Face embeddings with deepstream peoplenet
rtx 4060
• DeepStream Version
ds7.1
• TensorRT Version
default
default
unable to print the embedding using sgie, pgie model using peoplenet
I will like to have a guide to implement resnet model into deepstream, I have successfully loaded the face-embeddings model as sgie.
The code below provided
import sys
sys.path.append('../')
import os
import gi
gi.require_version('Gst', '1.0')
from gi.repository import GLib, Gst
from common.platform_info import PlatformInfo
from common.bus_call import bus_call
import pyds
PGIE_CLASS_ID_PERSON = 0
PGIE_CLASS_ID_BAG = 1
PGIE_CLASS_ID_FACE = 2
MUXER_BATCH_TIMEOUT_USEC = 33000
def osd_sink_pad_buffer_probe(pad,info,u_data):
    frame_number=0
    num_rects=0
    gst_buffer = info.get_buffer()
    if not gst_buffer:
        print("Unable to get GstBuffer")
        return
    # Retrieve batch metadata from the gst_buffer
    # Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
    # C address of gst_buffer as input, which is obtained with hash(gst_buffer)
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    l_frame = batch_meta.frame_meta_list
    while l_frame is not None:
        try:
            # Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
            # The casting is done by pyds.NvDsFrameMeta.cast()
            # The casting also keeps ownership of the underlying memory
            # in the C code, so the Python garbage collector will leave
            # it alone.
        except StopIteration:
            break
        #Intiallizing object counter with 0.
        obj_counter = {
            PGIE_CLASS_ID_PERSON:0,
            PGIE_CLASS_ID_BAG:0,
            PGIE_CLASS_ID_FACE:0,
        frame_number=frame_meta.frame_num
        num_rects = frame_meta.num_obj_meta
        l_obj=frame_meta.obj_meta_list
        while l_obj is not None:
            try:
                # Casting l_obj.data to pyds.NvDsObjectMeta
                obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
                break
            obj_counter[obj_meta.class_id] += 1
            obj_meta.rect_params.border_color.set(0.0, 0.0, 1.0, 0.8) #0.8 is alpha (opacity)
            try:
                l_obj=l_obj.next
                break
        # Acquiring a display meta object. The memory ownership remains in
        # the C code so downstream plugins can still access it. Otherwise
        # the garbage collector will claim it when this probe function exits.
        display_meta=pyds.nvds_acquire_display_meta_from_pool(batch_meta)
        display_meta.num_labels = 1
        py_nvosd_text_params = display_meta.text_params[0]
        # Setting display text to be shown on screen
        # Note that the pyds module allocates a buffer for the string, and the
        # memory will not be claimed by the garbage collector.
        # Reading the display_text field here will return the C address of the
        # allocated string. Use pyds.get_string() to get the string content.
        py_nvosd_text_params.display_text = "Frame Number={} Number of Objects={} Bag_count={} Face_count={}".format(frame_number, num_rects, obj_counter[PGIE_CLASS_ID_BAG], obj_counter[PGIE_CLASS_ID_FACE])
        # Now set the offsets where the string should appear
        py_nvosd_text_params.x_offset = 10
        py_nvosd_text_params.y_offset = 12
        # Font , font-color and font-size
        py_nvosd_text_params.font_params.font_name = "Serif"
        py_nvosd_text_params.font_params.font_size = 10
        # set(red, green, blue, alpha); set to White
        py_nvosd_text_params.font_params.font_color.set(1.0, 1.0, 1.0, 1.0)
        # Text background color
        py_nvosd_text_params.set_bg_clr = 1
        # set(red, green, blue, alpha); set to Black
        py_nvosd_text_params.text_bg_clr.set(0.0, 0.0, 0.0, 1.0)
        # Using pyds.get_string() to get display_text as string
        # print(pyds.get_string(py_nvosd_text_params.display_text))
        pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)
        try:
            l_frame=l_frame.next
            break
    return Gst.PadProbeReturn.OK
def pgie_src_pad_buffer_probe(pad, info, u_data):
    if not gst_buffer:
        try:
            break
        l_obj = frame_meta.obj_meta_list
        face_class_detected = False
            try:
                obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
                break
            if obj_meta.class_id == PGIE_CLASS_ID_FACE:
                face_class_detected = True
                break
            try:
                l_obj = l_obj.next
                break
        # if not face_class_detected:
        #     # No class 1 detected, clear objects so sgie does nothing
        #     frame_meta.obj_meta_list = None
        #     frame_meta.num_obj_meta = 0
        try:
            l_frame = l_frame.next
            break
def sgie_src_pad_buffer_probe(pad, info, u_data):
    # Get buffer and batch metadata
    if not buffer:
        print("Unable to get buffer")
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(buffer))
    if not batch_meta:
        print("No batch metadata available")
    # Iterate through frames in the batch
        try:
            break
        # Iterate through objects in the frame
            try:
                break
            if obj_meta.unique_component_id == 1:
                if obj_meta.class_id == 2:
                    l_user = obj_meta.obj_user_meta_list
            # print(obj_meta.unique_component_id)
            # print(obj_meta.class_id)
            # print(obj_meta.object_id)
            # print(obj_meta.confidence)
            # print(obj_meta.detector_bbox_info)
            # print(obj_meta.tracker_bbox_info)
            # print(obj_meta.tracker_confidence)
            # print(obj_meta.rect_params)
            # print(obj_meta.mask_params)
            # print(obj_meta.text_params)
            # print(obj_meta.obj_label)
            # print(obj_meta.classifier_meta_list)
            # print(obj_meta.obj_user_meta_list)
            # print(obj_meta.misc_obj_info)
            # print(obj_meta.reserved)
            # Filter for class ID 2 (faces)
                # Iterate through user metadata for tensor data
                while l_user is not None:
                    try:
                        user_meta = pyds.NvDsUserMeta.cast(l_user.data)
                        # Check for tensor metadata from sgie (gie-unique-id=2)
                        if (user_meta.base_meta.meta_type == pyds.nvds_get_user_meta_type("NVIDIA.TENSOR_OUTPUT_USER_META") and
                            user_meta.base_meta.component_id == 2):
                            tensor_meta = pyds.NvDsTensorMeta.cast(user_meta.user_meta_data)
                            # Extract and print embeddings (assuming FLOAT data type)
                            for layer in tensor_meta.tensor_layer:
                                if layer.data_type == 0:  # FLOAT
                                    embedding = np.array(pyds.get_tensor_data_float(layer), dtype=np.float32)
                                    print(f"Frame {frame_meta.frame_num}, Object {obj_meta.object_id}, Face Embedding: {embedding.tolist()}")
                        break
                    try:
                        l_user = l_user.next
                        break
            try:
                l_obj = l_obj.next
                break
        try:
            break
def main(args):
    # Check input arguments
    if len(args) != 2:
        sys.stderr.write("usage: %s <media file or uri>\n" % args[0])
        sys.exit(1)
    platform_info = PlatformInfo()
    # Standard GStreamer initialization
    Gst.init(None)
    # Create gstreamer elements
    # Create Pipeline element that will form a connection of other elements
    print("Creating Pipeline \n ")
    pipeline = Gst.Pipeline()
    if not pipeline:
        sys.stderr.write(" Unable to create Pipeline \n")
    # Source element for reading from the file
    print("Creating Source \n ")
    source = Gst.ElementFactory.make("filesrc", "file-source")
    if not source:
        sys.stderr.write(" Unable to create Source \n")
    # Since the data format in the input file is elementary h264 stream,
    # we need a h264parser
    print("Creating H264Parser \n")
    h264parser = Gst.ElementFactory.make("h264parse", "h264-parser")
    if not h264parser:
        sys.stderr.write(" Unable to create h264 parser \n")
    # Use nvdec_h264 for hardware accelerated decode on GPU
    print("Creating Decoder \n")
    decoder = Gst.ElementFactory.make("nvv4l2decoder", "nvv4l2-decoder")
    if not decoder:
        sys.stderr.write(" Unable to create Nvv4l2 Decoder \n")
    # Create nvstreammux instance to form batches from one or more sources.
    streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
    if not streammux:
        sys.stderr.write(" Unable to create NvStreamMux \n")
    # Use nvinfer to run inferencing on decoder's output,
    # behaviour of inferencing is set through config file
    pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
    if not pgie:
        sys.stderr.write(" Unable to create pgie \n")
    sgie = Gst.ElementFactory.make("nvinfer", "secondary-inference")
    if not sgie:
        sys.stderr.write(" Unable to create sgie \n")
    # Use convertor to convert from NV12 to RGBA as required by nvosd
    nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
    if not nvvidconv:
        sys.stderr.write(" Unable to create nvvidconv \n")
    # Create OSD to draw on the converted RGBA buffer
    nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
    if not nvosd:
        sys.stderr.write(" Unable to create nvosd \n")
    # Finally render the osd output
    if platform_info.is_integrated_gpu():
        print("Creating nv3dsink \n")
        sink = Gst.ElementFactory.make("nv3dsink", "nv3d-sink")
        if not sink:
            sys.stderr.write(" Unable to create nv3dsink \n")
    else:
        if platform_info.is_platform_aarch64():
        else:
            print("Creating EGLSink \n")
            sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
        if not sink:
            sys.stderr.write(" Unable to create egl sink \n")
