I compiled and ran the sample program, but the port did not receive any packets
why total bytes nad total packets are all 0?
And the full run output is:
ubuntu@localhost:/tmp/build$ sudo ./doca_flow_shared_counter -a auxiliary:mlx5_core.sf.4,dv_flow_en=2 -a auxiliary:mlx5_core.sf.5,dv_flow_en=2 -- -l 60
[18:40:36:370476][DOCA][INF][FLOW_SHARED_COUNTER::MAIN:51]: Starting the sample
EAL: Detected CPU lcores: 8
EAL: Detected NUMA nodes: 1
EAL: Detected shared linkage of DPDK
EAL: Multi-process socket /var/run/dpdk/rte/mp_socket
EAL: Selected IOVA mode 'PA'
TELEMETRY: No legacy callbacks, legacy socket not created
[18:40:36:647667][DOCA][DBG][NUTILS:533]: Port 0 MAC: 02 25 f2 8d a2 4c
[18:40:36:676743][DOCA][DBG][NUTILS:533]: Port 1 MAC: 02 25 f2 8d a2 5c
[18:40:36:678888][DOCA][WRN][engine_model:72]: adapting queue depth to 128.
[18:40:36:678934][DOCA][INF][engine_model:124]: engine model defined with mode=vnf
[18:40:36:678949][DOCA][INF][engine_model:126]: engine model defined with nr_pipe_queues=8
[18:40:36:678961][DOCA][INF][engine_model:127]: engine model defined with pipe_queue_depth=128
[18:40:36:684065][DOCA][INF][engine_field_mapping:329]: Engine field mapping initialized
[18:40:36:684177][DOCA][INF][engine_shared_resources:94]: Engine shared resources initialized successfully
[18:40:36:684196][DOCA][DBG][engine_pipe:78]: Engine pipe module initialized
[18:40:36:684211][DOCA][INF][dpdk_engine:288]: ACL number of collisions is zero, set it to default 3
[18:40:36:684251][DOCA][INF][dpdk_port:545]: dpdk port module init
[18:40:36:684264][DOCA][DBG][dpdk_table_hws:1152]: Initialized dpdk table work module to be HW steering
[18:40:36:684278][DOCA][INF][dpdk_table:72]: Initializing dpdk table successfully
[18:40:36:684290][DOCA][DBG][dpdk_flow_hws:36]: Initialized dpdk flow work module to be HW steering
[18:40:36:684302][DOCA][INF][dpdk_flow:68]: Initializing dpdk flow successfully
[18:40:36:684327][DOCA][INF][engine_shared_resources:133]: Allocated 2 shared resources of type 1
[18:40:36:684341][DOCA][INF][dpdk_resource_manager:184]: Dpdk resource manager register completed
[18:40:36:684712][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.meta.port, offset=0)
[18:40:36:684739][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.meta.mark, offset=0)
[18:40:36:684754][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.meta.random, offset=0)
[18:40:36:684957][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.meta.ipsec_syndrome, offset=0)
[18:40:36:684979][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.meta.hash, offset=0)
[18:40:36:684993][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.meta.meter_color, offset=0)
[18:40:36:685008][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.outer.eth.dst_mac, offset=0)
[18:40:36:685020][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.outer.eth.src_mac, offset=6)
[18:40:36:685033][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.outer.eth.type, offset=12)
[18:40:36:685046][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.inner.eth.dst_mac, offset=0)
[18:40:36:685059][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.inner.eth.src_mac, offset=6)
[18:40:36:685072][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.inner.eth.type, offset=12)
[18:40:36:685084][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.outer.eth_vlan0.tci, offset=0)
[18:40:36:685097][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.outer.eth_vlan1.tci, offset=0)
[18:40:36:685109][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.inner.eth_vlan0.tci, offset=0)
[18:40:36:685122][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.inner.eth_vlan1.tci, offset=0)
[18:40:36:685133][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.outer.ipv4.src_ip, offset=12)
[18:40:36:685146][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.outer.ipv4.dst_ip, offset=16)
[18:40:36:685158][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.outer.ipv4.dscp_ecn, offset=1)
[18:40:36:685172][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.outer.ipv4.next_proto, offset=9)
[18:40:36:685184][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.outer.ipv4.ttl, offset=8)
[18:40:36:685197][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.outer.ipv4.version_ihl, offset=0)
[18:40:36:685210][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.inner.ipv4.src_ip, offset=12)
[18:40:36:685223][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.inner.ipv4.dst_ip, offset=16)
[18:40:36:685235][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.inner.ipv4.dscp_ecn, offset=1)
[18:40:36:685248][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.inner.ipv4.next_proto, offset=9)
[18:40:36:685260][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.inner.ipv4.ttl, offset=8)
