Fail to run doca flow samples on dpu
The samples built fine but won’t run. I tried flow_drop and flow_hairpin,they both failed
Here are the details and error message:
root@localhost:/home/ubuntu/mellanox/doca/samples/doca_flow/flow_drop/build# ./doca_flow_drop -a auxiliary:mlx5_core.sf.4 -a auxiliary:mlx5_core.sf.5 – -l 60
and the error is
[12:27:51:390208][DOCA][ERR][dpdk_flow_hws_legacy:81]: failed to configure flow hws port 0 - rte flow configure, type 1 message: port configure with incorrect steering mode
And the full run output is:
EAL: Detected CPU lcores: 8
EAL: Detected NUMA nodes: 1
EAL: Detected shared linkage of DPDK
EAL: Multi-process socket /var/run/dpdk/rte/mp_socket
EAL: Selected IOVA mode ‘PA’
TELEMETRY: No legacy callbacks, legacy socket not created
[12:27:51:065275][DOCA][DBG][NUTILS:533]: Port 0 MAC: 00 00 00 00 04 00
[12:27:51:288932][DOCA][DBG][NUTILS:533]: Port 1 MAC: 00 00 00 00 04 01
[12:27:51:292929][DOCA][INF][engine_model:73]: engine model defined with mode=vnf
[12:27:51:292959][DOCA][INF][engine_model:75]: engine model defined with nr_pipe_queues=8
[12:27:51:292974][DOCA][INF][engine_model:76]: engine model defined with pipe_queue_depth=0
[12:27:51:296291][DOCA][INF][engine_field_mapping:329]: Engine field mapping initialized
[12:27:51:296364][DOCA][INF][engine_shared_resources:94]: Engine shared resources initialized successfully
[12:27:51:296401][DOCA][INF][dpdk_engine:326]: queue depth is zero, set it to default 128.
[12:27:51:296415][DOCA][INF][dpdk_engine:331]: ACL number of collisions is zero, set it to default 1
[12:27:51:296433][DOCA][INF][dpdk_pipe_items:175]: Initialized dpdk pipe items module
[12:27:51:296473][DOCA][DBG][dpdk_table_hws:907]: Initialized dpdk table work module to be HW steering
[12:27:51:296488][DOCA][INF][dpdk_table:70]: Initializing dpdk table successfully
[12:27:51:296501][DOCA][DBG][dpdk_flow_hws:36]: Initialized dpdk flow work module to be HW steering
[12:27:51:296514][DOCA][INF][dpdk_flow:56]: Initializing dpdk flow successfully
[12:27:51:296527][DOCA][INF][dpdk_resource_manager:184]: Dpdk resource manager register completed
[12:27:51:296711][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.meta.port, offset=0)
[12:27:51:296731][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.meta.mark, offset=0)
[12:27:51:296744][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.meta.nisp_syndrome, offset=0)
[12:27:51:296757][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.meta.ipsec_syndrome, offset=0)
[12:27:51:296772][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.outer.eth.dst_mac, offset=0)
[12:27:51:296786][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.outer.eth.src_mac, offset=6)
[12:27:51:296800][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.outer.eth.type, offset=12)
[12:27:51:296814][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.inner.eth.dst_mac, offset=0)
[12:27:51:296829][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.inner.eth.src_mac, offset=6)
[12:27:51:296842][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.inner.eth.type, offset=12)
[12:27:51:296855][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.outer.eth_vlan0.tci, offset=0)
[12:27:51:296869][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.outer.eth_vlan1.tci, offset=0)
[12:27:51:296882][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.inner.eth_vlan0.tci, offset=0)
[12:27:51:296895][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.inner.eth_vlan1.tci, offset=0)
[12:27:51:296908][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.outer.ipv4.src_ip, offset=12)
[12:27:51:296923][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.outer.ipv4.dst_ip, offset=16)
[12:27:51:296938][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.outer.ipv4.dscp_ecn, offset=1)
[12:27:51:296951][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.outer.ipv4.next_proto, offset=9)
[12:27:51:296967][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.outer.ipv4.ttl, offset=8)
[12:27:51:296980][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.outer.ipv4.version_ihl, offset=0)
[12:27:51:296995][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.inner.ipv4.src_ip, offset=12)
[12:27:51:297009][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.inner.ipv4.dst_ip, offset=16)
[12:27:51:297022][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.inner.ipv4.dscp_ecn, offset=1)
[12:27:51:297036][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.inner.ipv4.next_proto, offset=9)
[12:27:51:297048][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.inner.ipv4.ttl, offset=8)
[12:27:51:297060][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.inner.ipv4.version_ihl, offset=0)
[12:27:51:297073][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.outer.ipv6.src_ip, offset=8)
[12:27:51:297086][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.outer.ipv6.dst_ip, offset=24)
[12:27:51:297099][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.outer.ipv6.dscp_ecn, offset=0)