    print("Playing file %s " %args[1])
    source.set_property('location', args[1])
    if os.environ.get('USE_NEW_NVSTREAMMUX') != 'yes': # Only set these properties if not using new gst-nvstreammux
        streammux.set_property('width', 1920)
        streammux.set_property('height', 1080)
        streammux.set_property('batched-push-timeout', MUXER_BATCH_TIMEOUT_USEC)
    streammux.set_property('batch-size', 1)
    pgie.set_property('config-file-path', "dstest1_pgie_config.txt")
    sgie.set_property('config-file-path', "dstest1_sgie_config.txt")
    print("Adding elements to Pipeline \n")
    pipeline.add(source)
    pipeline.add(h264parser)
    pipeline.add(decoder)
    pipeline.add(streammux)
    pipeline.add(pgie)
    pipeline.add(sgie)
    pipeline.add(nvvidconv)
    pipeline.add(nvosd)
    pipeline.add(sink)
    # we link the elements together
    # file-source -> h264-parser -> nvh264-decoder ->
    # nvinfer -> nvvidconv -> nvosd -> video-renderer
    print("Linking elements in the Pipeline \n")
    source.link(h264parser)
    h264parser.link(decoder)
    # Get the source pad of decoder and link it to streammux's sink pad
    sinkpad = streammux.get_request_pad("sink_0")
    if not sinkpad:
        sys.stderr.write(" Unable to get the sink pad of streammux\n")
    srcpad = decoder.get_static_pad("src")
    if not srcpad:
        sys.stderr.write(" Unable to get source pad of decoder\n")
    # Link the decoder's src pad to streammux's sink pad
    if srcpad.link(sinkpad) != Gst.PadLinkReturn.OK:
        sys.stderr.write(" Failed to link decoder to streammux\n")
    # Link the remaining elements in the pipeline
    if not streammux.link(pgie):
        sys.stderr.write(" Failed to link streammux to pgie\n")
    if not pgie.link(sgie):
        sys.stderr.write(" Failed to link pgie to sgie\n")
    if not sgie.link(nvvidconv):
        sys.stderr.write(" Failed to link sgie to nvvidconv\n")
    if not nvvidconv.link(nvosd):
        sys.stderr.write(" Failed to link nvvidconv to nvosd\n")
    if not nvosd.link(sink):
        sys.stderr.write(" Failed to link nvosd to sink\n")
    sgie_srcpad = sgie.get_static_pad("src")
    if not sgie_srcpad:
        sys.stderr.write(" Unable to get src pad of sgie\n")
    else:
        sgie_srcpad.add_probe(Gst.PadProbeType.BUFFER, sgie_src_pad_buffer_probe, 0)
    # create an event loop and feed gstreamer bus mesages to it
    loop = GLib.MainLoop()
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect ("message", bus_call, loop)
    # Lets add probe to get informed of the meta data generated, we add probe to
    # the sink pad of the osd element, since by that time, the buffer would have
    # had got all the metadata.
    osdsinkpad = nvosd.get_static_pad("sink")
    if not osdsinkpad:
        sys.stderr.write(" Unable to get sink pad of nvosd \n")
    osdsinkpad.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, 0)
    # start play back and listen to events
    print("Starting pipeline \n")
    pipeline.set_state(Gst.State.PLAYING)
    try:
        loop.run()
    except:
        pass
    # cleanup
    pipeline.set_state(Gst.State.NULL)
if __name__ == '__main__':
    sys.exit(main(sys.argv))
This is my sgie config file
[property]
gpu-id=0
onnx-file=./recognition_resnet27.onnx
model-engine-file=/home/wesenkhoo2/Documents/deepstream_python_apps/apps/deepstream-test1/recognition_resnet27.onnx_b1_gpu0_fp16.engine
batch-size=1
network-mode=3
gie-unique-id=2
interval=0
net-scale-factor=0.00392156862745098
operate-on-class-ids=2
# Feature extraction mode (no bbox or class parsing)
network-type=100
output-tensor-meta=1
You need to parse the tensor_output_data after the inference based on your model.
You can refer to our sample deepstream_ssd_parser.py to get the tensor_output_data.
<capsule object NULL at 0x7f50266cd200>
I get something like this, which means there’s nothing inside the inference?
def preprocess_image_for_onnx(image: np.ndarray, size=(128, 128)):
    Preprocess a Pillow image for ONNX model inference.
    Args:
        image (np.ndarray): Path to the image file.
        size (tuple): Target size for the image (width, height).
    Returns:
        np.ndarray: Preprocessed image batch of shape (1, Channels, Height, Width).
    # Resize the image
    resized_image = cv2.resize(image, size)
    # Convert to NumPy array
    image_array = np.array(resized_image, dtype=np.float32)
    # Normalize pixel values to [0, 1] or other normalization (e.g., mean/std scaling)
    image_array /= 255.0  # Scale to [0, 1]
    # Rearrange dimensions to (Channels, Height, Width) from (Height, Width, Channels)
    image_array = np.transpose(image_array, (2, 0, 1))
    # Add batch dimension to make it (1, Channels, Height, Width)
    image_array = np.expand_dims(image_array, axis=0)
    return image_array
before that I use onnxruntime to run the inferencing, this is the code above that I have convert the cv image to the pillow format, do i need to do it in deepstream?
Yes. We suggest that you first run our sample attached to get familiar with the process.
No. DeepStream has its own decoding part.
