• Hardware Platform (Jetson / GPU): jetson nano • DeepStream Version : 2.0 DP • JetPack Version (valid for Jetson only) : 4.4 DP • TensorRT Version : 7.1
I want to run FaceDetection-IR on jetson nano using deep stream sdk. I installed the deep stream sdk and I follow the below commnad and I get a error:
1- in the directory :
This command you mentioned only downloads facedetectir_int8.txt and resnet18_facedetectir_pruned.etlt.
engine file is optional because etlt can be loaded and converted into engine at runtime if engine file does not exist.
Could you please provide what you have done (commands executed) step by step, and what error you have met, so that we can look into your problem precisely.
I’m also deeply interested in instruction on how to gain tensor metadata not only for SSD but for other models like DetectNet_v2 models such as FaceDetectIR.
Thank you for sharing!
it worked great with video file input.
Is there a code that crops & save to file?
I wasn’t able to get the peoplenet/ faceir to work with usb camera [ tried stereolabs zed camera as input] .Though
Also only peoplenet did show any detections visually.
@MingGatsby which exactly is the problem you are running into? If to follow the url mentioned above you might find the extended stepsw to run the deepstream applications.