[12:27:51:297111][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.outer.ipv6.next_proto, offset=6)
[12:27:51:297124][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.outer.ipv6.hop_limit, offset=7)
[12:27:51:297137][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.inner.ipv6.src_ip, offset=8)
[12:27:51:297151][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.inner.ipv6.dst_ip, offset=24)
[12:27:51:297165][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.inner.ipv6.dscp_ecn, offset=0)
[12:27:51:297177][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.inner.ipv6.next_proto, offset=6)
[12:27:51:297191][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.inner.ipv6.hop_limit, offset=7)
[12:27:51:297206][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.outer.udp.src_port, offset=0)
[12:27:51:297220][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.outer.udp.dst_port, offset=2)
[12:27:51:297232][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.inner.udp.src_port, offset=0)
[12:27:51:297245][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.inner.udp.dst_port, offset=2)
[12:27:51:297258][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.outer.tcp.src_port, offset=0)
[12:27:51:297272][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.outer.tcp.dst_port, offset=2)
[12:27:51:297286][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.outer.tcp.flags, offset=13)
[12:27:51:297299][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.inner.tcp.src_port, offset=0)
[12:27:51:297313][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.inner.tcp.dst_port, offset=2)
[12:27:51:297325][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.inner.tcp.flags, offset=13)
[12:27:51:297338][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.outer.icmp4.type, offset=0)
[12:27:51:297352][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.outer.icmp4.code, offset=1)
[12:27:51:297365][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.outer.icmp4.ident, offset=4)
[12:27:51:297377][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.inner.icmp4.type, offset=0)
[12:27:51:297389][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.inner.icmp4.code, offset=1)
[12:27:51:297453][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.inner.icmp4.ident, offset=4)
[12:27:51:297467][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.outer.icmp6.type, offset=0)
[12:27:51:297481][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.outer.icmp6.code, offset=1)
[12:27:51:297495][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.inner.icmp6.type, offset=0)
[12:27:51:297508][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.inner.icmp6.code, offset=1)
[12:27:51:297523][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.tunnel.vxlan.vni, offset=4)
[12:27:51:297537][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.tunnel.gre_key.value, offset=0)
[12:27:51:297550][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.tunnel.gre.protocol, offset=2)
[12:27:51:297566][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.tunnel.gtp.teid, offset=4)
[12:27:51:297580][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.tunnel.mpls.label, offset=0)
[12:27:51:297594][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.tunnel.audp.hdr, offset=0)
[12:27:51:297608][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.tunnel.nisp.hdr, offset=0)
[12:27:51:297621][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.tunnel.geneve.ver_opt_len, offset=0)
[12:27:51:297635][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.tunnel.geneve.o_c, offset=1)
[12:27:51:297649][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.tunnel.geneve.next_proto, offset=2)
[12:27:51:297661][DOCA][DBG][dpdk_layer:81]: Registered dpdk field opcode=match.packet.tunnel.geneve.vni, offset=4)
[12:27:51:297673][DOCA][INF][dpdk_layer:404]: Dpdk layer register completed
[12:27:51:297687][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.meta.data, offset=4, len=20)
[12:27:51:297701][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.meta.port, offset=28, len=4)
[12:27:51:297713][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.meta.mark, offset=32, len=4)
[12:27:51:297743][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.meta.nisp_syndrome, offset=36, len=1)
[12:27:51:297783][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.meta.ipsec_syndrome, offset=37, len=1)
[12:27:51:297799][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.meta.flags, offset=0, len=4)
[12:27:51:297813][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.eth.dst_mac, offset=46, len=6)
[12:27:51:297827][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.eth.src_mac, offset=40, len=6)
[12:27:51:297841][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.eth.type, offset=52, len=2)
[12:27:51:297854][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.eth.dst_mac, offset=162, len=6)