[18:40:36:685271][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.inner.ipv4.version_ihl, offset=0)
[18:40:36:685283][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.outer.ipv6.src_ip, offset=8)
[18:40:36:685296][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.outer.ipv6.dst_ip, offset=24)
[18:40:36:685308][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.outer.ipv6.dscp_ecn, offset=0)
[18:40:36:685319][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.outer.ipv6.next_proto, offset=6)
[18:40:36:685331][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.outer.ipv6.hop_limit, offset=7)
[18:40:36:685344][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.inner.ipv6.src_ip, offset=8)
[18:40:36:685356][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.inner.ipv6.dst_ip, offset=24)
[18:40:36:685368][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.inner.ipv6.dscp_ecn, offset=0)
[18:40:36:685381][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.inner.ipv6.next_proto, offset=6)
[18:40:36:685393][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.inner.ipv6.hop_limit, offset=7)
[18:40:36:685406][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.outer.udp.src_port, offset=0)
[18:40:36:685418][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.outer.udp.dst_port, offset=2)
[18:40:36:685430][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.inner.udp.src_port, offset=0)
[18:40:36:685443][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.inner.udp.dst_port, offset=2)
[18:40:36:685456][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.outer.tcp.src_port, offset=0)
[18:40:36:685468][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.outer.tcp.dst_port, offset=2)
[18:40:36:685480][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.outer.tcp.flags, offset=13)
[18:40:36:685492][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.inner.tcp.src_port, offset=0)
[18:40:36:685506][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.inner.tcp.dst_port, offset=2)
[18:40:36:685516][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.inner.tcp.flags, offset=13)
[18:40:36:685529][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.outer.icmp4.type, offset=0)
[18:40:36:685542][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.outer.icmp4.code, offset=1)
[18:40:36:685554][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.outer.icmp4.ident, offset=4)
[18:40:36:685565][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.inner.icmp4.type, offset=0)
[18:40:36:685577][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.inner.icmp4.code, offset=1)
[18:40:36:685590][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.inner.icmp4.ident, offset=4)
[18:40:36:685749][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.outer.icmp6.type, offset=0)
[18:40:36:685767][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.outer.icmp6.code, offset=1)
[18:40:36:685781][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.inner.icmp6.type, offset=0)
[18:40:36:685794][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.inner.icmp6.code, offset=1)
[18:40:36:685808][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.tunnel.vxlan.vni, offset=4)
[18:40:36:685911][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.tunnel.gre_key.value, offset=0)
[18:40:36:685928][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.tunnel.gre.protocol, offset=2)
[18:40:36:685942][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.tunnel.gtp.teid, offset=4)
[18:40:36:685955][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.tunnel.mpls.label, offset=0)
[18:40:36:685968][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.tunnel.geneve.ver_opt_len, offset=0)
[18:40:36:686043][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.tunnel.geneve.o_c, offset=1)
[18:40:36:686058][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.tunnel.geneve.next_proto, offset=2)
[18:40:36:686072][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.tunnel.geneve.vni, offset=4)
[18:40:36:686085][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.tunnel.geneve_opt.type, offset=0)
[18:40:36:686098][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.tunnel.geneve_opt.class, offset=0)
[18:40:36:686111][DOCA][DBG][dpdk_layer:85]: Registered dpdk field opcode=match.packet.tunnel.geneve_opt.data, offset=0)
[18:40:36:686126][DOCA][INF][dpdk_pipe_items:186]: Initialized dpdk pipe items module
[18:40:36:686137][DOCA][INF][dpdk_pipe:142]: Dpdk pipe initialized successfully
[18:40:36:686171][DOCA][INF][dpdk_layer:446]: Dpdk layer register completed
[18:40:36:686202][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.meta.data, offset=4, len=20)
