended-lambda --default-stream per-thread -Xcudafe --diag_suppress=esa_on_defaulted_function_ignored")
#set(CMAKE_CUDA_FLAGS "--expt-extended-lambda ")
#set(NvidiaCutlass_DIR "/usr/local/cuda/lib64/cmake")
#find_package(NvidiaCutlass)
message(STATUS "Cuda root dir: ${CUDAToolkit_LIBRARY_ROOT}")
set(CMAKE_CUDA_STANDARD_REQUIRED TRUE)
set(CMAKE_CUDA_SEPARABLE_COMPILATION ON)
set(UTILS ${CMAKE_SOURCE_DIR}/utils)
message( "UTILS path  ${UTILS}")
set(CMAKE_CUDA_STANDARD 17)
set(CMAKE_CXX_STANDARD 17)
set(CMAKE_CXX_STANDARD_REQUIRED TRUE)
# Retrieve information about current git branch into environment var
find_package(Git)
if (Git_FOUND)
  message("Git found: ${GIT_EXECUTABLE}")
  message(STATUS "Resolving GIT Version")
  # the commit's SHA1, and whether the building workspace was dirty or not
  execute_process(COMMAND
    "${GIT_EXECUTABLE}" describe --match=NeVeRmAtCh --always #--abbrev=8
    WORKING_DIRECTORY "${CMAKE_SOURCE_DIR}"
    OUTPUT_VARIABLE GIT_SHA1
    ERROR_QUIET OUTPUT_STRIP_TRAILING_WHITESPACE)
    "${GIT_EXECUTABLE}" describe --tag #--abbrev=8
    OUTPUT_VARIABLE GIT_TAG
  # the date of the commit
    "${GIT_EXECUTABLE}" log -1 --format=%ad --date=local
    OUTPUT_VARIABLE GIT_DATE
  # the subject of the commit
    "${GIT_EXECUTABLE}" log -1 --format=%s
    OUTPUT_VARIABLE GIT_COMMIT_SUBJECT
  message(STATUS "GIT_COMMIT_SUBJECT=" ${GIT_COMMIT_SUBJECT})
  message(STATUS "GIT_SHA1=" ${GIT_SHA1})
  message(STATUS "GIT_DATE=" ${GIT_DATE})
  message(STATUS "GIT_TAG=" ${GIT_TAG})
  #add_definitions("-DGIT_COMMIT_SUBJECT=\"${GIT_COMMIT_SUBJECT}\"")
  add_definitions("-DGIT_SHA1=\"${GIT_SHA1}\"")
  add_definitions("-DGIT_DATE=\"${GIT_DATE}\"")
  add_definitions("-DGIT_TAG=\"${GIT_TAG}\"")
else ()
  message(SEND_ERROR "Could not find git package")
endif ()
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -Wall -pedantic -fopenmp")
#set(SANITIZE "ADDRESS_LEAK")
#set(SANITIZE  "THREADS")
#set(SANITIZE  "LEAK")
IF (CMAKE_BUILD_TYPE MATCHES Debug)
  IF (SANITIZE MATCHES "ADDRESS_LEAK")
    message("Sanitize address...")