[12:27:51:297867][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.eth.src_mac, offset=156, len=6)
[12:27:51:297881][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.eth.type, offset=168, len=2)
[12:27:51:297896][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.eth_vlan0.tci, offset=56, len=2)
[12:27:51:297909][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.eth_vlan1.tci, offset=58, len=2)
[12:27:51:297923][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.eth_vlan0.tci, offset=172, len=2)
[12:27:51:297936][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.eth_vlan1.tci, offset=174, len=2)
[12:27:51:297949][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.ipv4.src_ip, offset=64, len=4)
[12:27:51:297964][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.ipv4.dst_ip, offset=68, len=4)
[12:27:51:297977][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.ipv4.dscp_ecn, offset=73, len=1)
[12:27:51:297991][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.ipv4.next_proto, offset=74, len=1)
[12:27:51:298005][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.ipv4.ttl, offset=75, len=1)
[12:27:51:298019][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.ipv4.version_ihl, offset=72, len=1)
[12:27:51:298033][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.ipv4.src_ip, offset=180, len=4)
[12:27:51:298046][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.ipv4.dst_ip, offset=184, len=4)
[12:27:51:298060][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.ipv4.dscp_ecn, offset=189, len=1)
[12:27:51:298073][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.ipv4.next_proto, offset=190, len=1)
[12:27:51:298087][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.ipv4.ttl, offset=191, len=1)
[12:27:51:298101][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.ipv4.version_ihl, offset=188, len=1)
[12:27:51:298115][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.ipv6.src_ip, offset=64, len=16)
[12:27:51:298129][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.ipv6.dst_ip, offset=80, len=16)
[12:27:51:298142][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.ipv6.dscp_ecn, offset=96, len=1)
[12:27:51:298154][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.ipv6.next_proto, offset=97, len=1)
[12:27:51:298167][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.ipv6.hop_limit, offset=98, len=1)
[12:27:51:298207][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.ipv6.src_ip, offset=180, len=16)
[12:27:51:298222][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.ipv6.dst_ip, offset=196, len=16)
[12:27:51:298238][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.ipv6.dscp_ecn, offset=212, len=1)
[12:27:51:298252][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.ipv6.next_proto, offset=213, len=1)
[12:27:51:298266][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.ipv6.hop_limit, offset=214, len=1)
[12:27:51:298281][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.udp.src_port, offset=104, len=2)
[12:27:51:298294][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.udp.dst_port, offset=106, len=2)
[12:27:51:298308][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.udp.src_port, offset=220, len=2)
[12:27:51:298321][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.udp.dst_port, offset=222, len=2)
[12:27:51:298333][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.tcp.src_port, offset=104, len=2)
[12:27:51:298345][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.tcp.dst_port, offset=106, len=2)
[12:27:51:298359][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.tcp.flags, offset=108, len=1)
[12:27:51:298372][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.tcp.src_port, offset=220, len=2)
[12:27:51:298386][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.tcp.dst_port, offset=222, len=2)
[12:27:51:298400][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.tcp.flags, offset=224, len=1)
[12:27:51:298414][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.icmp4.type, offset=104, len=1)
[12:27:51:298428][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.icmp4.code, offset=105, len=1)
[12:27:51:298442][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.icmp4.ident, offset=106, len=2)
[12:27:51:298455][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.icmp4.type, offset=220, len=1)
[12:27:51:298469][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.icmp4.code, offset=221, len=1)
[12:27:51:298482][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.icmp4.ident, offset=222, len=2)
[12:27:51:298495][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.icmp6.type, offset=104, len=1)
[12:27:51:298509][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.icmp6.code, offset=105, len=1)
[12:27:51:298522][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.icmp6.type, offset=220, len=1)
[12:27:51:298535][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.icmp6.code, offset=221, len=1)