[18:40:36:686218][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.meta.port, offset=24, len=4)
[18:40:36:686231][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.meta.mark, offset=28, len=4)
[18:40:36:686243][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.meta.random, offset=32, len=2)
[18:40:36:686256][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.meta.ipsec_syndrome, offset=34, len=1)
[18:40:36:686289][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.meta.flags, offset=0, len=4)
[18:40:36:686314][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.meta.meter_color, offset=35, len=1)
[18:40:36:686328][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.eth.dst_mac, offset=42, len=6)
[18:40:36:686341][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.eth.src_mac, offset=36, len=6)
[18:40:36:686355][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.eth.type, offset=48, len=2)
[18:40:36:686367][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.eth.dst_mac, offset=378, len=6)
[18:40:36:686381][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.eth.src_mac, offset=372, len=6)
[18:40:36:686394][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.eth.type, offset=384, len=2)
[18:40:36:686407][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.eth_vlan0.tci, offset=52, len=2)
[18:40:36:686420][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.eth_vlan1.tci, offset=54, len=2)
[18:40:36:686431][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.eth_vlan0.tci, offset=388, len=2)
[18:40:36:686444][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.eth_vlan1.tci, offset=390, len=2)
[18:40:36:686457][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.ipv4.src_ip, offset=60, len=4)
[18:40:36:686470][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.ipv4.dst_ip, offset=64, len=4)
[18:40:36:686483][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.ipv4.dscp_ecn, offset=69, len=1)
[18:40:36:686515][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.ipv4.next_proto, offset=70, len=1)
[18:40:36:686531][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.ipv4.ttl, offset=71, len=1)
[18:40:36:686700][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.ipv4.version_ihl, offset=68, len=1)
[18:40:36:686718][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.ipv4.src_ip, offset=396, len=4)
[18:40:36:686731][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.ipv4.dst_ip, offset=400, len=4)
[18:40:36:686744][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.ipv4.dscp_ecn, offset=405, len=1)
[18:40:36:686757][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.ipv4.next_proto, offset=406, len=1)
[18:40:36:686770][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.ipv4.ttl, offset=407, len=1)
[18:40:36:686783][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.ipv4.version_ihl, offset=404, len=1)
[18:40:36:686796][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.ipv6.src_ip, offset=60, len=16)
[18:40:36:686809][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.ipv6.dst_ip, offset=76, len=16)
[18:40:36:686820][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.ipv6.dscp_ecn, offset=92, len=1)
[18:40:36:686833][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.ipv6.next_proto, offset=93, len=1)
[18:40:36:686846][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.ipv6.hop_limit, offset=94, len=1)
[18:40:36:686859][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.ipv6.src_ip, offset=396, len=16)
[18:40:36:686871][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.ipv6.dst_ip, offset=412, len=16)
[18:40:36:686884][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.ipv6.dscp_ecn, offset=428, len=1)
[18:40:36:686896][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.ipv6.next_proto, offset=429, len=1)
[18:40:36:686909][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.ipv6.hop_limit, offset=430, len=1)
[18:40:36:686921][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.udp.src_port, offset=100, len=2)
[18:40:36:686934][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.udp.dst_port, offset=102, len=2)
[18:40:36:686946][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.udp.src_port, offset=436, len=2)
[18:40:36:686959][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.udp.dst_port, offset=438, len=2)
[18:40:36:686971][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.tcp.src_port, offset=100, len=2)
[18:40:36:686983][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.tcp.dst_port, offset=102, len=2)
[18:40:36:686997][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.tcp.flags, offset=104, len=1)
[18:40:36:687010][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.tcp.src_port, offset=436, len=2)