    set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -fsanitize=address -fsanitize=leak -fno-omit-frame-pointer")
  ELSEIF (SANITIZE MATCHES "ADDRESS")
    set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -fsanitize=address  -fno-omit-frame-pointer")
  ELSEIF (SANITIZE MATCHES "THREADS")
    set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -fsanitize=thread  -fno-omit-frame-pointer")
  ELSEIF (SANITIZE MATCHES "LEAK")
    set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -fsanitize=leak  -fno-omit-frame-pointer")
  ENDIF ()
  set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS}")
ENDIF ()
message("-- CMAKE_BUILD_TYPE = " ${CMAKE_BUILD_TYPE})
#set(BOOST_ROOT /usr/local/)
#set(BOOST_INCLUDEDIR /usr/local/include/)
#set(BOOST_LIBRARYDIR /usr/local/lib64/)
#set(Boost_NO_SYSTEM_PATHS TRUE)
FIND_PACKAGE(Boost 1.72.0 COMPONENTS thread system filesystem date_time timer chrono regex REQUIRED)
INCLUDE_DIRECTORIES(${Boost_INCLUDE_DIR})
LINK_DIRECTORIES(${Boost_LIBRARY_DIRS})
# OpenCV library
FIND_PACKAGE(OpenCV 4.1 REQUIRED)
INCLUDE_DIRECTORIES(${OpenCV_INCLUDE_DIRS})
LINK_DIRECTORIES(${OpenCV_LIBS})
message(STATUS "OpenCV include=" ${OpenCV_INCLUDE_DIRS})
message(STATUS "OpenCV libs=" ${OpenCV_LIBS})
message(STATUS "CMAKE_DL_LIBS=" ${CMAKE_DL_LIBS})
set(Boost_USE_MULTITHREADED ON)
set(Boost_USE_STATIC_LIBS ON)
set(Boost_USE_STATIC_RUNTIME ON)
find_package(GTest REQUIRED)
find_package(Eigen3 3.3 REQUIRED NO_MODULE)
include_directories(${EIGEN3_INCLUDE_DIR})
find_package(HDF5 REQUIRED)
# Set the path of the utils directory
set(UTILS ${PROJECT_SOURCE_DIR}/utils)
set(ALGORITHMS ${PROJECT_SOURCE_DIR}/algorithms)
set(INFRA ${PROJECT_SOURCE_DIR}/infra)
# Initiate compilation of submodules
# inside a hosting repository
message(STATUS "CMAKE_CUDA_ARCHITECTURES: ${CMAKE_CUDA_ARCHITECTURES}$")
ADD_SUBDIRECTORY(${UTILS})
ADD_SUBDIRECTORY(${ALGORITHMS})
ADD_SUBDIRECTORY(${INFRA})
System setup
OS Rocky 8.6/8.7
NVHPC versions 22.9,22.11,23.3 (I tried all this version using cuda 11.8 or cuda 11.7)
Cmake version 3.20 and 3.26
What is wrong with my camke and should I fix it?
Do you have the full output from the error or is this all that was printed?
Typically system include directories are implicitly included so it’s unclear why explicitly adding it via the -isystem flag would cause an error.
Hi
In addition to that the full error report was added.
When I compiled over another machine which has functional NVHPC package I couldn’t find at cmake artifacts any command -isystem=/usr/include or -isystem /usr/include
In addition to that When I am compile the code using Cuda which was install using standard install there was not any compilation issue
My theory would be that there’s an incompatibility between the system header files and the host compiler that nvcc is using (likely g++ in this case, but I’m not sure). For example with nvc++, we sometime need to provide our own modified version of a system header file to work around some issue, which in turn use “include_next” to then load the actual system include. If “-I/usr/include” is added before the our includes paths, this causes the system include to be loaded before ours, and hence the work around is not applied.
Though given the information you’ve provided is incomplete, I can’t be sure this is correct. Besides the command line and the “In file included …” headers, does the output show more information, in particular the error message as to why the compilation failed?
Which more information should I provide in order to help the analysis process?
And which modifications should I done at my cmake files to enable successful compilation?
The full text from the output from the failing compilation line.
I’m not an expert in using cmake, so don’t know but likely it’s being include from one of the INCLUDE_DIRECTORIES. Right now I’m just gathering information so I can pass it on to another engineer who may know more.
I am attach a log file of Cmake and build commands.
Please inform if there is need for further information.
CompilationFile.log (66.0 KB)
Thanks, here’s the error in your log:
/usr/include/c++/8/cmath:45:15: fatal error: math.h: No such file or directory
 #include_next <math.h>
compilation terminated.
Which I can reproduce with this simple example:
% cat test.cpp
#include <cmath>
% g++ -c test.cpp -isystem /usr/include
In file included from test.cpp:1:
Likely there’s an ordering problem when putting the “/usr/include” path before the path to the C++ headers.
I’m asking our cmake experts here what could be adding this flag.