[12:27:51:298549][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.vxlan.vni, offset=116, len=3)
[12:27:51:298562][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.gre_key.value, offset=120, len=4)
[12:27:51:298575][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.gre.protocol, offset=118, len=2)
[12:27:51:298613][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.gtp.teid, offset=116, len=4)
[12:27:51:298628][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.nisp.hdr, offset=116, len=40)
[12:27:51:298641][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.audp.hdr, offset=116, len=24)
[12:27:51:298656][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.esp.spi, offset=116, len=4)
[12:27:51:298669][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.esp.sn, offset=120, len=4)
[12:27:51:298682][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.mpls.label.0, offset=116, len=4)
[12:27:51:298695][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.mpls.label.1, offset=120, len=4)
[12:27:51:298709][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.mpls.label.2, offset=124, len=4)
[12:27:51:298723][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.mpls.label.3, offset=128, len=4)
[12:27:51:298736][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.mpls.label.4, offset=132, len=4)
[12:27:51:298750][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.geneve.ver_opt_len, offset=116, len=1)
[12:27:51:298764][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.geneve.o_c, offset=117, len=1)
[12:27:51:298778][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.geneve.next_proto, offset=118, len=2)
[12:27:51:298791][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.geneve.vni, offset=120, len=3)
[12:27:51:298868][DOCA][INF][doca_flow_match:565]: Doca flow match UDS initialized
[12:27:51:298883][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.meta.data, offset=12, len=20)
[12:27:51:298896][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.meta.port, offset=36, len=4)
[12:27:51:298909][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.meta.mark, offset=40, len=4)
[12:27:51:298922][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.meta.nisp_syndrome, offset=44, len=1)
[12:27:51:298935][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.meta.ipsec_syndrome, offset=45, len=1)
[12:27:51:298948][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.eth.dst_mac, offset=54, len=6)
[12:27:51:298961][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.eth.src_mac, offset=48, len=6)
[12:27:51:298974][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.eth.type, offset=60, len=2)
[12:27:51:298988][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.eth_vlan0.tci, offset=64, len=2)
[12:27:51:299001][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.eth_vlan1.tci, offset=66, len=2)
[12:27:51:299014][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.ipv4.src_ip, offset=72, len=4)
[12:27:51:299027][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.ipv4.dst_ip, offset=76, len=4)
[12:27:51:299041][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.ipv4.dscp_ecn, offset=81, len=1)
[12:27:51:299055][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.ipv4.next_proto, offset=82, len=1)
[12:27:51:299070][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.ipv4.ttl, offset=83, len=1)
[12:27:51:299084][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.ipv4.version_ihl, offset=72, len=1)
[12:27:51:299098][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.ipv6.src_ip, offset=72, len=16)
[12:27:51:299111][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.ipv6.dst_ip, offset=88, len=16)
[12:27:51:299125][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.ipv6.dscp_ecn, offset=104, len=1)
[12:27:51:299138][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.ipv6.next_proto, offset=105, len=1)
[12:27:51:299153][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.ipv6.hop_limit, offset=106, len=1)
[12:27:51:299166][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.udp.src_port, offset=112, len=2)
[12:27:51:299179][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.udp.dst_port, offset=114, len=2)
[12:27:51:299193][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.tcp.src_port, offset=112, len=2)
[12:27:51:299271][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.tcp.dst_port, offset=114, len=2)
[12:27:51:299287][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.icmp4.type, offset=112, len=1)
[12:27:51:299301][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.icmp4.code, offset=113, len=1)
[12:27:51:299315][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.icmp4.ident, offset=114, len=2)
[12:27:51:299328][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.icmp6.type, offset=112, len=1)
[12:27:51:299342][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.icmp6.code, offset=113, len=1)