[18:40:36:687024][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.tcp.dst_port, offset=438, len=2)
[18:40:36:687036][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.tcp.flags, offset=440, len=1)
[18:40:36:687050][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.icmp4.type, offset=100, len=1)
[18:40:36:687062][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.icmp4.code, offset=101, len=1)
[18:40:36:687075][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.icmp4.ident, offset=102, len=2)
[18:40:36:687087][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.icmp4.type, offset=436, len=1)
[18:40:36:687100][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.icmp4.code, offset=437, len=1)
[18:40:36:687113][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.icmp4.ident, offset=438, len=2)
[18:40:36:687125][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.icmp6.type, offset=100, len=1)
[18:40:36:687139][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.outer.icmp6.code, offset=101, len=1)
[18:40:36:687152][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.icmp6.type, offset=436, len=1)
[18:40:36:687164][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.inner.icmp6.code, offset=437, len=1)
[18:40:36:687177][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.vxlan.vni, offset=112, len=3)
[18:40:36:687190][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.gre_key.value, offset=116, len=4)
[18:40:36:687203][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.gre.protocol, offset=114, len=2)
[18:40:36:687215][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.gtp.teid, offset=112, len=4)
[18:40:36:687228][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.esp.spi, offset=112, len=4)
[18:40:36:687240][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.esp.sn, offset=116, len=4)
[18:40:36:687253][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.mpls[0].label, offset=112, len=4)
[18:40:36:687266][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.mpls[1].label, offset=116, len=4)
[18:40:36:687279][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.mpls[2].label, offset=120, len=4)
[18:40:36:687293][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.mpls[3].label, offset=124, len=4)
[18:40:36:687307][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.mpls[4].label, offset=128, len=4)
[18:40:36:687320][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.geneve.ver_opt_len, offset=112, len=1)
[18:40:36:687334][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.geneve.o_c, offset=113, len=1)
[18:40:36:687346][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.geneve.next_proto, offset=114, len=2)
[18:40:36:687360][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.geneve.vni, offset=116, len=3)
[18:40:36:687373][DOCA][DBG][doca_flow_register:47]: Registered field opcode=match.packet.tunnel.geneve.options, offset=120, len=252)
[18:40:36:687458][DOCA][INF][doca_flow_match:563]: Doca flow match UDS initialized
[18:40:36:687473][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.meta.data, offset=12, len=20)
[18:40:36:687486][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.meta.port, offset=32, len=4)
[18:40:36:687498][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.meta.mark, offset=36, len=4)
[18:40:36:687510][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.meta.ipsec_syndrome, offset=42, len=1)
[18:40:36:687523][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.eth.dst_mac, offset=50, len=6)
[18:40:36:687537][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.eth.src_mac, offset=44, len=6)
[18:40:36:687550][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.eth.type, offset=56, len=2)
[18:40:36:687563][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.eth_vlan0.tci, offset=60, len=2)
[18:40:36:687576][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.eth_vlan1.tci, offset=62, len=2)
[18:40:36:687589][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.ipv4.src_ip, offset=68, len=4)
[18:40:36:687602][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.ipv4.dst_ip, offset=72, len=4)
[18:40:36:687613][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.ipv4.dscp_ecn, offset=77, len=1)
[18:40:36:687626][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.ipv4.next_proto, offset=78, len=1)
[18:40:36:687638][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.ipv4.ttl, offset=79, len=1)
[18:40:36:687717][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.ipv4.version_ihl, offset=76, len=1)
[18:40:36:687732][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.ipv6.src_ip, offset=68, len=16)
