FacialLandmarks python multiple faces issue
Jetson Orin 4012, NVIDIA Jetson Orin NX Bundle, 8x 2GHz, 16GB DDR5
• DeepStream Version
Container: deepstream:7.0-triton-multiarch
see Container: deepstream:7.0-triton-multiarch
• TensorRT Version
$ nvidia-smi
Returns: Driver Version: N/A
Issue
I am running the following gstreamer pipeline in python via the provided bindings:
gst-launch-1.0 v4l2src device=/dev/video0 !  nvvideoconvert src-crop=0:0:1920:1080 ! m.sink_0 nvstreammux name=m batch-size=1 live-source=1 width=1280 height=720 ! nvinfer config-file-path=configs/facedetect.yml ! nvinfer config-file-path=ai_pipeline/configs/landmarks.yml ! fakesink
I added the following landmark probe to the landmarks infer stage:
def _landmarks_inference_probe(self, pad: Gst.Pad, info: Gst.PadProbeInfo) -> None:
    buffer = info.get_buffer()
    if not buffer:
      return Gst.PadProbeReturn.OK
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(buffer))
    l_frame = batch_meta.frame_meta_list
    while l_frame is not None:
      try:
      except StopIteration:
        break
      l_object = frame_meta.obj_meta_list
      faces: List[Face] = []
      id: int = 0
      obj_counter = 0
      while l_object is not None: # Loop through found faces
        try:
          obj_meta = pyds.NvDsObjectMeta.cast(l_object.data)
          break
        log.info(f'obj: {obj_counter}')
        obj_counter += 1
        left: float = obj_meta.detector_bbox_info.org_bbox_coords.left
        top: float = obj_meta.detector_bbox_info.org_bbox_coords.top
        width: float = obj_meta.detector_bbox_info.org_bbox_coords.width
        height: float = obj_meta.detector_bbox_info.org_bbox_coords.height
        landmarks: List[Point] = []
        l_user = obj_meta.obj_user_meta_list
        user_counter = 0
        while l_user is not None:
          try:
            user_meta = pyds.NvDsUserMeta.cast(l_user.data)
            break
          if (user_meta.base_meta.meta_type != pyds.NvDsMetaType.NVDSINFER_TENSOR_OUTPUT_META):
            continue
          log.info(f'usr: {user_counter}')
          user_counter += 1
          tensor_meta = pyds.NvDsInferTensorMeta.cast(user_meta.user_meta_data)
          frame_outputs = []
          output_shapes = [[80,80,80],[80,2],[80]]
          for i in range(tensor_meta.num_output_layers):
            layer = pyds.get_nvds_LayerInfo(tensor_meta, i)
            # Convert NvDsInferLayerInfo buffer to numpy array
            ptr = ctypes.cast(pyds.get_ptr(layer.buffer), ctypes.POINTER(ctypes.c_float))
            v = np.ctypeslib.as_array(ptr, shape=(output_shapes[i]))
            frame_outputs.append(v)
          landmarks: List[Point] = Landmarks.from_pipeline_inference_output(frame_outputs)
          try:
            l_user = l_user.next
            break
        face = Face(
          id,
          left,
          top,
          width,
          height,
          landmarks,
          frame_outputs[2], #landmark_confidences
        faces.append(face)
        id += 1
        log.info(f'{face}')
        try:
          l_object = l_object.next
          break
      log.info(f'{faces}')
      try:
        l_frame = l_frame.next
        break
I thought everythin was working fine first, but when teesting with multiple found faces within the frame, i noticed that the landmarks of the last face found (face 2 with 2 found faces, face 3 with 3 found faces etc…) are scattered all over the place. Am i doing something wrong while retrieving the landmarks for each found face?
We know nothing about your models and implementation, you may need to debug by yourself.
At least the pipeline is fine as your description.