[12:27:51:299356][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.vxlan.vni, offset=124, len=3)
[12:27:51:299372][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.gre_key.value, offset=128, len=4)
[12:27:51:299386][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.gre.protocol, offset=126, len=2)
[12:27:51:299399][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.gtp.teid, offset=124, len=4)
[12:27:51:299412][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.nisp.hdr, offset=124, len=40)
[12:27:51:299427][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.audp.hdr, offset=124, len=24)
[12:27:51:299442][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.esp.spi, offset=124, len=4)
[12:27:51:299455][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.esp.sn, offset=128, len=4)
[12:27:51:299469][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.mpls.label.0, offset=124, len=4)
[12:27:51:299482][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.mpls.label.1, offset=128, len=4)
[12:27:51:299497][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.mpls.label.2, offset=132, len=4)
[12:27:51:299509][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.mpls.label.3, offset=136, len=4)
[12:27:51:299523][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.mpls.label.4, offset=140, len=4)
[12:27:51:299558][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.geneve.ver_opt_len, offset=116, len=1)
[12:27:51:299579][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.geneve.o_c, offset=117, len=1)
[12:27:51:299595][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.geneve.next_proto, offset=118, len=2)
[12:27:51:299609][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.geneve.vni, offset=120, len=3)
[12:27:51:299623][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.eth.dst_mac, offset=174, len=6)
[12:27:51:299636][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.eth.src_mac, offset=168, len=6)
[12:27:51:299650][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.eth.type, offset=180, len=2)
[12:27:51:299663][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.eth_vlan0.tci, offset=184, len=2)
[12:27:51:299677][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.eth_vlan1.tci, offset=186, len=2)
[12:27:51:299690][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.ipv4.src_ip, offset=192, len=4)
[12:27:51:299703][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.ipv4.dst_ip, offset=196, len=4)
[12:27:51:299717][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.ipv4.dscp_ecn, offset=201, len=1)
[12:27:51:299730][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.ipv4.next_proto, offset=202, len=1)
[12:27:51:299744][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.ipv4.ttl, offset=203, len=1)
[12:27:51:299757][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.ipv4.version_ihl, offset=200, len=1)
[12:27:51:299771][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.ipv6.src_ip, offset=192, len=16)
[12:27:51:299785][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.ipv6.dst_ip, offset=208, len=16)
[12:27:51:299798][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.ipv6.dscp_ecn, offset=224, len=1)
[12:27:51:299811][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.ipv6.next_proto, offset=225, len=1)
[12:27:51:299825][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.ipv6.hop_limit, offset=226, len=1)
[12:27:51:299839][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.udp.src_port, offset=232, len=2)
[12:27:51:299853][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.udp.dst_port, offset=234, len=2)
[12:27:51:299867][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.tcp.src_port, offset=232, len=2)
[12:27:51:299881][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.tcp.dst_port, offset=234, len=2)
[12:27:51:299894][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.icmp4.type, offset=232, len=1)
[12:27:51:299908][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.icmp4.code, offset=233, len=1)
[12:27:51:299921][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.icmp4.ident, offset=234, len=2)
[12:27:51:299935][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.icmp6.type, offset=232, len=1)
[12:27:51:299948][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.icmp6.code, offset=233, len=1)
[12:27:51:300009][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.vxlan.vni, offset=244, len=3)
[12:27:51:300026][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.gre_key.value, offset=248, len=4)
[12:27:51:300040][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.gre.protocol, offset=246, len=2)
[12:27:51:300055][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.gtp.teid, offset=244, len=4)
[12:27:51:300068][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.nisp.hdr, offset=244, len=40)
[12:27:51:300080][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.audp.hdr, offset=244, len=24)
[12:27:51:300093][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.esp.spi, offset=244, len=4)