[18:40:36:687745][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.ipv6.dst_ip, offset=84, len=16)
[18:40:36:687760][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.ipv6.dscp_ecn, offset=100, len=1)
[18:40:36:687772][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.ipv6.next_proto, offset=101, len=1)
[18:40:36:687785][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.ipv6.hop_limit, offset=102, len=1)
[18:40:36:687933][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.udp.src_port, offset=108, len=2)
[18:40:36:687950][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.udp.dst_port, offset=110, len=2)
[18:40:36:687964][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.tcp.src_port, offset=108, len=2)
[18:40:36:687978][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.tcp.dst_port, offset=110, len=2)
[18:40:36:688054][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.icmp4.type, offset=108, len=1)
[18:40:36:688069][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.icmp4.code, offset=109, len=1)
[18:40:36:688083][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.icmp4.ident, offset=110, len=2)
[18:40:36:688096][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.icmp6.type, offset=108, len=1)
[18:40:36:688109][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.outer.icmp6.code, offset=109, len=1)
[18:40:36:688123][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.vxlan.vni, offset=120, len=3)
[18:40:36:688136][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.gre_key.value, offset=124, len=4)
[18:40:36:688149][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.gre.protocol, offset=122, len=2)
[18:40:36:688164][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.gtp.teid, offset=120, len=4)
[18:40:36:688177][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.esp.spi, offset=120, len=4)
[18:40:36:688264][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.esp.sn, offset=124, len=4)
[18:40:36:688279][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.mpls[0].label, offset=120, len=4)
[18:40:36:688293][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.mpls[1].label, offset=124, len=4)
[18:40:36:688306][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.mpls[2].label, offset=128, len=4)
[18:40:36:688320][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.mpls[3].label, offset=132, len=4)
[18:40:36:688388][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.mpls[4].label, offset=136, len=4)
[18:40:36:688403][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.geneve.ver_opt_len, offset=120, len=1)
[18:40:36:688417][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.geneve.o_c, offset=121, len=1)
[18:40:36:688431][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.geneve.next_proto, offset=122, len=2)
[18:40:36:688444][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.tunnel.geneve.vni, offset=124, len=3)
[18:40:36:688539][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.eth.dst_mac, offset=390, len=6)
[18:40:36:688554][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.eth.src_mac, offset=384, len=6)
[18:40:36:688568][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.eth.type, offset=396, len=2)
[18:40:36:688582][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.eth_vlan0.tci, offset=400, len=2)
[18:40:36:688595][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.eth_vlan1.tci, offset=402, len=2)
[18:40:36:688608][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.ipv4.src_ip, offset=408, len=4)
[18:40:36:688685][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.ipv4.dst_ip, offset=412, len=4)
[18:40:36:688700][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.ipv4.dscp_ecn, offset=417, len=1)
[18:40:36:688713][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.ipv4.next_proto, offset=418, len=1)
[18:40:36:688727][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.ipv4.ttl, offset=419, len=1)
[18:40:36:688740][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.ipv4.version_ihl, offset=416, len=1)
[18:40:36:688753][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.ipv6.src_ip, offset=408, len=16)
[18:40:36:688766][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.ipv6.dst_ip, offset=424, len=16)
[18:40:36:688856][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.ipv6.dscp_ecn, offset=440, len=1)
[18:40:36:688871][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.ipv6.next_proto, offset=441, len=1)
[18:40:36:688885][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.ipv6.hop_limit, offset=442, len=1)
[18:40:36:688899][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.udp.src_port, offset=448, len=2)
[18:40:36:688913][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.udp.dst_port, offset=450, len=2)