I am using the models and their configs as provided by NVIDIA:
Currently i am extracting all the inferred data in the probe added to the source-pad of the nvinfer element created by:
self.landmarks_infer = Gst.ElementFactory.make('nvinfer', 'nvinfer_landmarks')
self.landmarks_infer.set_property('config-file-path', 'ai_pipeline/configs/landmarks.yml')
Probe gets added by:
inference_src_pad: Optional[Gst.Pad] = self.landmarks_infer.get_static_pad('src')
if not inference_src_pad:
  raise RuntimeError(f'[{os.getpid()} {GazenetPipeline.__name__}] Failed to get src pad from landmark_infer')
inference_src_pad.add_probe(Gst.PadProbeType.BUFFER, self._landmarks_inference_probe)
Code is inspired by discussion: : GazeNet - Python Implimentation
After closer inspection of the sample (deepstream_tao_apps/apps/tao_others/deepstream-faciallandmark-app/deepstream_faciallandmark_app.cpp at release/tao5.3_ds7.0ga · NVIDIA-AI-IOT/deepstream_tao_apps · GitHub) i see, that the sample is using 2 probes, 1 one the source-pad of the pgies next queue element and 1 of the source pad of the sgies next queue element.
My question now is: Do i have to mirror that setup exactly in my python code and if so: Why does it kinda work the way i am doing it right now with just a single probe at the landmark nvinfers src-pad, but only with a single face found?
It feels like i am looping through the frame meta in a slightly wrong way, but am not able to see whats wrong. Appreciate your help!
Since deepstream_tao_apps/apps/tao_others/deepstream-faciallandmark-app/deepstream_faciallandmark_app.cpp at release/tao5.3_ds7.0ga · NVIDIA-AI-IOT/deepstream_tao_apps · GitHub works, please implement your app as the sample.
Setting the batch-size parameter to 1 seemed to fix the issue. Can’t really explain why^^
landmarks_config.yml:
#Source: https://github.com/NVIDIA-AI-IOT/deepstream_tao_apps/blob/release/tao5.3_ds7.0ga/configs/nvinfer/facial_tao/faciallandmark_sgie_config.yml
property:
  gpu-id: 0
  model-engine-file: ../models/landmarks/model.etlt_b32_gpu0_int8.engine
  tlt-model-key: nvidia_tlt
  tlt-encoded-model: ../models/landmarks/model.etlt
  int8-calib-file: ../models/landmarks/int8_calibration.txt
  #dynamic batch size
  batch-size: 1
  ## 0=FP32, 1=INT8, 2=FP16 mode
  network-mode: 1
  num-detected-classes: 1
  output-blob-names: 'softargmax;softargmax:1;conv_keypoints_m80'
  #0=Detection 1=Classifier 2=Segmentation 100=other
  network-type: 100
  # Enable tensor metadata output
  output-tensor-meta: 1
  #1-Primary  2-Secondary
  process-mode: 2
  gie-unique-id: 2
  operate-on-gie-id: 1
  net-scale-factor: 1.0
  offsets: '0.0'
  input-object-min-width: 5
  input-object-min-height: 5
  #0=RGB 1=BGR 2=GRAY
  model-color-format: 2
class-attrs-all:
  pre-cluster-threshold: 0.0
Python code to extract informations:
def _add_landmarks_inference_probe(self) -> None:
    raise RuntimeError(f' Failed to get src pad from landmark_infer')
  if not buffer:
    try:
      break
      try:
        break
      # Extract bounding box information for found faces
      while l_user is not None: # Loop through user meta (landmark meta in this case)?
        try:
          break
          continue
        frame_outputs = []
        landmarks: List[Point] = [Point(x, y) for x, y in frame_outputs[1]]
        landmark_confidences: List[float] = frame_outputs[2]
        face = Face(
          left,
          top,
          width,
          height,
          landmarks,
          landmark_confidences,
        faces.append(face)
        try:
          break
      try:
        break
      # List of faces + their landmark data found in frame
      print(faces)
    try:
      break