[12:27:51:300106][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.esp.sn, offset=248, len=4)
[12:27:51:300120][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.mpls.label.0, offset=244, len=4)
[12:27:51:300134][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.mpls.label.1, offset=248, len=4)
[12:27:51:300147][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.mpls.label.2, offset=252, len=4)
[12:27:51:300161][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.mpls.label.3, offset=256, len=4)
[12:27:51:300174][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.mpls.label.4, offset=260, len=4)
[12:27:51:300188][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.geneve.ver_opt_len, offset=116, len=1)
[12:27:51:300201][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.geneve.o_c, offset=117, len=1)
[12:27:51:300214][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.geneve.next_proto, offset=118, len=2)
[12:27:51:300227][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.geneve.vni, offset=120, len=3)
[12:27:51:300241][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.alter.crypto.nisp_id, offset=300, len=4)
[12:27:51:300255][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.alter.crypto.esp_id, offset=300, len=4)
[12:27:51:300268][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.alter.push.vlan_tci, offset=64, len=2)
[12:27:51:300405][DOCA][INF][doca_flow_actions:759]: Doca flow actions UDS initialized
[12:27:51:300424][DOCA][INF][doca_flow_layer:62]: Doca flow layer initialized
[12:27:51:300437][DOCA][INF][doca_flow:679]: Doca flow initialized successfully
[12:27:51:301408][DOCA][INF][utils_hash_table:123]: hash table a_tmplt_t port 0 created
[12:27:51:301476][DOCA][INF][utils_hash_table:123]: hash table p_tmplt_t port 0 created
[12:27:51:303115][DOCA][INF][utils_hash_table:123]: hash table dpdk_tbl_mgr port 0 created
[12:27:51:303258][DOCA][INF][utils_hash_table:123]: hash table grp_fwd port 0 created
[12:27:51:303285][DOCA][INF][dpdk_port:161]: match on IPsec ASO syndrome is not supported - port 0 error:Operation not supported
[12:27:51:303304][DOCA][INF][dpdk_port:303]: Dpdk port 0 initialized successfully with 9 queues
[12:27:51:390106][DOCA][DBG][dpdk_flow_hws_legacy:76]: Port configure: port_id=0 queue_depth=128 queues=9 meters=0 counters=2
[12:27:51:390234][DOCA][ERR][dpdk_port_legacy:1167]: failed to create port 0 - configuration ret=-95
[12:27:51:390306][DOCA][INF][utils_hash_table:165]: hash table destroyed
[12:27:51:390836][DOCA][INF][utils_hash_table:165]: hash table destroyed
[12:27:51:390895][DOCA][INF][utils_hash_table:165]: hash table destroyed
[12:27:51:391552][DOCA][INF][utils_hash_table:165]: hash table destroyed
[12:27:51:391578][DOCA][INF][dpdk_port:463]: Dpdk port 0 destroyed successfully with 9 queues
[12:27:51:391595][DOCA][ERR][doca_flow:1405]: dpdk port creation failed
[12:27:51:391611][DOCA][ERR][flow_common:108]: Failed to start port: Unknown error
[12:27:51:391630][DOCA][ERR][FLOW_DROP:229]: Failed to init DOCA ports: Unknown error
[12:27:51:391667][DOCA][INF][doca_flow_match:577]: Doca flow match UDS destroyed
[12:27:51:391708][DOCA][INF][doca_flow_actions:771]: Doca flow actions UDS destroyed
[12:27:51:391723][DOCA][INF][doca_flow_layer:77]: Doca flow layer destroyed
[12:27:51:391737][DOCA][INF][dpdk_resource_manager:191]: Dpdk resource manager unregister completed
[12:27:51:391751][DOCA][INF][dpdk_flow:444]: Cleanup dpdk flow
[12:27:51:391764][DOCA][DBG][dpdk_flow_hws:72]: Cleanup dpdk flow HW steering module
[12:27:51:391776][DOCA][INF][dpdk_table:77]: Cleanup dpdk table
[12:27:51:391789][DOCA][DBG][dpdk_table_hws:914]: Cleanup dpdk table HW steering module
[12:27:51:391802][DOCA][INF][dpdk_layer:416]: Dpdk layer unregister completed
[12:27:51:391816][DOCA][INF][dpdk_pipe_items:187]: Destroyed dpdk pipe items module
[12:27:51:391830][DOCA][INF][engine_field_mapping:336]: Engine field mapping destroyed
[12:27:51:391851][DOCA][INF][engine_model:258]: engine model destroyed
[12:27:51:391864][DOCA][INF][doca_flow:694]: Doca flow destroyed
[12:27:51:391876][DOCA][ERR][FLOW_DROP::MAIN:77]: flow_drop() encountered errors
Tx port 0 is already stopped
[12:27:51:391968][DOCA][ERR][NUTILS:113]: Failed to bind hairpin queues (-16)
[12:27:51:391986][DOCA][ERR][NUTILS:200]: Disabling hairpin queues failed: err=21, port=0
[12:27:51:392037][DOCA][ERR][NUTILS:126]: Failed to bind hairpin queues (-16)
[12:27:51:392052][DOCA][ERR][NUTILS:200]: Disabling hairpin queues failed: err=21, port=1
Device with port_id=0 already stopped
[12:27:52:692618][DOCA][DBG][NUTILS:1109]: DPDK fini is done
port configure with incorrect steering mode,how can I configyre the correct steering mode?
can anyone help me?
I have solved this problem by add dv_flow_en=2 into eal below
./doca_flow_hairpin -a auxiliary:mlx5_core.sf.4,dv_flow_en=2 -a auxiliary:mlx5_core.sf.5,dv_flow_en=2 – -l 60
cause the cfg is “vnf,hws”,now it seems work correctly