[18:40:36:688989][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.tcp.src_port, offset=448, len=2)
[18:40:36:689006][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.tcp.dst_port, offset=450, len=2)
[18:40:36:689021][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.icmp4.type, offset=448, len=1)
[18:40:36:689037][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.icmp4.code, offset=449, len=1)
[18:40:36:689050][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.icmp4.ident, offset=450, len=2)
[18:40:36:689136][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.icmp6.type, offset=448, len=1)
[18:40:36:689152][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.outer.icmp6.code, offset=449, len=1)
[18:40:36:689165][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.vxlan.vni, offset=460, len=3)
[18:40:36:689178][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.gre_key.value, offset=464, len=4)
[18:40:36:689192][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.gre.protocol, offset=462, len=2)
[18:40:36:689268][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.gtp.teid, offset=460, len=4)
[18:40:36:689283][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.esp.spi, offset=460, len=4)
[18:40:36:689297][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.esp.sn, offset=464, len=4)
[18:40:36:689310][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.mpls[0].label, offset=460, len=4)
[18:40:36:689322][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.mpls[1].label, offset=464, len=4)
[18:40:36:689336][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.mpls[2].label, offset=468, len=4)
[18:40:36:689348][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.mpls[3].label, offset=472, len=4)
[18:40:36:689437][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.mpls[4].label, offset=476, len=4)
[18:40:36:689456][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.geneve.ver_opt_len, offset=460, len=1)
[18:40:36:689469][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.geneve.o_c, offset=461, len=1)
[18:40:36:689482][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.geneve.next_proto, offset=462, len=2)
[18:40:36:689495][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.geneve.vni, offset=464, len=3)
[18:40:36:689508][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.encap.tunnel.geneve.options, offset=468, len=252)
[18:40:36:689586][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.alter.crypto.esp_id, offset=736, len=4)
[18:40:36:689600][DOCA][DBG][doca_flow_register:47]: Registered field opcode=actions.packet.alter.push.vlan_tci, offset=60, len=2)
[18:40:36:689758][DOCA][INF][doca_flow_actions:746]: Doca flow actions UDS initialized
[18:40:36:689774][DOCA][INF][doca_flow_layer:65]: Doca flow layer initialized
[18:40:36:689787][DOCA][INF][doca_flow:614]: Doca flow initialized successfully
[18:40:36:691092][DOCA][INF][utils_hash_table:123]: hash table a_tmplt_t port 0 created
[18:40:36:691221][DOCA][INF][utils_hash_table:123]: hash table p_tmplt_t port 0 created
[18:40:36:693294][DOCA][INF][utils_hash_table:123]: hash table dpdk_tbl_mgr port 0 created
[18:40:36:693448][DOCA][INF][utils_hash_table:123]: hash table grp_fwd port 0 created
[18:40:36:693553][DOCA][DBG][dpdk_meter_profiles:100]: profile table created p0_prof_main (0xaaaad7adce60)
[18:40:36:693583][DOCA][DBG][dpdk_meter_profiles:100]: profile table created p0_prof_c0 (0xaaaad7add080)
[18:40:36:693610][DOCA][DBG][dpdk_meter_profiles:100]: profile table created p0_prof_c1 (0xaaaad7add2a0)
[18:40:36:693633][DOCA][DBG][dpdk_meter_profiles:100]: profile table created p0_prof_c2 (0xaaaad7add4c0)
[18:40:36:693661][DOCA][DBG][dpdk_meter_profiles:100]: profile table created p0_prof_c3 (0xaaaad7add6e0)
[18:40:36:693685][DOCA][DBG][dpdk_meter_profiles:100]: profile table created p0_prof_c4 (0xaaaad7add900)
[18:40:36:693711][DOCA][DBG][dpdk_meter_profiles:100]: profile table created p0_prof_c5 (0xaaaad7addb20)
[18:40:36:693737][DOCA][DBG][dpdk_meter_profiles:100]: profile table created p0_prof_c6 (0xaaaad7addd40)
[18:40:36:693765][DOCA][DBG][dpdk_meter_profiles:100]: profile table created p0_prof_c7 (0xaaaad7addf60)
[18:40:36:693790][DOCA][DBG][dpdk_meter_profiles:100]: profile table created p0_prof_c8 (0xaaaad7ade180)
[18:40:36:761617][DOCA][DBG][dpdk_port_hws:72]: Port configure: port_id=0 queue_depth=128 queues=9 meters=0 counters=2
[18:40:37:815011][DOCA][INF][dpdk_port:721]: Dpdk port 0 initialized successfully with 9 queues
[18:40:37:815119][DOCA][WRN][engine_port:246]: detected representor used in VNF mode (driver port id 0)
[18:40:37:815143][DOCA][DBG][engine_port:333]: Port with driver id 0 and container idx 0 - created successfully
[18:40:37:815193][DOCA][DBG][dpdk_fwd_groups:412]: create dpdk_fwd_group flow, type 4
[18:40:37:866543][DOCA][DBG][dpdk_fwd_groups:412]: create dpdk_fwd_group flow, type 6
[18:40:37:878238][DOCA][DBG][engine_port:552]: Port with driver id 0 started successfully
[18:40:37:878302][DOCA][INF][doca_flow:1454]: doca flow port with id=0, type=0 started
[18:40:37:878447][DOCA][INF][utils_hash_table:123]: hash table a_tmplt_t port 1 created
[18:40:37:879203][DOCA][INF][utils_hash_table:123]: hash table p_tmplt_t port 1 created
[18:40:37:881273][DOCA][INF][utils_hash_table:123]: hash table dpdk_tbl_mgr port 1 created
[18:40:37:881440][DOCA][INF][utils_hash_table:123]: hash table grp_fwd port 1 created
[18:40:37:881521][DOCA][DBG][dpdk_meter_profiles:100]: profile table created p1_prof_main (0xaaaad7ff5840)
[18:40:37:881555][DOCA][DBG][dpdk_meter_profiles:100]: profile table created p1_prof_c0 (0xaaaad7ff5a60)
[18:40:37:881584][DOCA][DBG][dpdk_meter_profiles:100]: profile table created p1_prof_c1 (0xaaaad7ff5c80)
[18:40:37:881631][DOCA][DBG][dpdk_meter_profiles:100]: profile table created p1_prof_c2 (0xaaaad7ff5ea0)
[18:40:37:881660][DOCA][DBG][dpdk_meter_profiles:100]: profile table created p1_prof_c3 (0xaaaad7ff60c0)
[18:40:37:881691][DOCA][DBG][dpdk_meter_profiles:100]: profile table created p1_prof_c4 (0xaaaad7ff62e0)
[18:40:37:881721][DOCA][DBG][dpdk_meter_profiles:100]: profile table created p1_prof_c5 (0xaaaad7ff6500)
[18:40:37:881749][DOCA][DBG][dpdk_meter_profiles:100]: profile table created p1_prof_c6 (0xaaaad7ff6720)
[18:40:37:881775][DOCA][DBG][dpdk_meter_profiles:100]: profile table created p1_prof_c7 (0xaaaad7ff6940)
[18:40:37:881804][DOCA][DBG][dpdk_meter_profiles:100]: profile table created p1_prof_c8 (0xaaaad7ff6b60)
[18:40:37:952406][DOCA][DBG][dpdk_port_hws:72]: Port configure: port_id=1 queue_depth=128 queues=9 meters=0 counters=2
[18:40:39:011728][DOCA][INF][dpdk_port:721]: Dpdk port 1 initialized successfully with 9 queues
[18:40:39:011827][DOCA][WRN][engine_port:246]: detected representor used in VNF mode (driver port id 1)
[18:40:39:011853][DOCA][DBG][engine_port:333]: Port with driver id 1 and container idx 1 - created successfully
[18:40:39:011900][DOCA][DBG][dpdk_fwd_groups:412]: create dpdk_fwd_group flow, type 4
[18:40:39:063577][DOCA][DBG][dpdk_fwd_groups:412]: create dpdk_fwd_group flow, type 6
[18:40:39:075295][DOCA][DBG][engine_port:552]: Port with driver id 1 started successfully
[18:40:39:075346][DOCA][INF][doca_flow:1454]: doca flow port with id=1, type=0 started
[18:40:39:075363][DOCA][INF][dpdk_port_legacy:1055]: doca pair ports id 1 - 0
[18:40:39:075383][DOCA][DBG][dpdk_fwd_groups:412]: create dpdk_fwd_group flow, type 1
[18:40:39:080000][DOCA][DBG][dpdk_fwd_groups:412]: create dpdk_fwd_group flow, type 1
[18:40:39:084231][DOCA][DBG][engine_port:463]: Ports with driver ids 1 and 0 paired successfully
[18:40:39:084430][DOCA][INF][dpdk_pipe_common:528]: entry pool 9 cache enabled, change nb_entries from 8192 to 12288
[18:40:39:106016][DOCA][DBG][dpdk_pipe_legacy:791]: pipe of type 0 created on port 0
[18:40:39:106327][DOCA][INF][dpdk_pipe_common:528]: entry pool 9 cache enabled, change nb_entries from 8192 to 12288
[18:40:39:127367][DOCA][DBG][dpdk_pipe_legacy:791]: pipe of type 0 created on port 0
[18:40:39:127648][DOCA][INF][dpdk_pipe_common:528]: entry pool 9 cache enabled, change nb_entries from 8192 to 12288
[18:40:39:131125][DOCA][DBG][dpdk_pipe_legacy:791]: pipe of type 1 created on port 0
[18:40:39:147061][DOCA][INF][dpdk_pipe_common:528]: entry pool 9 cache enabled, change nb_entries from 8192 to 12288
[18:40:39:167850][DOCA][DBG][dpdk_pipe_legacy:791]: pipe of type 0 created on port 1
[18:40:39:168123][DOCA][INF][dpdk_pipe_common:528]: entry pool 9 cache enabled, change nb_entries from 8192 to 12288
[18:40:39:188916][DOCA][DBG][dpdk_pipe_legacy:791]: pipe of type 0 created on port 1
[18:40:39:189267][DOCA][INF][dpdk_pipe_common:528]: entry pool 9 cache enabled, change nb_entries from 8192 to 12288
[18:40:39:192748][DOCA][DBG][dpdk_pipe_legacy:791]: pipe of type 1 created on port 1
[18:40:39:208822][DOCA][INF][FLOW_SHARED_COUNTER:329]: Wait few seconds for packets to arrive
[18:40:44:208963][DOCA][INF][FLOW_SHARED_COUNTER:342]: Port 0:
[18:40:44:209073][DOCA][INF][FLOW_SHARED_COUNTER:343]: Total bytes: 0
[18:40:44:209087][DOCA][INF][FLOW_SHARED_COUNTER:344]: Total packets: 0
[18:40:44:209099][DOCA][INF][FLOW_SHARED_COUNTER:342]: Port 1:
[18:40:44:209112][DOCA][INF][FLOW_SHARED_COUNTER:343]: Total bytes: 0
[18:40:44:209124][DOCA][INF][FLOW_SHARED_COUNTER:344]: Total packets: 0
[18:40:44:244192][DOCA][DBG][engine_port:583]: Port with driver id 0 stopped successfully
[18:40:44:267111][DOCA][INF][utils_hash_table:165]: hash table destroyed
[18:40:44:267278][DOCA][INF][utils_hash_table:165]: hash table destroyed
[18:40:44:267349][DOCA][INF][utils_hash_table:165]: hash table destroyed
[18:40:44:268320][DOCA][INF][utils_hash_table:165]: hash table destroyed
[18:40:44:268346][DOCA][DBG][dpdk_meter_profiles:152]: profile table destroyed (0xaaaad7add080)
[18:40:44:268369][DOCA][DBG][dpdk_meter_profiles:152]: profile table destroyed (0xaaaad7add2a0)
[18:40:44:268391][DOCA][DBG][dpdk_meter_profiles:152]: profile table destroyed (0xaaaad7add4c0)
[18:40:44:268458][DOCA][DBG][dpdk_meter_profiles:152]: profile table destroyed (0xaaaad7add6e0)
[18:40:44:268480][DOCA][DBG][dpdk_meter_profiles:152]: profile table destroyed (0xaaaad7add900)
[18:40:44:268500][DOCA][DBG][dpdk_meter_profiles:152]: profile table destroyed (0xaaaad7addb20)
[18:40:44:268521][DOCA][DBG][dpdk_meter_profiles:152]: profile table destroyed (0xaaaad7addd40)
[18:40:44:268549][DOCA][DBG][dpdk_meter_profiles:152]: profile table destroyed (0xaaaad7addf60)
[18:40:44:268572][DOCA][DBG][dpdk_meter_profiles:152]: profile table destroyed (0xaaaad7ade180)
[18:40:44:268596][DOCA][DBG][dpdk_meter_profiles:152]: profile table destroyed (0xaaaad7adce60)
[18:40:44:268616][DOCA][INF][dpdk_port:927]: Dpdk port 0 destroyed successfully with 9 queues
[18:40:44:268635][DOCA][DBG][engine_port:429]: Port with driver id 0 put in container idx 0 - destroyed successfully
[18:40:44:300938][DOCA][DBG][engine_port:583]: Port with driver id 1 stopped successfully
[18:40:44:324747][DOCA][INF][utils_hash_table:165]: hash table destroyed
[18:40:44:325283][DOCA][INF][utils_hash_table:165]: hash table destroyed
[18:40:44:325616][DOCA][INF][utils_hash_table:165]: hash table destroyed
[18:40:44:326823][DOCA][INF][utils_hash_table:165]: hash table destroyed
[18:40:44:326862][DOCA][DBG][dpdk_meter_profiles:152]: profile table destroyed (0xaaaad7ff5a60)
[18:40:44:326892][DOCA][DBG][dpdk_meter_profiles:152]: profile table destroyed (0xaaaad7ff5c80)
[18:40:44:326913][DOCA][DBG][dpdk_meter_profiles:152]: profile table destroyed (0xaaaad7ff5ea0)
[18:40:44:326936][DOCA][DBG][dpdk_meter_profiles:152]: profile table destroyed (0xaaaad7ff60c0)
[18:40:44:326960][DOCA][DBG][dpdk_meter_profiles:152]: profile table destroyed (0xaaaad7ff62e0)
[18:40:44:326981][DOCA][DBG][dpdk_meter_profiles:152]: profile table destroyed (0xaaaad7ff6500)
[18:40:44:327001][DOCA][DBG][dpdk_meter_profiles:152]: profile table destroyed (0xaaaad7ff6720)
[18:40:44:327023][DOCA][DBG][dpdk_meter_profiles:152]: profile table destroyed (0xaaaad7ff6940)
[18:40:44:327046][DOCA][DBG][dpdk_meter_profiles:152]: profile table destroyed (0xaaaad7ff6b60)
[18:40:44:327068][DOCA][DBG][dpdk_meter_profiles:152]: profile table destroyed (0xaaaad7ff5840)
[18:40:44:327088][DOCA][INF][dpdk_port:927]: Dpdk port 1 destroyed successfully with 9 queues
[18:40:44:327104][DOCA][DBG][engine_port:429]: Port with driver id 1 put in container idx 0 - destroyed successfully
[18:40:44:327137][DOCA][INF][doca_flow_match:575]: Doca flow match UDS destroyed
[18:40:44:327164][DOCA][INF][doca_flow_actions:758]: Doca flow actions UDS destroyed
[18:40:44:327177][DOCA][INF][doca_flow_layer:82]: Doca flow layer destroyed
[18:40:44:327190][DOCA][INF][dpdk_pipe_items:198]: Destroyed dpdk pipe items module
[18:40:44:327200][DOCA][INF][dpdk_pipe:150]: Dpdk pipe destroyed
[18:40:44:327212][DOCA][INF][dpdk_resource_manager:191]: Dpdk resource manager unregister completed
[18:40:44:327224][DOCA][INF][dpdk_flow:449]: Cleanup dpdk flow
[18:40:44:327237][DOCA][DBG][dpdk_flow_hws:72]: Cleanup dpdk flow HW steering module
[18:40:44:327249][DOCA][INF][dpdk_table:79]: Cleanup dpdk table
[18:40:44:327263][DOCA][DBG][dpdk_table_hws:1159]: Cleanup dpdk table HW steering module
[18:40:44:327275][DOCA][INF][dpdk_port:552]: dpdk port module cleanup
[18:40:44:327286][DOCA][INF][dpdk_layer:461]: Dpdk layer unregister completed
[18:40:44:327297][DOCA][DBG][engine_pipe:85]: Engine pipe module destroyed
[18:40:44:327312][DOCA][INF][engine_shared_resources:243]: Cleanup 2 shared resources of type 1 completed
[18:40:44:327326][DOCA][INF][engine_field_mapping:336]: Engine field mapping destroyed
[18:40:44:327348][DOCA][INF][engine_model:370]: engine model destroyed
[18:40:44:327358][DOCA][INF][doca_flow:636]: Doca flow destroyed
[18:40:44:996569][DOCA][DBG][NUTILS:1109]: DPDK fini is done
[18:40:44:996652][DOCA][INF][FLOW_SHARED_COUNTER::MAIN:89]: Sample finished successfully
can you share the output from command
sudo ovs-vsctl show
find the bridge name from output and run the command
sudo ovs-ofctl dump-flows bridge-name
I think you may need packet generator send flow to port.
I have the same issue, can you please elaborate on how to setup the tuple matching and packet generator? Mine didn’t work. Thank you!
doca_flow_hairpin:
Packet generator:
Program output:
